Old 10-12-2016, 10:14 PM   #1
custom10nut
custom10nut's Avatar
Front sway bar diameter
Is a factory front sway bar for our trucks 1 1/4 inch? I need to replace my bushings, so I need the right size.
custom10nut is offline   Reply With Quote
Old 10-12-2016, 11:01 PM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: Front sway bar diameter
They didn't have factory sway bars 67-72. 73-87 had a couple of different sizes. Measure yours.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 10-13-2016, 03:00 AM   #3
LongBox
Well, my 69 GMC has a factory sway bar. It is mentioned on the SPID. I've been under the truck, and seen it for myself. I will try to find time to put a caliper on it tomorrow to give you the exact OD of this piece, but the rain is coming down pretty heavy right now, so don't hold me to the time.
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline   Reply With Quote
Old 10-13-2016, 05:19 AM   #4
northern 85
northern 85's Avatar
Pretty sure the factory bars on 1/2 tons were 1 1/8, mine is from a 80s 1 ton 2wd is 1 1/4
northern 85 is offline   Reply With Quote
Old 10-13-2016, 11:01 AM   #5
custom10nut
Mine did come from a 70, I just have to measure it with my calipers. I was just hoping someone would know offhand.
Old 10-13-2016, 01:07 PM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
It depends. Stock 1/2 tons were 1-1/8" while the 3/4+ ton trucks were 1-1/4". The majority of aftermarket bars are the larger 1-1/4"...
I would measure just to be sure.
The 67-72's absolutely had optional factory sway bars... GM didn't drill holes in the A arms and frame that are a perfect match for sway bar mounting brackets for nothing...
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-13-2016, 01:23 PM   #7
michael bustamante
michael bustamante's Avatar
OEM that ive seen for our era. starts at 7/8"
ive pulled em off square bodys. and they come up to 1 1/4" and they fit just fine
1967custom
michael bustamante is offline   Reply With Quote
Old 10-13-2016, 01:35 PM   #8
chewychevy67
My 67 is a 7/8" stock with a 327 engine.
chewychevy67 is offline   Reply With Quote
Old 10-13-2016, 02:54 PM   #9
67ChevyRedneck
Wow, I didn't remember them being that small (mine has the aftermarket 1-1/4").
That's what makes this forum great.
Jesse James
Project "On a Dime"
Old 10-13-2016, 03:42 PM   #10
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
My 1972 GMC C1500 has a factory sway bar that is 1 1/16".
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 10-13-2016, 08:03 PM   #11
plastercracker
i replaced mine from summit racing. just entered year make and model and there they where from moog. i used the rubber ones. think they where 1 1/16? and they only had them in blue. perfect fit
plastercracker is offline   Reply With Quote
Old 10-13-2016, 08:08 PM   #12
garyd1961
Were the Suburban sway bars the same size as the 1/2 ton C10s? I took one off a 1970 Suburban and put it on my 1970 1/2 ton C10.
garyd1961 is offline   Reply With Quote
Old 10-13-2016, 11:58 PM   #13
brad_man_72
the boat guy
Oooh I learned something.
Old 10-14-2016, 12:49 AM   #14
ghalperin
ghalperin's Avatar
I have a 1 1/16" front bar from a 68 C10 CST. I just got these from eBay, they fit perfect.
Glenn
1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca
1929 Ford Model A Roadster - traditional pre-war banger hot rod
ghalperin is offline   Reply With Quote
Old 10-14-2016, 01:00 AM   #15
mild68
mild68's Avatar
I think if it got power steering it got an antisway bar.
Not saying if it didn't have power steering it couldn't have an antisway bar.
mild68 is offline   Reply With Quote
Old 10-14-2016, 02:15 AM   #16
LongBox
Yep, my 69 does NOT have power steering, and it DOES have the anti sway bar.
Rick
Old 10-14-2016, 11:18 AM   #17
biketopia
My 71 has power steering and no sway bar
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 10-14-2016, 06:59 PM   #18
garyd1961
I thought the CST and Cheyenne got a sway bar. I know my Cheyenne Super had one.
Old 10-14-2016, 07:55 PM   #19
custom10nut
Mystery solved. I got down an measured. Mine is 1 1/8 inch type. I have the new bushings ready to put in.
Does anyone know if there is a rear sway bar.for a C-10 with the trailing arm suspension? The Panhard Bar sort does the same thing, but I've have been told there are sway bars made, which I think would be an improvement
Old Yesterday, 11:15 PM   #20
1967GMCC20
1967GMCC20's Avatar
I need a 1-1/4 for my 67 GMC. So I read I have to drill the locating holes. After driving this truck over 1000mi this year, I can feel the sway, a sway bar and GV overdrive, this truck is ready for winding roads, and long trips.
1967GMCC20 is offline   Reply With Quote
Old Yesterday, 11:55 PM   #21
BROWN 70
BROWN 70's Avatar
Smile Re: Front sway bar diameter
hi guys, my gmc didnt come with a front bar. I found a 7/8 at the wrecking yard and put it on. it was better. then I found a 1.250 at the yard and put it on. big difference. btw my a arms were drilled.
BROWN 70 is offline   Reply With Quote
