Yesterday, 12:57 PM | #1 |
BlahBlahBlah
Rear axle offset question
I was looking at the axle on my old 71 big block 157 in wheel base DRW C30 comparing it to a standard 3/4 ton axle. What is the reason the one ton center section isnt centered on axle meaning one axle side is longer than the other. Looking at the 3/4 ton the center section is centered on the assembly like all 3/4 and half ton Chevy trucks I have looked at.
Yesterday, 01:57 PM | #2 |
Re: Rear axle offset question
The driveshaft and pinion gear of most differentials are centered.. This puts the ring gear offset to one side, making one axle longer than the other.. I can't see your C/10 from here but I can see my '71.. It's not centered...
Yesterday, 03:01 PM | #3 |
BlahBlahBlah
I just assumed on the 3/4 ton the axles were the same on each side. I’ve never taken a rear end apart, beyond my capability. After reading your post I sort of understand a bit better. Still unsure why the one ton is so much different.
Couple pics, one ton axel is nice and clean, 3/4 ton is “weedy”
... Last edited by CG; Yesterday at 03:14 PM. Reason: Still trying to figure it out in my pea brain |
Yesterday, 10:16 PM | #4 |
All about them Ks
The HO52/72 from your 1 ton are off set like that. The dana 60 in your 3/4 ton is centered. Just a difference in axle designs. Also noteworthy here in my observation, most 3/4 ton Chevy’s got the Ho52, and GMC’s seem to have gotten more of the dana 60’s but this isn’t cut and dry.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5 lift, 35s, front dana 60 blah blah blah http://67-72chevytrucks.com/vboard/s...d.php?t=662879 69 K10 SWB: 4 lift 33s in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's Last edited by 57taskforce; Yesterday at 10:57 PM. |
Today, 12:29 AM | #5 |
BlahBlahBlah
Any idea on why it was designed with the offset?
I believe the 3/4 ton started life as a 72 Cheyenne Super that I sold the guy that owns it now. He parted it and this is all that’s left
Today, 09:55 AM | #6 | |
It helps with u-joint rotation and vibration. Too much or too little angle cause accelerated wear. U-Joint Operating Angles: {The u-joint operating angle is the angle formed by two yokes connected by a cross and bearing kit. There are two kinds of u-joint angles. The simple one plane angle found in most installations has all driveline slope confined to one plane, usually the vertical plane. The other type of driveline angle is compound angle in two planes. This is found in driveline designs where offset exists in both the vertical and horizontal planes.} 1 plane set-up 2 plane set-up
Today, 10:49 AM | #7 |
BlahBlahBlah
Interesting stuff. So maybe because the C30 has the 157in wheel base it required a different drive shaft set up than the shorter wheel base trucks.
