Old 03-24-2024, 04:57 PM   #76
SpudWrench
SpudWrench's Avatar
Re: Father/Son/Friend 63 C10 Build
Lots of great work here. Like the exhaust. Gives me a goal on how I will have mine routed
"Just do it! Dont let your dreams be dreams"
-Shia LaBeouf
SpudWrench is offline   Reply With Quote
Old 03-25-2024, 12:08 PM   #77
cla5675
Thanks, Spud. Good luck with your build.
cla5675 is offline   Reply With Quote
Old 03-29-2024, 08:47 PM   #78
cla5675
Got the bed and hood in place for final mock up. So far so good. A few more items to fabricate in the cab then time for body work and some paint.
Old 08-10-2024, 11:31 PM   #79
cla5675
Got the firewall done and first round of epoxy on the cab interior.
Old 08-11-2024, 03:07 AM   #80
Braunschweiger
You are doing a great job and don't let setbacks discourage you,
it will be a great truck.
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 08-11-2024, 02:50 PM   #81
cla5675
Thanks!
Old 08-18-2024, 08:46 PM   #82
cla5675
Got a little more filler work done on the interior this week.
Old 09-03-2024, 10:13 PM   #83
cla5675
Interior is ready for color and sound deadener.
Old 09-06-2024, 08:49 PM   #84
cla5675
Did spray out test of the flat gray single stage. Looks good. Gonna paint the rest of the interior and inner side of the doors this week.
Old 09-09-2024, 10:54 AM   #85
rbruno68
When you sprayed your interior, it looks like epoxy went on all surfaces. After that, did you spray the floor/ front of cab under the dash and the dash/back of cab/roof in different paints? Meaning, did you spray something different on areas that would not be seen or covered vs areas that you will see? Hope that question makes sense.
rbruno68 is offline   Reply With Quote
Old 09-09-2024, 10:21 PM   #86
cla5675
Good eye, bruno. We used SPI gray epoxy "from the dash up" on the areas that will get single stage paint and U-Pol Raptor epoxy "from the dash down" which will all be covered in Dynamat or a similar sound deadener.
Only reason for the two primers is U-Pol takes less time for substrate prep and my buddy wanted to try out the Raptor epoxy. Used the good stuff in areas that will be painted.
Hope that helps.
Troy.
Old 09-10-2024, 08:46 AM   #87
rbruno68
Hope that helps.
Troy.
That definitely helps. I will be working on may cab hopefully soon and was thinking about how much work needs to be done. Not that I want to take short cuts, but for areas that will be covered by carpet/mat or tucked up under the dash, I was wondering if there were different ways of doing it verses the way the dash and other places that will be seen will be done. Thanks for the info.
Rob
Old 10-01-2024, 09:44 PM   #88
cla5675
Fauxtina paint work is coming along nicely. Interior paint work is done.
Old 10-01-2024, 09:48 PM   #89
cla5675
Some comparison pics on the cab repair. Not too bad if I do say so myself.
Old 10-01-2024, 09:52 PM   #90
cla5675
Firewall repair went well too.
Old 10-01-2024, 09:56 PM   #91
cla5675
Lastly, some pics of cab interior repair work.
Old 10-02-2024, 02:43 AM   #92
Braunschweiger
You did a great job, it turned out very nice.
Greetings Harald
My 62 build thread
Old 10-02-2024, 08:47 AM   #93
rbruno68
Looks great. Hoping to get close to this in a month or so on my 63 cab. I am planning on going back to Fawn with mine, but the grey is a nice contrast.
Old 10-02-2024, 02:34 PM   #94
cla5675
Thanks for the kind words, fellas!!
Troy.
Old 10-02-2024, 02:43 PM   #95
cla5675
Few more pics of the fauxtina work. This time in the daylight.
Old 10-03-2024, 08:35 AM   #96
rbruno68
Got another question. How did you color match your blue? my plan is to fix patches like you did but not paint the entire cab this go around. Mine is a factory red truck and the colors range from very orange to still close to red. If I want to put color on my repairs, I would like to see if I can blend it like you did. But, if I got to the paint store and give them my paint code, I would image the red they sell me wouldn't match the faded red on my truck.
Old 10-04-2024, 12:05 AM   #97
cla5675
At my local paint shop they use a "gun" to determine the paint match. I guess it sort of takes a pic and breaks down the pigments. I never use paint codes any more. They just aren't as accurate as the "gun" method in my experience.
Troy.
Old 10-05-2024, 10:06 AM   #98
rbruno68
Troy.
I stopped in a local PPG supplier and they mentioned the same thing. I could bring them a panel and they have some way of determining all the pigments that would need to go in the paint to duplicate what I have. I think that is what I will end up doing. Now just need to figure out what shade of red of the variety of faded shades on my truck to take to PPG.
Rob
