Old 08-22-2024, 07:21 PM   #1
vintovka
vintovka's Avatar
Rewiring GM tilt column to flash high beams
I have a 1954 Chevy Pickup on a 1984 GMC sierra classic K10 chassis. It still has the GM tilt column with the full function side stalks and the original multi connector at the end. I need guidance on how to make the high beams flash via the stalk. Is there any easy way to do this?
vintovka is offline   Reply With Quote
Old 08-23-2024, 11:04 AM   #2
Dead Parrot
Re: Rewiring GM tilt column to flash high beams
On my 84 CUCV with a non-tilt column, I went the other way. I wanted the floor switch vs the column stalk. Also, the column switch was no-op. Discovered that the 3 wire connector for the beam switch was the exact same pattern as the floor mount switch. Except for wire length, it would have been as simple as plugging the floor switch in. Don't know if GM was using the 3 wire floor switch in 54 but it might as simple as pulling the floor switch wire over to the base of the column and plugging it in to the existing column switch.
Dead Parrot is offline   Reply With Quote
Old 08-23-2024, 11:35 AM   #3
vintovka
vintovka's Avatar
Thanks but all of the 54 body wiring is long gone. I stupidity reused all of the 84 gmc wiring including the fuse box -- big mistake don't do it!!. All i have to work with is the remaining wiring from column and box connected to the original 54 headlight switch. Wonder if theres a wiring diagram that would show how to integrate the column stalk to the switch?????
Old 08-23-2024, 08:57 PM   #4
hatzie
Moderator
hatzie's Avatar
The 1984 GM Light Truck wiring diagrams in the manual page should be a good place to start.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
