Old 08-16-2024, 04:41 PM   #1
72BLAZERDUDE
72BLAZERDUDE's Avatar
Welding vs Bolt In
My C notch is all bolted in. Any advantages to welding it in after it it bolted in ?
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 08-17-2024, 07:49 AM   #2
kwmech
Re: Welding vs Bolt In
Yes. Over time the bolts will stretch and loosen up a bit with frame flex
Old 08-17-2024, 08:47 AM   #3
Getter-Done
Getter-Done's Avatar
If you don't do a lot of towing and
Maybe plan on lowering it more in the near future,
I would leave it.
If you like the Stance and do any Heavy Towing,
I would defiantly weld it and take the bolts out
and use a copper spoon as a backer and weld the bolt holes up.
Here's an Old Thread: https://67-72chevytrucks.com/vboard/...d.php?t=357911
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 08-17-2024, 04:04 PM   #4
LS short box
No reason not to do both. Kind of depends on you welding skills.
On my 68 C10 with a C notch I bought the frame with the weld in C notch already installed. Not sure of the previous owners welding skills I added bolts and boxed the inside of the frame with 3/16" steel plate.
Old 08-19-2024, 12:45 PM   #5
72BLAZERDUDE
Boxing the frame is a great idea. Give me a chance to use the brand new plasma cutter and tig welder that I just bought. I will just leave the bolts weld it up and box the frame. Firm believer in overkill.
Old 08-21-2024, 10:36 AM   #6
SCOTI
SCOTI's Avatar
Welds & bolts; especially if not a certified welder.
As for boxing, it will be better boxed but still won't be as strong as stock since the C-channels strength is in its height.
https://67-72chevytrucks.com/vboard/...d.php?t=457037
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
