Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-18-2024, 06:47 PM   #1
karlbenz
flat tow wiring question
I'm wanting to flat tow my 64 GMC. Will it hurt anything to splice into the wires at the firewall? All the kits I see are running new wires back. No, I'm not buying a kit. Was looking at them for reference
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
karlbenz is offline   Reply With Quote
Old 08-18-2024, 10:01 PM   #2
RustyPile
RustyPile's Avatar
Re: flat tow wiring question
I wouldn't recommend "splicing into" the wiring harness.. I suggest you buy a trailer wiring kit that includes the lights. Fasten the harness along the side of the truck and fasten (clamp, bolt, zip tie) the lights to the rear bumper.. Plug the tow harness into a trailer receptacle on the rear of the towing vehicle, just as you would if towing a trailer.
I'll add this as an after-thought. Disconnect the driveshaft from the differential or you'll wind up with a damaged transmission.
RustyPile is offline   Reply With Quote
Old 08-18-2024, 10:19 PM   #3
Getter-Done
Getter-Done's Avatar
Harbor Freight Tow light kit $35.oo + tax
Link: https://www.harborfreight.com/automo...kit-64282.html
84 Chevy K-20
Old 08-18-2024, 11:11 PM   #4
mongocanfly
mongocanfly's Avatar
And if you don't mind spending more, they also have wireless tow lights
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-18-2024, 11:15 PM   #5
Getter-Done
I have seen Those.
84 Chevy K-20
Old 08-19-2024, 10:33 AM   #6
karlbenz
I’d be worried about losing them. Like the idea though
1965 Chevy C60
Old 08-19-2024, 08:36 PM   #7
bhap
bhap's Avatar
There is a flat 3wire harness that exits the cab near the trans hump that runs the rear turn signals and running lights. You could pull the plug and connect your “trailer lights” to the rear from there.
bhap is offline   Reply With Quote
Old 08-23-2024, 11:51 PM   #8
truckster
truckster's Avatar
When I rewired my Blazer I set it up for flat towing. I have a flat-4 connector that sits on my radiator support. I soldered it in where the wiring harness runs down the firewall to the rear.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
