Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > Welcome Area
Old 07-22-2024, 09:02 AM   #1
Jesse Vandiver
Jesse Vandiver's Avatar
New member 67 C10
Hey all I got this 67 c10 a couple months ago. This is my first one. In the past I’ve had a K10, a S10, and a Silverado. I’ve been going through and learning about it and sorting out (or getting sorted) a bunch of things. I don’t have any history on it. VIN says it’s a 67 from Flint with a 6 cylinder. The glove box door is long gone.
It’s got a ZZ6 with Holley EFI, a 700R4, and a 8.5” ten bolt with 3.73 posi.
So far I got the correct (Newport Engineering) switch for the windshield wipers and flipped the wiper linkage since it was backwards. Got a new transmission pan gasket (was leaking bad) and new flex plate put on (starter wasn’t shimmed correctly the ring gear was chewed up). Got the Flowmaster exhaust rerouted out the sides instead of under the bumper so I can get up and down my driveway. I fixed some binding linkage on the Lokar shifter and tightened a set screw in the linkage that was totally loose so I can put it in park now. Had to get it towed twice because of a faulty wire I found and fixed. I put some new audio in it and left the Custom auto sounds radio in the dash just to fill the holes.
Next I’m taking it in to find out why it’s leaking coolant and probably get all the old brake lines replaced. After that there’s some blemishes in the paint to get fixed and start thinking about a new bench seat.
Jesse Vandiver is offline   Reply With Quote
Old 07-23-2024, 12:02 AM   #2
68bowtie
68bowtie's Avatar
Re: New member 67 C10
Nice truck. Welcome to the club.
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Old 07-23-2024, 06:10 AM   #3
Getter-Done
Getter-Done's Avatar
Welcome to the Forum
Cool truck.
84 Chevy K-20
Old 07-23-2024, 01:32 PM   #4
loudchevy
loudchevy's Avatar
That is a clean starting point. Nice C10.
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 07-23-2024, 02:18 PM   #5
Shifty One
Shifty One's Avatar
Welcome and fine looking truck!
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 07-31-2024, 09:46 AM   #6
68Gold/white
Very Nice, Major congrats!!!
I'd like to see. more clearly how your panhard connects to the rear end.
My good friend adapted a 8.5 into his 66 C10. yours may be similar.
68Gold/white is offline   Reply With Quote
Old 07-31-2024, 11:50 AM   #7
Jesse Vandiver
Thank you! Here's a couple shots. Its connected on top of the passenger side c-notch.
Old 08-02-2024, 08:18 AM   #8
72BLAZERDUDE
72BLAZERDUDE's Avatar
Welcome
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 08-02-2024, 08:28 AM   #9
A1971Blazer
A1971Blazer's Avatar
Welcome...67s are the coolest...!
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
