![]() Join Date: Jul 2000
Re: Borg Warner super t10 in place of 3 speed
About the gear ratios, I found the info below on the 3-speeds. 0-3 are the number of grooves on the input shaft. I would guess your six-cyl trans is 3.11 or 3.50, assuming it's original.
.................................1st 2nd 3rd Saginaw 3-speed – 1 2.54 1.50 1.00 Saginaw 3-speed – 0 2.85 1.68 1.00 Saginaw 3-speed – 2 3.11 1.84 1.00 Saginaw 3-speed – 3 3.50 1.89 1.00 So compare total torque multiplication (1st gear ratio X rear axle ratio) to see which one will work best.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
