Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 09-12-2024, 09:47 PM   #4
bhap
bhap's Avatar
Re: Headlight wire sizes
The wires running from switch to relays will be fine, they probably carry less than 1 amp. For the wires from relays to headlights, attached is a wire size chart for 12v that shows wire size by length of wire for various amp loads. 14 gauge is probably big enough, but 12 ga wouldn’t hurt - I don’t know how many amp LED lights draw. The wires from your power distribution block / battery to the relays need to be big enough to carry the load on each relay for the length of the run. Madelectrical.com is a good resource for information.
bhap is offline   Reply With Quote
