Old 08-31-2024, 06:31 PM   #1
Dude68
Active Member
1968 help
I need a head for my 1968 C10, trying to stay as close to original as I can with this tuck tat belonged to my grandpa. Casting is 3921968.
250 I6, three on the tree.
Thanks,
Joey
Joey
Dude68 is offline   Reply With Quote
Old 08-31-2024, 09:40 PM   #2
Dude68
Active Member
Re: 1968 help
Also, what are my options for cylinder heads if I cannot find a 3895052 or 3927763?
Joey
Old 08-31-2024, 10:12 PM   #3
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: 1968 help
All the L6 series engines use the same head,
Just don't get a later head with integrated manifold.
Old 09-01-2024, 10:05 PM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: 1968 help
OP, what makes you think that the head you have can't just have a valve job?
~Steven
Simi Valley, CA
Old 09-01-2024, 10:54 PM   #5
'68OrangeSunshine
Re: 1968 help
Steveedee makes a good point. If you do have your head in for a valve job, ask the machinist to use Stellite valve seats. The originals were made to run with TetraEthylLead additive in the gas. That stuff's been illegal in Cal for 25 years.
Stellites are better equipped to handle the goofy gas we get nowdays.
If you do find another L6 Head, it will need a valve job anyway, if not other machining operations.
Old 09-02-2024, 09:48 AM   #6
Dude68
Active Member
Re: 1968 help
I took the head in and it had a giant crack and it could not be fixed. I kept the parts and discarded the head. My uncle found a head that is for an earlier 261 engine. My uncle thought it would fit. It has casting number of 3836850. I know there were 2 heads available for a 67-72 250, and those 2 heads also for a 230 & 292. Gonna pull this motor and see if it’s ok. It was running fine when I broke the timing gear. I discovered the head was cracked replacing the timing gear. When I had to pull everything to replace the timing gea, I pulled the head t get a valve job. The shop found the crack and I bought a new house about (1992) that time. I had to tow the truck to a friends house because I was not allowed to park vehicles on the street. Then my parents moved to the lake and built a shop, so Dad and I put it son a trailer and brought it to his shop in 2011. Did a little work and quit, just now getting back into it.
Joey
Old 09-02-2024, 10:35 AM   #7
Sheepdip
Sheepdip's Avatar
Re: 1968 help
These guys have done some pretty amazing rescues....
https://www.locknstitch.com/index.html
Sheepdip is offline   Reply With Quote
Old 09-02-2024, 02:19 PM   #8
'68OrangeSunshine
Re: 1968 help
You might as well cast around for another complete L6 -- 250 or 292.
Old 09-03-2024, 02:07 PM   #9
70STOVEBOLT
70STOVEBOLT's Avatar
Re: 1968 help
I have a 250 that came out of my '70. I don't know the mileage on it, but the head is good. Shipping would be a killer from Indiana to Arkansas though.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 09-03-2024, 02:15 PM   #10
bry593
Re: 1968 help
Originally Posted by '68OrangeSunshine View Post
I'm the same way with weed-eating my lawn....
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs
bry593 is offline   Reply With Quote
