Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 08-04-2024, 09:18 PM   #1
BRL
BRL's Avatar
Remote Batt. Disconnect
Anybody tried one of these yet?
Can't seem to find any posts but that doesn't mean there aren't any out here someplace.
I would like to see them be built stronger like in the USA for example, and at first the thing was giving me trouble and I was about to remove it, but that's when I discovered I hadn't fully tightened the screws down yet.
So far so good after a few months.
BRL is offline   Reply With Quote
Old 08-04-2024, 09:36 PM   #2
dmjlambert
dmjlambert's Avatar
Re: Remote Batt. Disconnect
That looks like a lot of wires, and a lot of stuff connected to other stuff. Many connections, many bolts. I'm curious. What does all that stuff accomplish?
Old 08-04-2024, 10:57 PM   #3
RustyPile
RustyPile's Avatar
Maybe something like this. Zoom in for a better look.
RustyPile is offline   Reply With Quote
Old 08-04-2024, 11:17 PM   #4
BRL
BRL's Avatar
Oh it gets even better!
I don't remember what half that stuff does after 30 years of ownership and I suppose I could have come up with a fuse block at some point, but everything works great so if it ain't broke I ain't fixin' it!
Old 08-04-2024, 11:23 PM   #5
Getter-Done
Getter-Done's Avatar
I Like it.
84 Chevy K-20
Old 08-04-2024, 11:34 PM   #6
dmjlambert
dmjlambert's Avatar
All I can think of to say is Gee Willikers.
Old 08-05-2024, 05:10 AM   #7
RustyPile
RustyPile's Avatar
No, and there's a reason why...
Old 08-05-2024, 06:43 AM   #8
franken
Remote battery disconnect issue while having a local nightmare and unwilling to fix it. Ok, you're fine.
Old 08-05-2024, 07:20 AM   #9
BRL
BRL's Avatar
There's nothing to fix, everything on that truck works just fine, and if the dang remote disconnect unit quits, all I have to do is remove the negative ground cable clamp from that unit and plug it back directly onto the negative battery post.
A simple one or two minute job tops.
...more like less than 30 seconds, I have the tool boxes bolted in right there under the hood beside it.
Old 08-05-2024, 09:16 AM   #10
GOPAPA
GOPAPA's Avatar
I have one right now to install in my truck ,, it has a clicker to go on my key chain and I want it because I unhook the battery at home or out some where almost each time I drive the truck when I am aways in distance ,, I figure it is another thing to have along with my locking doors to make it a bit harder to theft . I am going to add longer wires and mount it on the side wall next to the battery .. I like it ..
When you learn a thing a day you store up smart.
GOPAPA is offline   Reply With Quote
Old 08-05-2024, 09:58 AM   #11
BRL
BRL's Avatar
Yea it just amazes me that the thing has held up as well as it has already, I'm used to believing that a car battery disconnect switch should be seriously built like a massive breaker switch in a power substation or something, but only time will tell if it will hold up or not.
I do like the concept though.
Old 08-09-2024, 10:09 PM   #12
BRL
BRL's Avatar
Smile Re: Remote Batt. Disconnect
Originally Posted by Getter-Done View Post
I Like it.
Getter-Done you're my new bestest buddy on this forum, you seem to understand me
As for the rest of you, Amazon just delivered a bus bar distribution block and I'll try to clean up this mess even though I'm immune to peer pressure.
Old 08-09-2024, 11:14 PM   #13
dmjlambert
dmjlambert's Avatar
That bus bar distribution block sure accommodates lots of wires, and a lot of stuff connected to other stuff. Many connections, many screws. Gee Willikers!
Old 08-10-2024, 12:05 AM   #14
BRL
BRL's Avatar
yea, well, I need to supply power to the shower hot water heater and the SETI radar satellite dish.
Old 08-16-2024, 12:29 AM   #15
BRL
BRL's Avatar
OK I cleaned up the mess somewhat.
Now it looks so good I'm thinking of removing the hood and driving around town to show it off.
The reason I bolted in toolboxes under the hood is because I have stereo amplifiers under both bucket seats, that's where all those wires were headed.
You install a powerful stereo system in a tiny truck cab and it'll blow your head off!
I was young once.
Old 09-02-2024, 12:25 AM   #16
BRL
BRL's Avatar
Apparently I have the same nightmare going on under the dash.
It all works.
So I was thinking of putting a kill switch under the dash and decided that drilling a hole in that plate shown would work, so I removed the 4 bolts that attaches it.
Nope, decided on a different location so I went to reinstall the plate...
Somehow the two screw holes towards the driver's seat became misaligned and its a darn good thing the bolts come to a point because that task wore me out!
Had to take a nap afterwards, I think I had an easier time bolting in the motor.
Old 09-02-2024, 12:33 AM   #17
Getter-Done
They make a under dash creeper now.
Link: https://www.amazon.com/Powerbuilt-Cr...0BHMHT2V9?th=1
84 Chevy K-20
Old 09-02-2024, 12:38 AM   #18
dmjlambert
dmjlambert's Avatar
I had the same experience with that plate, the 4 bolt holes did not align worth a damn. I could not believe I removed the plate with such ease, and it was hell to put back on. I had it off before and don't remember it being difficult to put back on. I would imagine there is some clever trick to it we don't know.
Old 09-02-2024, 01:49 AM   #19
BRL
BRL's Avatar
Yea I couldn't line up those holes, even using a Phillips screwdriver shank as a crowbar in an attempt to line up the holes, nothing budged.
That plate assy. did have a cluch pedal at one time but I removed it and trashed it (oops!) if that makes it any difference, but the whole experience was just ridiculous.
At least I know it wasn't just my experience alone, thanks for that.
That under dash creeper looks a lot like a stretcher, I could have used a stretcher when I was done.
Old 09-02-2024, 02:37 AM   #20
franken
A battery disconnect is usually thought of as completely disconnecting the battery from the vehicle. Disconnecting just the low current stuff can be done with a relay and a bus much like the one posted. Squares had a nice one if there's a scrapyard around.
Old 09-03-2024, 08:33 PM   #21
Tom
driving is in my blood
Tom's Avatar
I can see remotely disconnecting the battery, but once that's done you'd have to manually reconnect it, since there is no power to make it auto. So I don't see the point.
I put a boat dual battery switch in my truck when I went dual batteries. I can turn both batt's off with the dial.
Old 09-04-2024, 01:03 AM   #22
BRL
BRL's Avatar
Originally Posted by Tom View Post
...but once that's done you'd have to manually reconnect it, since there is no power to make it auto. So I don't see the point...
Actually that switch is still grounded to the battery negative post directly so the remote control still works to shut everything else's ground off.
Also I still have the battery tender negitive wire connected directly to the battery post so I can still maintain a full charge even with the disconnect activated.
Yea I know it sounds strange and hard to explain but the unit is still working as intended.
Old 09-04-2024, 05:08 PM   #23
truckin 79
Why not just go with the simple route and use this, I did simple and easy. I use a large carabiner to attach to key ring when not on the truck
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 09-04-2024, 10:48 PM   #24
BRL
BRL's Avatar
Or just use this.
Step out of the truck, walk away, press a button and the power is shut off.
No need to pop the hood in the middle of a parking lot every time you want to disable or enable the electric.
Old 09-04-2024, 10:59 PM   #25
Getter-Done
Or just use this.
A Great Member that use to frequent this forum used these on his Golf carts.
I have yet to purchase one.
Most of these have Great Reviews.
84 Chevy K-20
