09-12-2024, 07:22 PM | #1 |
Cab light question
I have 3 rigs with clearance lights on them. Two of which I have never had any issues with. My79 dually however has two lights dead in the water. Initially I thought it was just bulbs no big deal as all 5 were non op. Well I got 3 of them fixed with just bulbs but the two pictured did not come on with a bulb change. Any ideas? Do these sockets go bad? Are these lights wired in parallel? Any input would be greatly appreciated. I do have another harness that I could use but really don’t want to get into that if I don’t have too.
1987 V30 Silverado SRW 454/400 4x4 104k original paint 1979 GMC C3500 Sierra Classic 3+3 454/4l80e 1971 K20 Cheyenne: http://67-72chevytrucks.com/vboard/s...d.php?t=804580 https://67-72chevytrucks.com/vboard/...d.php?t=837441 Instagram: jt_trucks3500 |
09-13-2024, 09:32 PM | #2 |
Re: Cab light question
Yes, these lights are wired in parallel. And yes, a bad socket could be a possibility.
However, it's more likely to be a bad ground. I don't know if there were any changes/variations in the wiring harnesses over the years, but on Dad's 77, each cab light has it's own individual ground. And those grounds are via metal clips that simply push onto the edge of the cab roof skin metal that's exposed in each of the light holes. You might find it necessary to remove those ground clips on the non-working lights, clean them up (along with the roof where they clip onto), and push them back into place to establish a good ground. I've also found that it's sometimes necessary to carefully re-bend the little wire contacts on these wedge base bulbs in order to get them to make a good connection with the contacts inside the sockets. For example, sometimes the bulb will light up when you first start to insert it into the socket, but go out once it's fully seated. Or you can get the bulb to work intermittently by wiggling it around in the socket. Bending the wire contacts out on the bulb a little will often fix these issues. |
Yesterday, 10:19 AM | #3 |
Hello a said. Grounds mostly first to check roof. I see you got rust hole in top side of the cowl vent near window steel, let more air humidity in the back side of the cab dual layer of the roof metal there no paint on the back side of the panels sure rust happens even faster there with the cool down heat ups on the meat rust more. any of the little grounding clip if the clip and the roof metal got enough surface rust on them become a bad ground or intermit ground at best bumps on driving. The other the light seal the lens may be small crack or the seal to roof may have slight warp to crack after all these years heat cool downs, Tip: after sealing for leaking and moister. For spray a little bit rust check red cap can on the screw in the clip after metal bear. To slow down surface rust just a lite dab if you put too much some time it can start to enter fear a with good ground. You may want to redo every few years or when it starts to dry out get to dirty. Those lights get pretty hot warp the seals make the connecting wear warp the spring rotate/bending springs blub mounting can help or fix. After all theses year heat bulbs.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
