Old 09-01-2024, 05:45 AM   #1
70 shorty
Where's my beer?
70 shorty's Avatar
Borg Warner super t10 in place of 3 speed
My 79 Vette has it's original BorgWarner super t10 4speed in it and I just got a tremec tkx 5 speed conversion for it. I think I want to put the 4 speed from the Vette in my truck to back up the built 6cyl in it. I think I've read that it will bolt right in and even the.shifter would be in exactly the same place. The Vette has a Hurst shifter in it, so I would reuse that. What about a crossmember? Of course there is none with the 3 spd, but would I need one with a 4 spd, and if so what do I use? Looking for advice from those who have done a 3 speed to passenger car 4 speed swap. Thanks!
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 09-01-2024, 09:48 AM   #2
Accelo
Accelo's Avatar
Re: Borg Warner super t10 in place of 3 speed
Just use a cross-member for an automatic. It should mount right up and match the Borg just fine. I believe the drive-line will do the same. If you have a floor shift, which sounds like you have, it should be a fairly painless swap except for the removal of the cross-member. Access is poor and the rivets are a PITA to remove. I recently worked on a converted truck, and they used a torch to cut the center of the 4-speed cross member out. The riveted sections were still there. Looked like heck but functioned perfectly.
Accelo is offline   Reply With Quote
Old 09-01-2024, 10:07 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
The 3 speed just uses the bell housing mounts, no rear X-member. The 4 speed will mount the same. No rear X-member needed..... Just bolt it in, in place of the 3 speed.
Leon
Old 09-01-2024, 10:15 AM   #4
geezer#99
geezer#99's Avatar
Leave the crossmember in place with the bh and hang the t10 onto the bh. The t10 is 20 lbs lighter than the Saginaw.
Depending on your t10’s first gear ratio you might be losing some gear reduction.
Another thing is to check the input shaft bearing housing diameter.
geezer#99 is online now   Reply With Quote
Old 09-01-2024, 10:56 AM   #5
MikeB
MikeB's Avatar
Very good advice. I was also thinking about input shaft spline count. The T10 is 10-spline like the Saginaw, but I just read that the Super T10 has 26 splines. I also read that the Super T10 has a larger output shaft diameter, which probably means a different yoke.
As for gear ratios, the Saginaw 3-speed has at least three different gearsets. The base six-cylinder engines have the lowest first gear ratio for better torque multiplication. The 292 six (and later the 305) got the next lowest, and then the 350 and big blocks got the tallest.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 09-01-2024, 11:21 AM   #6
geezer#99
geezer#99's Avatar
And now that I thought about it, it’s likely the shifter location isn’t the same. IIRC the t10 is a couple inches more rearward. Puts the handle right under the seat.
Old 09-01-2024, 02:48 PM   #7
MikeB
MikeB's Avatar
About the gear ratios, I found the info below on the 3-speeds. 0-3 are the number of grooves on the input shaft. I would guess your six-cyl trans is 3.11 or 3.50, assuming it's original.
.................................1st 2nd 3rd
Saginaw 3-speed – 1 2.54 1.50 1.00
Saginaw 3-speed – 0 2.85 1.68 1.00
Saginaw 3-speed – 2 3.11 1.84 1.00
Saginaw 3-speed – 3 3.50 1.89 1.00
So compare total torque multiplication (1st gear ratio X rear axle ratio) to see which one will work best.
Mike
Old 09-02-2024, 10:55 AM   #8
70 shorty
Where's my beer?
70 shorty's Avatar
Thanks for all the replies. I will research further in respect to the gear ratios and input spline count.
Old 09-02-2024, 12:48 PM   #9
HalfBrit
Back in the 90's I swapped a Muncie M21 into my '70 3 spd truck. Probably put 150k miles with the stock bellhousing mounts and no rear crossmember. Compared to the Muncie, I was surprised how heavy the 3 spd was when removed.
HalfBrit is offline   Reply With Quote
Old 09-08-2024, 12:48 AM   #10
406flyfish
I have a super t 10 out of a vette in my 69 c10. I removed the bell housing mounts and used the aluminum corvette bell housing. I also installed the automatic crossmember. I felt like it would better support it further back but who knows. The output shaft is the same as a th400 . I have the hurst shifter for a c10 and it comes out right at the seat so I built an adapter to move it forward to clear. The clutch spline wasnt an issue but I donÂ’t recall which clutch I used. First gear seems a little tall to me but the engine wants a 3k stall so take off is rough either way. If you need any pics or questions feel free to ask.
406flyfish is offline   Reply With Quote
Old 09-08-2024, 12:54 PM   #11
MikeB
MikeB's Avatar
I did the same in a 55 Chevy car. Didn't put that many miles on it though!
Just be sure to check the bellhousing mounts when you're under the vehicle. They have been known to sag with age.
Mike
Old 09-09-2024, 03:00 PM   #12
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
My 1970 C10 has a Super T-10 bolted to the original 3OTT bellhousing that is behind a 350. There is no transmission crossmember as the bellhousing is bolted to the frame with the stock mounts. The Super T-10 just hangs out back there all by itself mounted to the bellhousing with 4 bolts. Been like that since 1974. No problems ever.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
