Old 05-07-2024, 09:05 AM   #301
raggedjim
raggedjim's Avatar
Re: The Doc & Kim 69 build
Glad to see you are back on it!
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 05-07-2024, 10:05 PM   #302
zicc1835
zicc1835's Avatar
Rg
thanks Roger the better weather here in the East definitely is a motivator
zicc1835 is offline   Reply With Quote
Old 05-07-2024, 10:43 PM   #303
zicc1835
zicc1835's Avatar
well these stands work with a hole drilled in the engine cradle crossmember, that's all done ....next cab off needs the fire wall and bottom blasted ....while that's out we will get the drive shafts I have out and see if we need something fabed .. I will also finish plumbing the brake lines
Old 05-15-2024, 05:09 PM   #304
hewittca
hewittca's Avatar
I like this one! Why did you mothball this one to build the other?
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 05-17-2024, 10:11 PM   #305
zicc1835
zicc1835's Avatar
I new I could finish the stepside quicker and was frankly tired of it lookin the way it did Im gonna take my time on this one and with each one this being my 3rd complete rebuild I think you learn more and more of what you want the outcome to be as long as we don't keep "going in a different direction"
I have already argued with myself over going the LS direction. I won the argument with logic... I picked up the remaned SB 350 and 2 700R4s for real short money some years ago and had the tranny rebuilt already 2 years ago ....I have thought about swapping out the front engine cradle cross member with a coil over unit to replace the tubular A arms etc. but logic won out I plan on spending the $$$s on paint and interior ...thanks for stopping by on this one Im looking forward to getting back at it
Old 08-17-2024, 06:25 PM   #306
zicc1835
zicc1835's Avatar
well finally some real progress cab off and down to my other yard for media blast underside of floor had surface rust if you look close as I lifted from frame you can see rust .....this truck was purchased by the PO. Doc .. from the great dry state of Arizona and was in great shape other wise
Old 08-19-2024, 10:23 AM   #307
loudchevy
loudchevy's Avatar
That cab looks great!
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 08-19-2024, 10:57 AM   #308
raggedjim
raggedjim's Avatar
Hard to find a cab like that in my area, I'd be time and money ahead if I could!
Rg
Roger
'70 GMC Jimmy 2wd
Old 08-24-2024, 09:33 PM   #309
zicc1835
zicc1835's Avatar
I purchased a Flowmaster stainless exhaust kit back in early 2019 ( post 208 ) I half installed it and needed to do some custom work to hook the shorty headers to it all ...short story can't find a shop with a mandrill bender to bend so my welder friend came by today and we put a plan together to start to fab from the headers to the H pipe and realized the trans crossmember will interfere luckily I found this on Speedway will be my third Trans CM for this build but we can clear the new Trans CM and head back through the trailing arm CM ....stay tuned
Old 08-26-2024, 09:42 AM   #310
loudchevy
loudchevy's Avatar
I just bought and installed this Speedway xmember. It has tons of adjustability built into it. The only down side I can see so far is the speedo cable connection on the tail of the transmission might not clear the edge of the xmember. I haven't installed the cable yet in mine, but it's really close.
Scott
2003 Tahoe Stock
Old 08-26-2024, 03:54 PM   #311
zicc1835
zicc1835's Avatar
great info im thinking it will solve my exhausting problem! ill try the speedo cable while the cabs off the frame
Old 08-31-2024, 10:12 PM   #312
zicc1835
zicc1835's Avatar
Im going to send this over to Scott thanks for your advice and info
got the CM mocked up today I had a old speedo cable and every thing looks fine lined up with cable on the 700r4. Im going to try and get all cables E brake etc I had routed and hooked up as much as I can before I put the cab back on...also had the drive shaft shortened and balanced a few inches seeing I set the motor back with the newer mounts I have a little less than two of my fat fingers between the distributor and the fire wall instead four and my thumb
Old 09-01-2024, 05:23 AM   #313
jaros44sr
jaros44sr's Avatar
Jesse, if you ever need machining done, I have a bridge port,great tool for clearance holes
Glad to help out a friend anytime
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-01-2024, 08:34 PM   #314
zicc1835
zicc1835's Avatar
thank you Jim ,ill be sure to take you up on that if I do
Old 09-07-2024, 09:24 PM   #315
zicc1835
zicc1835's Avatar
playing with the exhaust ...waiting on my welder I ordered all kinds of exhaust parts including stainless doubled braided flex pipe see if I can do without the welder..... and I couldn't help myself said I wasn't going to add QTP electric cut outs but order those also will see how it all lines up
Old 09-07-2024, 09:37 PM   #316
zicc1835
zicc1835's Avatar
also got my detent cable for kick down on 700R4 and Im looking into TCC lock up switch. I ran all the stainless brake lines before I mothballed this 2 years ago so I began mocking up the brake booster I had sitting on the shelf ...second hand purchased on the board long ago chrome with chrome master need to do some fabing on the push rod / brake peddle hook up more parts on the way for that ....pictures if it comes together later
BETTER WEATHER here to work in
Old 09-09-2024, 09:20 AM   #317
loudchevy
loudchevy's Avatar
Those exhaust pipes got tucked up there very nicely!
Scott
2003 Tahoe Stock
Old 09-09-2024, 02:20 PM   #318
zicc1835
zicc1835's Avatar
Old 09-11-2024, 08:59 PM   #319
zicc1835
zicc1835's Avatar
look what was delivered today......
Old 09-11-2024, 09:04 PM   #320
zicc1835
zicc1835's Avatar
my grandson said .....Lets go Pop-Pop I want a ride
Old 09-12-2024, 10:14 PM   #321
zicc1835
zicc1835's Avatar
so I got this all mocked up cut outs and all... hoping my double braided stainless flex pipes holds up. I can't find a mandrel bender local and my welder although very good was shying from fabing the transition from the headers ...so I did the heavy lifting for him and now he has a whole lot of butt welding to do where I put the temp lap joint clamps ...will see
Old 09-13-2024, 08:13 AM   #322
hewittca
hewittca's Avatar
Been a while since I checked in. Everything's looking great! Gotta love sharing the truck with your grandson!
I was looking at your trailing arm crossmember in detail because that is one thing on my truck that I feel still needs work, especially with the two piece driveshaft. On your truck, with the engine set back and the 700r4 you would have a comically short first driveshaft if you did a two piece!
Old 09-15-2024, 10:20 PM   #323
zicc1835
zicc1835's Avatar
Funny you sat that I had a 72 LWB with original 402 PO installed a 700r4 with a single what I thought was a VERY LONG single shaft
Old 09-22-2024, 08:49 PM   #324
zicc1835
zicc1835's Avatar
my welder showed up today and we finished up piecing the exhaust together im pleased although I have a lot of leftover parts 2.5 H pipe setups and Lap clamps and assorted pipes I guess ill put it on the shelf.... because you know why next get the motor/ trans buttoned up to get it started
Old 09-24-2024, 07:35 PM   #325
zicc1835
zicc1835's Avatar
so I spent some time last night tightening the header bolts I clocked the MINI starter I clocked it way from the header and closer to the block and reinstalled it. I put a temp positive battery and ground cable hooked up a starter button to the starter purchased a new battery today and was able to crank the motor ......progess I have to make sure when I fire it off the trans (700r4)cooling lines are tied together and detent cable is in. Ill only fire it off for a moment until I hook the radiator up or I might get some patience and wait until I can run it with temporary oil pressure and temp gauges hooked up.. that's a better plan I need to convince myself of that ... we will see
