Old Today, 09:28 AM   #226
SCOTI
SCOTI's Avatar
Re: 1964 C10 fleet side swb
Originally Posted by Justin71105 View Post
I've been having that front end pop for a few months now and today I finally found out what it was and fixed it.
When installing the coils springs I was placing the springs in the lower control arm and using that groove in the lower to align them. Problem is the top does not fit in the D shape properly when this is done, found online that someone recommended starting on the upper since it is a fixed position as well and it doesn't move like the lower control arm when you are installing.
I found the third ring down on the coil spring was rubbing the engine cross member where it goes up in there. The spring would also rotate slightly from the upper portion not being locked into the D shape. I think it would rotate and give a slight gap and I wouldn't hear the popping for a little while and then spin back and start it up again.
Simply dropped lower control arm and aligned the upper first then brought the control arm up to the lower side of spring.
Did this to both sides and now have a 1" gap or more all the way around the engine member.
Took it down the road and no more popping, the spring had been rubbed pretty good on the drivers side and that's were I was hearing the noise most consistently.
Also figured out the belt needed for the Holley kit with a little work around. I dropped my idler pulley size under the alternator from a 90mm to a 76mm and the 113" belt fit. Seemed pretty tight to me but the tensioner now lines up with the marks it needs to almost perfectly.
True... But I rarely have that issue because that top coil is usually trimmed off. I use the lower a-arm divot as my guide.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old Today, 01:22 PM   #227
Justin71105
Yeah thats how I am used to installing them as well.
I just think these are too much of a drop, they are still moving in the pockets even clocked correctly on bottom or top.
I believe when I hit some pot holes or bunps and the suspension raises the springs are just moving around in there loose.
Either going to get some 2" drop coils or find an isolator that fits. Pretty sure these are 3" coils, with the frame jacled up I can spin them slightly before they catch.
When they uncompress on a bump they could be moving all around.
Also thought about using a j bolt to cinch them down. There is a hole right inside the lower pocket to put it in.
-- Picked up some J hooks and habe both coils locked down, will mark the coils and see tomorrow if they are still able to rotate.
1964 C10 Resto-mod
5.3L - L59
Justin71105 is offline   Reply With Quote
