Old 07-14-2024, 07:08 PM   #1226
chewychevy67
Re: 67 GMC super custom build
Thanks guys. That is the first full weekend in a long time I spent on the truck. I really wasn't looking forward to making all the rest of the holes to mount my trim and emblems but I did get it all done. Only drilled 1 wrong and had to weld and redo it. I can't imagine adding the trim after it's painted. That would be full on stress.
chewychevy67 is online now   Reply With Quote
Old 07-16-2024, 12:09 AM   #1227
chewychevy67
I removed my hood and am going to send my hood hinges to willie for restoration so tonight I got half way thru the next job I'm not that fond of doing. Being my truck is a 67 it did not have cab to fender seals. I have to drill the holes and mount them. I have tried this on 3 other cabs with new seals and they never work. So this time I took some originals and mounted them. They have been molded for 50 years and were a nice fit plus my doors can close and open without catching them! Passenger door next. The special washers that I had 3d printed worked absolutely awesome and with my door wiring boot mounted at an angle it won't get in the way of the seals like they would if they were mounted just on the face of the Pillar.
Old 07-19-2024, 07:46 PM   #1228
chewychevy67
I Got the passenger side done today. Much easier the second go round. I realized that I put the seal backwards on the bottom 2 screws on the driver seal so I'll have to correct that.
Old 07-26-2024, 12:05 AM   #1229
chewychevy67
OK so here's where most of you are going to think im nuts. I've decided not to use any fat mat or anything like that to put inside the doors, on the cab floor or firewall. I have decided to go completely stock. Which is basically nothing. But if I truly want the 60s experience it's gonna be loud lol. Just mocking up the new original style insulation with the heated seat wiring. I may put just on the back of the carpet but we'll see. Carpet will be original as well. No carpet under the seats.
Old 07-26-2024, 08:30 AM   #1230
IronCanine
I'm trying....
IronCanine's Avatar
Dude....I'm on the crazy train with you! I'm putting bias ply tires on mine!!!!!!
We hidin' from the world too much nowadays...let's feel it and hear it!!!
IronCanine is offline   Reply With Quote
Old 07-26-2024, 12:57 PM   #1231
chewychevy67
So here's something I've been thinking about for quite some time. I love the flat ribbon that I'm using for my heated seats. Lays flat under the rug and you can't feel it very much under the carpet. I want to run my fuel tank wire and interior lights wires there as well instead of by the sill plate and those wires are thin so no worries there. Now for the power seat motor wiring. I have a 10 gauge wire running there and you can absolutely feel it. It's thick. I have pondered running it thru the ribbon but I'm concerned it wouldn't carry enough current if both were being used at the same time. The chevelle I got the harness from also had a plastic sleeve around it but then you have a large bump. I was thinking I'd find something thinner to wrap this in.
Old 07-26-2024, 08:56 PM   #1232
chewychevy67
I layed my original carpet in my cab to see if you could feel the wires and it's not too bad. I'm happy with it. Especially once the carpet is new it will look smoother.
Old 07-26-2024, 09:08 PM   #1233
chewychevy67
Floor mat makes it so you can't even feel it.
Old 07-29-2024, 02:59 PM   #1234
chewychevy67
So instead of using the original sheet metal type screws for my sill plates I decided to use t nuts like this. They sit in the hole you drilled and give you extra thread for a real nut. Nut gets welded on the flange to the body underneath and it will tighten better without stripping and it will still look like a truss head from the top.
Old 08-02-2024, 10:58 PM   #1235
chewychevy67
So tonight I mocked up the heat stove pipe into my air cleaner. The big block this air cleaner was on had a big metal piece that obviously did not fit my small block so this is what i made. I used 2 stove pipes to make 1 so both ends are expanded to fit tighter. Now I just have to weld it all together.
Old 08-05-2024, 04:28 PM   #1236
chewychevy67
Today I made the mount for the instant aire connection. I'll run a metal vacuum line across the inner fender to the engine with a rubber hose on either side.
Old 08-10-2024, 02:00 AM   #1237
chewychevy67
Tonight I added a cup holder to the ash tray of my truck. I was really hesitant about adding this because I hear how flimsy they can be. I used a 4 runner slider cup holder and had a 3d printed housing made. I'm helping this guy make one for 67 trucks as he has already made a housing for 68 to 72 trucks. I had to modify a bit and I'll report back so he can offer a unit for 67 trucks as well. I must say this turned out really well and it's nice and tight. I may just keep this . I also mounted it in a way that without any modification I can put the old ash tray in no problems. Takes 2 minutes.
Old 08-27-2024, 12:47 AM   #1238
chewychevy67
My fog lights are close to my bumper brackets and james used a 72 chevy bumper which was smart because it uses longer brackets to clear the marker lights so now that I have it all together I wanted full adjustment of the fog lights so I bought some 72 4x4 brackets and I cut out the indented area and am going to add it to my brackets where it passes the fog lights. Should look stock.
Old 08-28-2024, 09:27 PM   #1239
chewychevy67
I've been thinking about how I could add cornering lights as my cadillac telescopic column wiring in my truck is all set up to wire them in. I have 2 chrome cast bezels that fit under the mouldings nicely and Im Going to see if I can get a bulb to cast a proper beam for this before I think about any surgery to the fenders and if i do thisi will get a custom lens moulded for this. Again completely unnecessary but another option all the cars had available but not the trucks.
Old 08-29-2024, 07:53 AM   #1240
clay68c10
clay68c10's Avatar
Those cornering lights were a cool feature, I like the version you're going for.
As I recall (in my 68), you could have one side or the other stay on when the Twilight Sentinel was running by engaging the turn signal when you shut off the car.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 08-29-2024, 09:27 AM   #1241
chewychevy67
Yep. That is correct. The signal won't come on but the cornering light will to the side the signal lever is set to and stay on till the sentinel turns off.
Old 08-29-2024, 04:49 PM   #1242
chewychevy67
Also thinking of a light like this with a projector bulb with a shield on it so it only shoots light lower. This one would be easier to mount but it will stand out more than the rectangle one. Rectanglewould blend in more and look better with the lines of the Truck. Here's a look at both I'm contemplating.
I think I will use the rectangular lens. It has a wider pattern and a nice cut off. I put it around the height it will be on the truck and the fence is a highway lane across maby a touch more from the lens. I can adjust the cut off if I make a shield for it but I wouldn't do that till it's on the truck when it's finished.
Old 08-30-2024, 02:24 PM   #1243
67 Burb
67 Burb's Avatar
Looks like the landing lights on a Boeing 737.
Bob
1967 2wd Burb, 350/TH350, 3.73 posi
67 Burb is offline   Reply With Quote
Old 08-30-2024, 06:18 PM   #1244
IronCanine
I'm trying....
IronCanine's Avatar
Northern Lights.
Old 08-30-2024, 06:26 PM   #1245
chewychevy67
OK guys lol. They really aren't that bright in person. Once they are working with the headlight they will appear dim.
Old 08-31-2024, 11:08 AM   #1246
IronCanine
I'm trying....
IronCanine's Avatar
Mine was more of a geographic burn. I think they're cool...I mean, my disposition about the awesomeness of this build is well established. What's amazing is...just when I think you're done, you got another cool thing and another cool thing and another cool thing. Wild.
Old 09-06-2024, 02:16 PM   #1247
chewychevy67
Got it outside today to get a full view of it. Sometimes it's hard to visualize what it is your trying to accomplish when you only looking at small sections of the vehicle all the time. Hood hinges are being shipped back today. I hear Willie Wilson is the man when it comes to rebuilt hood hinges so soon I can put it back on.
Old 09-06-2024, 03:07 PM   #1248
68bowtie
68bowtie's Avatar
Looks good.
I don’t recall, do you plan to keep it factory height?
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Old 09-06-2024, 03:19 PM   #1249
chewychevy67
Yes I am. When it's all done and if I don't like the rake look I may even the back and front to believe but that's about it.
Old 09-06-2024, 07:05 PM   #1250
chewychevy67
I did some paint on my phone with this picture out of boardom. Not great but gives me an idea of how it might look. Mabey soon one of these paint jobs will be a reality! I'm thinking I'll probably paint it like the truck in the last 2 photos without the cowl hood buy may just do the white roof. The 67 roof paint style isn't my favorite but it's still in the mix but only with the white bottom.
