Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 08-30-2024, 05:42 PM   #26
57taskforce
All about them K’s
57taskforce's Avatar
Re: Bought a rough running '04 Suburban
How was the oil pressure??? That’s a massive leak.
Tyler
Old 08-30-2024, 06:30 PM   #27
Steeveedee
Who Changed This?
Steeveedee's Avatar
Does that exhaust valve open and close?
~Steven
Simi Valley, CA
Old 08-30-2024, 11:05 PM   #28
LockDoc
The Older Generation
LockDoc's Avatar
Oil pressure was the same as the 8.1 in the black Dually so no problem there....
Originally Posted by Getter-Done View Post
Wow.
The pushrod beat up the snap ring.
I am thinking where are the Ears of that snap ring?
It probably won't make it back through they will drop to the bottom.
Is the oil pan Metal?
If so a magnet could be place in a position away from the oil pickup.
I had a few small pieces of metal on the end of the magnet. Oil pan is aluminum.
You know, I haven't tried that yet. I will do that in the morning. Thanks!
Leon
Old 09-06-2024, 01:26 PM   #29
Tom
driving is in my blood
Tom's Avatar
My 02 subruban is the best bang for your buck truck I've ever bought. I only use it for going to the lake or camping, but its perfect. I love it very much.
Tom is online now   Reply With Quote
Old 09-06-2024, 04:50 PM   #30
jjzepplin
jjzepplin's Avatar
Magnetic oil plug or just glue a magnet on the pan. Once had a rocker shoot right over the adjusting nut and stud. Had a bunch of valve springs break and cause rocker carnage.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 09-06-2024, 05:14 PM   #31
LockDoc
LockDoc's Avatar
I have had an '03 for a few years that I use to plow my drive. The problem is that it is so rusty that I can't drive it on the road any more. This one is still good enough to be road worthy.
I have a couple of small rare earth magnets and I thought about sliding one of them through the drain plug hole. I may check at NAPA or O'rielys to see if they have one of the magnetic plugs.
Thanks guys.
Leon
Old 09-11-2024, 10:19 AM   #32
TATE228
So the trick here is going to be to find a penny or something and jb weld it where the pushrod lands then proceed to fill the crack with the jb weld. The next step isnt really necessary but i like to run a zip tie around the whole thing to make it extra strong. Your welcome
-1971 K20 350/sm465
-2004 1500
TATE228 is offline   Reply With Quote
Old 09-11-2024, 05:41 PM   #33
LockDoc
LockDoc's Avatar
By golly, I always appreciate a good tip or two to help me get the job done. I think I will use a ball peen hammer and put a little divot in the penny before I glue it in there. That will help center the push rod. I think I also have a couple of EXTRA HEAVY DUTY Zip Ties I can use.
Thanks!
Leon
Old 09-11-2024, 07:57 PM   #34
Boog
laying low
Boog's Avatar
Be sure to use the black ones though. They say they last longer.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 09-13-2024, 12:26 PM   #35
TATE228
I have a stash of the "good home depot zip ties" that I save for just these types of jobs. i just don't trust the standard harbor freight ties for the important jobs.
-1971 K20 350/sm465
-2004 1500
Old 09-14-2024, 10:29 AM   #36
HO455
HO455's Avatar
RIP Bob Parks.
Old 09-14-2024, 10:32 AM   #37
LockDoc
LockDoc's Avatar
I hope they are better than the $1200 exterior door I just bought from them. It sucked....
Leon
