Old 08-04-2024, 11:17 AM   #1
Peanut74
Help identifying my transmission
This one has me stumped big time.
The transmission that came in my '67 appears to be a TH350. HOWEVER, it has only two speeds. The trans pan has the angled corner notch and 13 bolts indicating that it's a TH350 which is a three speed. Thought maybe it a TH250 but that's also a three speed from what I found. I may at a loss as to what it is. Any help in identifying it would be greatly appreciated.
1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
Peanut74 is offline   Reply With Quote
Old 08-04-2024, 11:44 AM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Help identifying my transmission
Defective TH350 that fails to engage one of its three gear ratios?
Is there a transmission listed on the SPID?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 08-04-2024, 11:51 AM   #3
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Powerglide- 2 speed auto
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 08-04-2024, 12:18 PM   #4
Getter-Done
Getter-Done's Avatar
Here's a link with info.
Sounds like there issue with the transmission not shifting.
Link: https://www.chevyhardcore.com/tech-s...uminum%20units
84 Chevy K-20
Old 08-04-2024, 02:02 PM   #5
Peanut74
I went under the truck and shifted it manual and it is indeed a two speed. I went back underneath it looking for any markings on the transmission case. The only thing I found was 8T. There was no M33, M38 or M39 on it. Snapped a couple pictures hoping that would help.
Also, the guy I bought the truck from just had the transmission rebuilt.
Old 08-04-2024, 02:48 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I was not aware that a Powerglide was still used in some of these trucks. Does a Powerglide have the angled corner on the pan? Seems like I learn a bit more almost every day -- or learn how much I don't know.
Peanut, if you can talk with the shop that rebuilt the trans, they should be able to fill you in on all the details.
- Mike -
RIP El Jay
Old 08-04-2024, 03:00 PM   #7
Getter-Done
Maybe the guy that rebuilt it done a custom job.?
How long is that tailshaft?
That appears to be the T350 case.
There was a long and short tail shaft on the T350.
There was also a 12" tail shaft on some T350 cars.
The aluminum case powerglide had 14 bolts in the pan.
The Early Powerglide was Cast iron and IIRC it did not have a pan.
84 Chevy K-20
Old 08-04-2024, 03:04 PM   #8
SRU1436
Look at the pans, they are different.
SRU1436 is offline   Reply With Quote
Old 08-04-2024, 03:47 PM   #9
Steeveedee
Who Changed This?
Steeveedee's Avatar
Sure looks like a 350 pan. How many notches in the detents of the shift selector? Six (PRND2L) would mean a three forward speeds (THM) and five (PRNDL) would mean two forward speeds (PG).
In the two gears, how fast do you go at what RPM?
As an afterthought, does it shift on time? If the vacuum modulator is weak it can shift way late or not at all, and you might not be getting high gear.
~Steven
Simi Valley, CA
Old 08-04-2024, 07:30 PM   #10
Peanut74
The tail shaft is 9"-9.5" which falls in line with a TH350. I have disconnected the shift linkage and have five stops (P, R, N, D, L). The truck last time I drove around the house never shifted into drive. It just stayed in low.
Old 08-04-2024, 08:57 PM   #11
hugger6933
All the Glides I used to have [drag racing application] had fins on the case [or ribs maybe] the went from the sides across the top. this does not look like any power glide I ever saw. Jim
hugger6933 is offline   Reply With Quote
Old 08-04-2024, 10:06 PM   #12
geezer#99
geezer#99's Avatar
Turbo 350 had the vacuum modulator on the passenger side at the back like in the pic.
Powerglide had the modulator on the drivers side at the back.
You got a t-350
Old 08-05-2024, 02:09 AM   #13
Rust_never_sleeps
Rust_never_sleeps's Avatar
I've heard of dirt track racers building 2 speed TH350's, but that seems really far-fetched for a truck tranny
1970 C10 Custom longbed 350/350
Rust_never_sleeps is offline   Reply With Quote
Old 08-05-2024, 09:52 PM   #14
Peanut74
Well I crawled under the truck with phone in hand and confirmed it is indeed a TH350 like everyone thought. That only leaves the question of why do I have only 2 speeds instead of 3.
Old 08-05-2024, 10:24 PM   #15
Stocker
20' Daredevil (Ret)
Stocker's Avatar
That's progress. Have you been able to determine which two gears you have, and which gear is missing?
- Mike -
RIP El Jay
Old 08-05-2024, 10:32 PM   #16
Getter-Done
This is what makes me think it is Customized.
The arrows pointing to the Tailstock / Silicone.
And the electrical Plug. ?
84 Chevy K-20
Old 08-06-2024, 11:36 PM   #17
Peanut74
Getter-Done the electrical connection is for the digital speedometer. The transmission was rebuilt just before I bought it. So that would explain the silicon on the tailshaft.
If anyone has a TH350 laying around could you manually shift it and tell me how many stops it has.
Old 08-07-2024, 12:35 AM   #18
RustyPile
RustyPile's Avatar
Let's get the nomenclature correct, it's "detents", not "stops".. Including PARK, mine has six...
RustyPile is offline   Reply With Quote
Old 08-07-2024, 08:03 PM   #19
WorkinLonghorn
WorkinLonghorn's Avatar
In post #10 you said "The truck last time I drove around the house never shifted into drive. It just stayed in low."
I think you need to get it out on the road to do a proper test drive. If it still won't shift out of low, I would check the governor. They get stuck. I've seen it happen a lot. Very easy fix but don't take it to AAMCO , just do it yourself in a few minutes. -BA
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 08-07-2024, 09:49 PM   #20
Ol Blue K20
Originally Posted by workinlonghorn View Post
in post #10 you said "the truck last time i drove around the house never shifted into drive. It just stayed in low."
i think you need to get it out on the road to do a proper test drive. If it still won't shift out of low, i would check the governor. They get stuck. I've seen it happen a lot. Very easy fix but don't take it to aamco , just do it yourself in a few minutes. -ba
x2....
Dale
Old 08-07-2024, 10:13 PM   #21
Lokin4AReason
Lokin4AReason's Avatar
looks like a turbo 350 w a long tail shaft
only other way to make sure , is to count bolt(s) on the trans pan and the shape of it
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 08-07-2024, 11:01 PM   #22
Peanut74
Son inlaw got a K5 Blazer with a TH350. He sent me a picture of the column shifter indicator and it matches what I have. So tomorrow I will go over and see how many stops/detents his has. I will probably make a pattern of all the shift locations to compare to mine.
Old 08-07-2024, 11:46 PM   #23
Steeveedee
Who Changed This?
Steeveedee's Avatar
As mentioned above there are six notches for a 3 forward speeds transmission.
Park
Reverse
Neutral
Drive
Second
First
~Steven
Simi Valley, CA
Old 08-09-2024, 10:41 AM   #24
leddzepp
Moderator
leddzepp's Avatar
Originally Posted by ol blue k20 View Post
x2....
x3
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 08-09-2024, 11:26 AM   #25
PbFut
Only 5 detent positions seems odd. You are counting with linkage disconnected. Assuming you have six, have you verified vacuum at the modulator? A damaged or disconnected vac line will disable 3rd gear shift on my truck. Also a poorly set kickdown cable could be locking out 3rd. If you only have 5 shift positions you have something amiss internally.
PbFut is online now   Reply With Quote
