Old 08-14-2024, 08:31 PM   #226
62c30
Re: 65 Fairlane pro-touring build
Originally Posted by Vic1947 View Post
Began scuffing the street side of the rear wheel wells and then applied a couple of coats of 3M rubberized undercoat. I did some rudimentary body work over the pie cuts before priming with epoxy but was still pleased to see how much evil the undercoat hides.
Which 3m undercoat did you use? I've seen several different ones. I was going to use raptor liner on some inner fenders but I'm thinking about undercoat instead.
62c30 is offline   Reply With Quote
Old 08-15-2024, 10:54 AM   #227
Vic1947
Vic1947's Avatar
Originally Posted by jaros44sr View Post
Your metal skills are impressive. Wish I had a bead roller, or you were my neighbor
I agree - it's always great to have a like-minded neighbor. I bought my "Low Buck Tools" bead roller years ago and never regretted the purchase. Since then, I've modified it with a HF winch, so I don't have to ask Kathy to be my helper. It's a very handy tool for all sorts of metal shaping.
I usually use the 3M 08964 Body Schutz, but it requires a special applicator gun and throwaway plastic tube. I ran across a deal for the 03584-aerosol version and decided to give it a try. I think the Body Schutz goes on thicker and is more durable, but neither product is as tough as Raptor or other bed liners. My goal was more cosmetic than durability, so the aerosol works okay in that regard.
Victor
57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown
Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas
Vic1947 is offline   Reply With Quote
Old Yesterday, 05:41 PM   #228
Vic1947
Vic1947's Avatar
The floor pan is finally assembled with SS rivets and 3M panel adhesive. The trans tunnel is held in place for the time being with clecos. I'm trying to decide whether to make it removeable. If I don't, Murphy's Law will make me regret it. I put all the rear suspension back in and set it up at ride height so I could measure the tire/wheel clearances. Looks like I'll be able to fit a 315/40-18 tire on an 11" rim and have plenty of room. Seam sealer is going on where panel assembly is complete.
Victor
Old Yesterday, 06:26 PM   #229
62c30
Looks damn good!
Old Today, 09:16 AM   #230
KevinK7
KevinK7's Avatar
Looks amazing, ...you have a lot of hours into that.
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 )
'68 C10 50th
KevinK7 is offline   Reply With Quote
Old Today, 09:50 AM   #231
SCOTI
SCOTI's Avatar
Sheetmetal efforts are on point. If there's a way to have the tunnel as an easy access point for service, it's not a bad idea. But not sure how much impact that has on a clean interior design to aid that accessibility (?).
315/40-18 is TALL @ ~28" for a Pro-Touring type of build.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
ford, restomod, t56
