Old 07-27-2024, 08:00 AM   #16
Joyridin
Re: Body mounting hardware
If you look at my post called "Freebies", I just gave away a set of polyurethane bushings. Yes, my truck is lowered, has coilovers, sway bars, 20" wheels, aftermarket front suspension and rear suspension. Those bushings do nothing but make your teeth fall out. Every bump you hit is like you hit a pothole 2' deep. Everything inside rattled and vibrated beyond belief no matter how well you pit it together. Hitting larger bumps made you jump in the seat, which in turn made your hands on the wheel jump, which made you twitch the steering wheel. Not fun when you are "carving a corner".
Joyridin is offline   Reply With Quote
