Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 08-17-2024, 04:12 PM   #1
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Broken tap removal
Anybody got a trick to removing a broken 3/8 tap from a hole? Buddy was cleaning up threads in engine block and somehow snapped the tap off.
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 08-17-2024, 04:23 PM   #2
richard2717
Re: Broken tap removal
I never knew these existed till now
https://www.amazon.com/Screw-Extract..._source=1&th=1
Members I have met.
Old 08-17-2024, 04:46 PM   #3
dmjlambert
dmjlambert's Avatar
I'll have to bookmark that, it looks fantastic. It would be most difficult to drill a tap for an easy out. But those look like just the right thing. Let us know how it works out.
Old 08-17-2024, 05:40 PM   #4
Boog
laying low
Boog's Avatar
Dang, I could have used that in 1974.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 08-17-2024, 05:55 PM   #5
Getter-Done
Getter-Done's Avatar
If that set works, you will be money ahead.
Here is the set like that I am used to.
Link: https://www.amazon.com/Walton-Tools-.../dp/B0006NGGCM
You can also make a chisel out of an old tap with a Cupped shape on the inside.
I can send a Picture if you're interested in that idea.
Carbide is the best thing for get HSS taps out.
But carbide prefers a Ridgid setup or it with chip and break.
Dremel tool with carbide Deburring tool works also especially if it cannot be setup in a milling machine.
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 08-17-2024, 07:57 PM   #6
TKCR
TKCR's Avatar
That’s the kind I’m used to using also. When I worked in the repair dept at the Honda Manufacturing plant, we got broken bolts and broken taps all the time. And these are what we used.
Old 08-17-2024, 10:01 PM   #7
mongocanfly
mongocanfly's Avatar
If that doesn't work it may need to go to a machine shop and be edm removed...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-17-2024, 11:28 PM   #8
Getter-Done
This is so Ironic to me.
Just this Last Friday I had a Critical job,
This stuff needs to be Approached with Kitten gloves (Most of the Time).
Thursday evening, I got a call from my (Direct boss) manager.
We worked together to get this fixed.
I put a Keen Sert in a hydraulic Block that has
No replacement part #
This was for a Major Car manufacturing Facility.
It was for a 5/8 x11 and was taped to 7/8 x 14 for the keen sert.
84 Chevy K-20
Old 08-18-2024, 02:13 AM   #9
pjmoreland
pjmoreland's Avatar
I've removed broken off exhaust manifold bolts by welding a nut to them. Maybe this technique would work with a broken tap.
pjmoreland is offline   Reply With Quote
Old 08-18-2024, 01:52 PM   #10
richard2717
I am not sure what he used but he did text me a picture saying he was able to get it out. I will ask him when I see him next what he did.
Members I have met.
Old 08-19-2024, 11:11 AM   #11
67C10Step
67C10Step's Avatar
A broken tap would certainly test someone's religion. That and a broken drill in a hole are not the things you want in the middle of an activity.
The old nut welding trick has saved many a person, including myself. Back when I was just trying to get mine running this was the result of trying to change out the thermostat.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 08-19-2024, 04:02 PM   #12
mongocanfly
The weld-a-nut trick works good on bolts...not so much on taps and driĺls..their hardness makes them crystallize if you weld on the hardened parts
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-19-2024, 05:24 PM   #13
richard2717
So I talked with him again and he used some gun oil squirted in then used a punch to tap it out. He said it worked pretty good like the oil was helping float it out
Members I have met.
Old 08-19-2024, 07:44 PM   #14
Boog
laying low
Boog's Avatar
On an old truck of mine a grease zerk was snapped off in the king pin area of the axle. So I tapped an eaze out in there and promptly snapped it off. Never did get that out...
Boog
primer is finer
Old 08-19-2024, 11:10 PM   #15
Getter-Done
I think I bought that truck . Just Kidding
84 Chevy K-20
