Old 07-21-2024, 10:01 AM   #1
chevyindallas
Bracket for drive shaft carrier bearing
The previous owner welded the carrier bearing to the bracket that it bolts to and there no longer seem to be any bolt holes for the carrier bearing to attach to even if I was able to cut off the bearing. Does anyone know if there is a replacement bracket that can bolt on where the current bracket is?
chevyindallas is offline   Reply With Quote
Old 07-21-2024, 10:15 AM   #2
custom10nut
custom10nut's Avatar
Re: Bracket for drive shaft carrier bearing
It sounds like you’re going to need a new cross member.
At the very least, you need to fabricate the mount point.
It needs to all be lined up as it was from the factory, or you’ll forever have driveshaft issues
custom10nut is offline   Reply With Quote
Old 07-21-2024, 10:24 AM   #3
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Carrier bracket has to be dead nuts for new holes. If I remember right, my crossmember, and perhaps all 1971ish CMs have six holes. Only four are used, depending on the chassis, I suppose. I don't know the hole measurements, and a glance of the web implies the mounts vary. This bracket is on my truck, front holes have threads.
Look on the parts board, though you have to be a paying member to do that.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 07-21-2024, 11:41 AM   #4
LockDoc
The Older Generation
LockDoc's Avatar
He doesn't have to be a paying member to look, or buy items posted for sale on the parts board.
He would have to be a paying member to post a want to buy though, I think that is what you were thinking about....
Leon
Old 07-21-2024, 12:38 PM   #5
Jason Banks
Jason Banks's Avatar
Post some pictures of what you are working with. Maybe we can point you to exactly what you need...
Jason Banks is offline   Reply With Quote
Old 07-21-2024, 12:41 PM   #6
71CHEVYSHORTBED402
Probably, thanks
Tony
Old 07-21-2024, 09:21 PM   #7
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: Bracket for drive shaft carrier bearing
if you can post a picture of your bracket someone on here can help i'm sure.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is online now   Reply With Quote
Old 07-22-2024, 08:27 AM   #8
Lee H
Lee H's Avatar
Long or short bed?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 07-22-2024, 09:56 AM   #9
chevyindallas
Excellent. Will do
Old 07-22-2024, 09:56 AM   #10
chevyindallas
Originally Posted by Lee H View Post
Long or short bed?
Long bed
Old 07-22-2024, 09:58 AM   #11
chevyindallas
That's what I was afraid of
Old 07-22-2024, 10:10 AM   #12
Jason Banks
Since you are new here, to post a picture, click the "Go Advanced" button underneath the "Quick Reply" section "Message" box where you would normally type your reply in this thread.
Once on the advanced page there is a Paper Clip icon where you can attach files.
Old 07-22-2024, 12:38 PM   #13
Orange Crate
Orange Crate's Avatar
X2 for pictures. Because the bearing has been welded to the bracket does not mean that it can't be salvaged. Welding is just extra metal and that can be be removed. But I guess it depends on how bad the "weld" is.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed
Orange Crate is offline   Reply With Quote
Old 07-22-2024, 04:27 PM   #14
chevyindallas
Thanks for the help so far. Here are photos of the bracket. Let me know if a different angle would be helpful.
I am starting to think that I can just cut of the old bearing strap and grind the bracket till it is smooth but would love y'alls opinions.
Old 07-22-2024, 08:01 PM   #15
Orange Crate
I would get that whole unit off of there and put it in a plastic 5 gallon bucket and use the magic electrolysis (lots of videos on how to do this) to get it cleaned up. Then you can come up with a plan on what to do. At first glance I think it can be saved. One thing about electrolysis is it gets in between the parts that are spot welded or not accessible with mechanical methods.
Old 07-22-2024, 08:06 PM   #16
chevyindallas
I can give that a shot. Would you just drill out the rivets that are holding the bracket onto the cross member?
Old 07-22-2024, 08:40 PM   #17
Jason Banks
I would not worry too much about that surface rust.
Your plan of attacking it with a grinder to get back to the flat surface where you can bolt a new carrier bearing sounds perfect.
If you don't mind the expense get the billet carrier bearing like this:
https://www.summitracing.com/parts/wst-bcb-6372
or this - https://www.amazon.com/Driveshaft-re.../dp/B0B7WTDM7R
The reason whey they welded the previous one is because the quality of the carrier bearings like you have has gone to crap, the factory style. I have one of the factory style on a truck that I have welded back together at lest 3 times. Never considered just welding it to the truck, but I guess that fixed it until the next guy has to change the carrier bearing again.
Old 07-23-2024, 09:25 AM   #18
chevyindallas
Love this idea. Thanks!
Old 07-24-2024, 10:31 PM   #19
michael bustamante
michael bustamante's Avatar
If it turns out the crossmemver is too far gone, I have crossmemver I can cut out of the frame for you. Lemme know
1967custom
michael bustamante is offline   Reply With Quote
Old 07-25-2024, 12:15 PM   #20
Orange Crate
I think what happens is if the slip joint isn't greased the driveshaft movement tends to push the stock carrier forward and backwards. And with a little rust sets up a stress point.... The aftermarket ones look to be more solid but you still have to grease that slip.....
Old 07-25-2024, 08:50 PM   #21
HO455
HO455's Avatar
I'm going to try and clear some misconceptions up. The carrier bearing in question is for the basic coil spring 1/2 ton truck. These trucks did not come with a sliding joint in the rear drive shaft like the 3/4 tons and leaf spring 1/2 ton trucks like 71CHEVYSHORTBED402 shows.
I have seen 3 different styles of carrier bearings for the various 67-72 trucks and there may be more I haven’t seen so it's no wonder as to why there is confusion. Photo #1 shows the basic 1/2 ton driveline with no sliding joint.
When the truck's rear axle moves up and down the drive shaft moves fore and aft. On trucks like 71CHEVYSHORTBED402's the slip joint absorbs this move by collapsing and expanding as needed.
On the basic 1/2 ton the movement is absorbed by the yoke on the end of the transmission moving in and out of the tailshaft. In the 2nd photo the red arrows indicate the fore and aft movement of the driveline. Since the bearing doesn't slide on the driveline the rubber bushing flexs to allow the bearing to move fore and aft. The green arrows point to the rubber bushing that must flex. The rubber will only flex so far so the carrier bearing MUST be installed with no preload on the rubber when the truck is at ride height.
The yellow arrow points to the slots in the bearing mount that allow the carrier to be installed with no preload at ride height.
Things get problematic when the truck is lowered (or raised) too much and the adjustment range provided by the factory isn't enough and the bearing gets installed with a preload either forward or aft. When that happens the rubber cannot flex enough and the bracket then is forced to flex, eventually work hardening the steel and breaking apart.
Another common cause of carrier failure on a stock height truck is installing the carrier with the rear axle hanging and not sitting at ride height. 2 post lifts are nice but.....
As mentioned you can replace the factory style carrier bearing with the billet style but you MUST replace the complete driveline with one that has the sliding joint in the rear half of the driveline as the billet carrier does not flex. Billet style shown in last photo. Green arrow indicates the sliding joint.
I hope this helps. If not just shout out and hopefully I answer the questions.
RIP Bob Parks.
Old 07-25-2024, 09:01 PM   #22
Steeveedee
Who Changed This?
Steeveedee's Avatar
^ I learned this lesson 50 years ago-
"Another common cause of carrier failure on a stock height truck is installing the carrier with the rear axle hanging and not sitting at ride height. 2 post lifts are nice but....."
It includes cars, like my '64 Impala. BTDT
~Steven
Simi Valley, CA
Old 07-30-2024, 11:09 AM   #23
chevyindallas
Whoa! This is hugely helpful. And definitely saved me from a mistake. Thank you.
Old 07-30-2024, 01:21 PM   #24
54blackhornet
54blackhornet's Avatar
HO455 thanks for educating us who are not so experienced…
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 07-30-2024, 03:16 PM   #25
71CHEVYSHORTBED402
Nice education, appreciated. Sounds like two general types, one for leaf springs, one for coil springs. For 2wd anyway.
Tony
