Old 09-02-2024, 12:10 PM   #576
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
Re: 67 Camaro Build
Originally Posted by 7dee2 View Post
Thanks, it’s just blacked out. I thought the same thing and even borrowed a used OE 67 Vette Stinger Insert from a buddy of mine. We found the scoop stamping is not an exact match for the insert, plus the inner structure creates problems. So after working with Perk’s, we decided the steel hood is not very conducive to this mod. I have seen pics of this done and it appears it’s always a fiberglass hood.
thanks for the indo. Thats good to know, Ive always wondered that about the insert, but never have had a Camaro with a stinger hood but its been in the back of my head if I ever go another 67 to stick one on it over the SS hood or a Cowl.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 09-04-2024, 08:58 AM   #577
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Originally Posted by 72 tigger View Post
Both the paint and brake lines look great!
I appreciate and respect your attention to detail
Thank you Kirk, I appreciate the kind words.
Glad you brought it up, I think that’s a cool mod for this style of hood.
Most of the front clip is back home with all the badges installed. These pics don’t do justice, this stuff looks so good! I do have a slightly crooked S on the right fender. Hard to see in the pictures but the Chevrolet script on the header needs to be bent a little to follow the contour of the panel. Both will be easy fixes later, Perks Customs continues doing an excellent job.
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 09-04-2024, 11:38 AM   #578
Lost in the 60's
Active Member
Lost in the 60's's Avatar
Re: 67 Camaro Build
Could you use a micro file and elongate the holes slightly to tilt the letter in the correct orientation ? I've done this with some of my "tweaks", as long as the emblem still covers the hole.
Lost in the 60's is offline   Reply With Quote
Old 09-08-2024, 08:43 AM   #579
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Yes exactly, you've read my mind.
The hood followed the next day. All these nice pretty panels are a huge motivation to get this car done.
Brett
Old 09-09-2024, 08:17 AM   #580
KevinK7
KevinK7's Avatar
Re: 67 Camaro Build
The 'icing' on the cake, ...the emblems really look good on there. You're getting close Brett
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 )
'68 C10 50th
KevinK7 is offline   Reply With Quote
Old 09-11-2024, 09:56 AM   #581
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Thanks Kevin, I do like how this hood has turned out (with the Baldwin Motion look).
The front brake calipers are installed, I'm not a big fan of the spliced rubber lines (H672), but it is what it is. Also, more fuel line routing while the exhaust was still mocked up. Placed blue tape with dots where I want to drill for the fuel line saddle clamps. I'll drop the exhaust out of the way to continue the installation.
https://www.inlinetube.com/products/h672
Brett
Old 09-11-2024, 12:33 PM   #582
KevinK7
KevinK7's Avatar
Re: 67 Camaro Build
Brett,
I hear ya' on the caliper lines. The conversion kits are '69 style calipers/hoses, and when putting them on '67/'68 they don't exactly route the best. I'm still surprised nobody came out with a set of hoses to work better on 67/68...
'68 C10 50th
Old 09-15-2024, 08:36 AM   #583
7dee2
7dee2's Avatar
Re: 67 Camaro Build
That's the truth!
Hooray, I've pulled the mockup motor and exhaust for the last time! I bought this cherry picker add-on tool to help me wrestle hoods, fingers are crossed that this works if I get the guts to try it. Ran it up as high as it would go to see if I could hang our extra hood on the wall. It's just shy and a bit too Hari-Kari, I think.
Brett
Old 09-18-2024, 09:10 AM   #584
7dee2
7dee2's Avatar
Re: 67 Camaro Build
I got something going on the doors, they both needed some left-over paint/mask removed and a sound deadener treatment. I'll wait until they are hung and apply cavity wax before the final build-out.
Brett
Old 09-22-2024, 08:21 AM   #585
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Here’s a look at the OE tail lights we have, red overspray and all. The plan is to restore the tins and replace the rest. I'm also working on speedo cable routing (unique for a Muncie) with a right-side speedo gear. The last pic illustrates the 2 types of right and left routing.
Brett
Old 09-24-2024, 05:58 PM   #586
CAMAROBOY68SS
Re: 67 Camaro Build
looking good, make sure the socket plug area is really clean. Also if your original blub sockets were good, I would reuse them. I have not found a good aftermarket socket yet that holds the bulb properly and would ground like originals with my 68. I have the added headache of my car being a RS so all 4 bulbs are brake/tail.
The Twins:
The "Others"
2017 Camaro SS
Life long Chevy guy
Old 09-25-2024, 09:36 AM   #587
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Thanks, our wiring is a real mess and will be completely replaced with American Autowire Factory Fit harnesses. We’ll hang onto the old wiring until I’m sure I don’t need anything, I've heard the taillights can be a real pain.
Our Moser diff needs a breather, so I grabbed this stuff from NAPA. I mentioned the rear diff covers earlier and here’s the lineup. I thought about running the ET cover (middle) with a Motion sticker but in the end the Mr. Gasket won out. I like them all but with a built drain plug, and you don’t see the Mr. Gasket as much. Too bad the slightly deeper Tanks fuel tank we're using will hide most of this view.
Brett
Old 09-29-2024, 08:32 AM   #588
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Taillight tins after a very light media blast, then chrome-type paint (going for bright taillights) on the inner, followed by dull aluminum on the outer.
Brett
Old 10-02-2024, 09:38 AM   #589
7dee2
7dee2's Avatar
Re: 67 Camaro Build
The intermediate brake lines line up well enough now to be bolted to the brake pressure regulator valve. That’s a win, the rear piece had to be bent around the subframe connecter making it slightly shorter. At the same time, the front piece was not happy with our manual MC setup. I ended up ordering a new 69 intermediate line and used the front piece with minor tweaking to make this finally work. https://www.inlinetube.com/products/ccb69m2
I get to refit the taillights with the tins this time, oops! But hey, it’s looking mean with those blue raccoon eyes.
Brett
Old 10-06-2024, 08:33 AM   #590
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Bending, trimming, hammering, and I tell what, they are going fit by golly!
Brett
Old 10-09-2024, 08:41 AM   #591
joesscamaro
Re: 67 Camaro Build
I've been gone a while. It's good to see all of this progress! The car is looking really good.
joesscamaro is offline   Reply With Quote
Old 10-09-2024, 09:09 AM   #592
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Thank you Joe.
Tail light housings are now seated with the inner tins on, the rear exhaust hanger is painted and reinstalled, and fuel line plumbing has made a little more progress.
Brett
