Old 08-19-2024, 06:12 PM   #1
JDarby
Active Member
Cruise Control Options
What is the best type cruise control if your donor did not come with it?
My donor is a 2003 Express Van with a 6.0LS and an auto.
Thanks in advance!
1955.1 GMC 100 RestOMod
1972 T120RV
1967 C200 Trail 90
2014 TRD Quad CAB
JDarby is offline   Reply With Quote
Old 08-20-2024, 10:04 AM   #2
1project2many
Re: Cruise Control Options
I think the answer will depend on how much work you want to do to integrate cruise with the ECM and wiring. There are aftermarket systems that will work independently of the OE computer. Those might be easiest option. Cruise units from some 90-94 ish GM vehicles can operate somewhat independently. Those units will use the OE speed and brake (and clutch pedal if equipped) signals. Other circuits include ignition power, ground, and the wires from the cruise switch.
1project2many is offline   Reply With Quote
Old 08-20-2024, 10:49 AM   #3
Modsqaud69
You might want to get in touch with Brendan over at lt1swap.com. He has years of experience with ls programming and wiring harness modifications. He might be able to steer you in the right direction. Rob
Modsqaud69 is offline   Reply With Quote
Old 08-20-2024, 01:38 PM   #4
leegreen
That van would have had DBC throttle body. You'll need a servo motor off something.
this thread is probably a good starting point
https://ls1tech.com/forums/conversio...ispreloading=1
If you are OEM manifold, computer and PCM, going to the wrecker and getting the cruise parts off any DBC LS truck is probably a good starting point. Get connectors too.
Swapping to a DBW TB might be just about as easy except maybe for your gas pedal choice.
leegreen is offline   Reply With Quote
Old 08-22-2024, 09:51 PM   #5
mick53
I'm using Dakota Digital HDX gauges with GPS speedo and cruise. They also blue teeth all the gauges to your phone
mick53 is offline   Reply With Quote
Old 08-26-2024, 11:47 AM   #6
JDarby
Active Member
Thanks LeeGreen I will dig into that info!
When cruising for long distance's it's a must anymore these days to have cruise control!
1972 T120RV
1967 C200 Trail 90
2014 TRD Quad CAB
