Old 05-24-2024, 08:47 AM   #176
67C10Step
67C10Step's Avatar
Re: 1967 buick special wagon
Still loving it! As a younger guy I overlooked the wagons but I've seen so many cool ones in the last 10 years if I had more room, time, and $$ I'd be looking for one. Guy down the road from me has a 69 malibu wagon that is cooler than the other side of the pillow.
What you are building will turn the heads of the motor crowd everywhere you go.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 05-24-2024, 10:12 AM   #177
3757chevy
3757chevy's Avatar
40 years ago I bought a '67 Chevelle wagon. It was a 283 with a power glide and had been the delivery car for the first parts store I worked for. I put Corvette rally wheels on the back and Nova wheels up front with baby moons. I miss it but that was before wagons got so popular.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 05-25-2024, 09:32 AM   #178
gottattooz
gottattooz's Avatar
Well good news and bad news. I got another windshield installed. They covered it as warranty. I cut off all the pins and screws for the trim clips and told the guy installing the glass to fill in the gaps with the urethane like a birthday cake. I told them about the dimensions of the channel I installed being incorrect and they trimmed the glass for clearance where it was a little tight, so it wouldn't get pinched if the body flexes for any reason.
When I left the windshield shop, I drove to greg Smith equipment sales and picked up a 4-post lift for the shop. (My dad's friend met me there with his car trailer) On the way up there, it rained and having no wipers, wiper arms, rear glass or rear wheel tubs, it was raining inside the car as well as outside.
On the ride home, I saw a puff of smoke and thought it from the exhaust of the car in front of me. But then I saw another puff, and it clearly came from under the hood, and I could smell burning plastic. I pulled over and the clip for the abs module was burning. It turns out the engine cover I put on was pushing the spark plug wire up against the oil dipstick bracket. The plug wire caught fire and caught the abs module on fire. I removed the engine cover and put it the fire and drove home on 7 cylinders. So now I need plug wires.
Josh
1967 Buick Special wagon
1968 Jeep Wagoneer
1958 Chevy Panel Truck
2017 Suzuki M109R
gottattooz is offline   Reply With Quote
Old 05-28-2024, 08:49 PM   #179
gottattooz
gottattooz's Avatar
Question Re: 1967 buick special wagon
Not really an update, but I did make it on a car show poster for the father's day show coming up. So far, the local guys loved seeing the car under construction, and all said they're looking forward to seeing real time in person progress each month as I make changes.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 05-30-2024, 11:07 PM   #180
gottattooz
gottattooz's Avatar
I hated the thought of not using the c6 wheels, so I got one of those sledge hammers with the pointed wedge on one side and beat it up and in where it was making contact. Then I put 2 full turns on each coil over to raise the car up evenly. Then my dad and I drove around hitting every bump and dip we could find and it didn't scrape once. I also measured the clearance under the front air dam and it's up from 4 1/4 inches to 5 inches. I'm beyond happy!!
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 06-07-2024, 03:17 PM   #181
gottattooz
gottattooz's Avatar
I tried my best to use the g8 seat belts, but apparently they jam up if the air bags deploy. So I ran across a 3 point setup from jegs.com. I bought one side initially to make sure it would work before buying the passenger side. I'm happy with the fit, and I'm very skeptical that it'll do anything except keep the body inside the car if anything serious happens. But the wagon came with lap belts, and the shoulder belt should keep me from getting a ticket.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 06-07-2024, 08:32 PM   #182
gottattooz
gottattooz's Avatar
The door panels I ordered last year were on back order. I guess no one really fixes up 4 doors and wagons, so they had to make them per request. I just opted for the cheap black panels with no chrome or frills. But I was excited to see on the back of the panel they have predesignated cut outs for the arm rest, door handle and window cranks. Since I'm running the power window motors, I won't have to patch a hole for the crank handle.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 06-08-2024, 03:03 PM   #183
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Nice!! They look great.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 06-10-2024, 01:16 AM   #184
3757chevy
3757chevy's Avatar
Nice.
MIKE
Old 06-19-2024, 11:14 AM   #185
gottattooz
gottattooz's Avatar
Not much of an update. I mounted the passenger seat belt. I took vacation and, in my travels, picked up some matching rims for spares. With the matching rear spare, I won't have to modify the rear wheel openings to fit the front wheels that stick out another 1/2 inch or so.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 07-23-2024, 09:53 PM   #186
gottattooz
gottattooz's Avatar
Time to tackle the rear wheel tubs. I removed the back seats so I could unplug all the electronics attached to the package tray, and then I removed the rear seat Brace. I used bed frame railing to make a bracket to support the battery box and hold the quarter panel out abs away from the tire.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 07-24-2024, 09:46 PM   #187
gottattooz
gottattooz's Avatar
My friend gave me a pair of wheel tubs from his c10, but I'm not confident I can make them work and still look cool. So I'm making braces from the existing wheel tub to the quarter panel and I'll fill in the gaps with the metal from a 55 gallon drum I have. It'll be easier to build around the fuel filler neck on the passenger side that way
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 07-25-2024, 06:40 AM   #188
KevinK7
KevinK7's Avatar
I wouldn't even know where to begin with something like this. I'm impressed as you turn another 'corner' to keep fabricating piece by piece.
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 )
'68 C10 50th
KevinK7 is offline   Reply With Quote
Old 07-25-2024, 05:16 PM   #189
gottattooz
gottattooz's Avatar
The whole project is very daunting and time consuming. But if you dissect the whole thing into small steps and focus on those smaller tasks, you make a lot of progress. The whole project is written in chalk, because you don't know what obstacles are going to arise until you realize what does or does not work for whatever reason. I've learned, as this is my 3rd body swap, to keep an open mind and sometimes you have to step back and pivot.
As frustrating as the challenges are sometimes, I enjoy figuring things out and taking things that don't necessarily belong together and making them look like they were intended to exist the whole time.
Facebook has a group dedicated to body swaps, and I'm so impressed with the vision and abilities of other people. From simple rat rod swaps to factory looking swaps that look like gm and Ford and dodge designed and built them. Plus the cross pollination of BMW chassis swaps under 58 Detroit steel and things that blow my mind. That page gets me excited to try new things
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 07-27-2024, 11:56 PM   #190
gottattooz
gottattooz's Avatar
I finished making the driver's side rear wheel tub. I painted all the welds and bare metal with engine paint. I'll seal both sides of the seams, undercoat the bottom and I'll put sounds deadener on the top. I'm excited to get one complete. The passenger side will be more of a challenge with the fuel filler neck
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 08-04-2024, 05:31 PM   #191
gottattooz
gottattooz's Avatar
I undercoated the wheel well and put sounds deadener on the inside. Then I made a patch panel for behind the wheel well. I'm thinking about the next patch panel going straight up to meet the floor to minimize the number of patches I'll have to make
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 08-15-2024, 10:32 PM   #192
gottattooz
gottattooz's Avatar
To center and secure the fuel filler neck, I made a template out of cardboard. There's a rubber grommet on the neck that's 2.75 inches in diameter. I bought a 2.75 inch hole saw and cut the bracket in half to fit around the neck and welded everything in place. If you're ever welding around the fuel cap, put a piece of plastic sheet behind the cap to prevent vapors from igniting.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 08-19-2024, 09:53 PM   #193
gottattooz
gottattooz's Avatar
I bought a new body control module, because I think I fried mine welding. I can't be sure, but everyone I've talked to who knows anything about newer cars says I damaged the bcm. Well I plugged in the new one and it immediately went into security lockout. Another Google search says you have to have it programed to match the car and blah blah blah. So I plugged the old one back in for now.
I did start on the passenger side, bracing the quarter panel
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 08-27-2024, 09:00 PM   #194
gottattooz
gottattooz's Avatar
I bought a pair of 6mm (1/4 inch) wheel spacers to push the inner lip of the rear wheels away from the inner wheel tub just a little more so I would feel comfortable hiring hard bumps without damaging the tire or rim. Now I can slip my fingers between each side of the wheel and the fenders easily.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 08-27-2024, 09:05 PM   #195
gottattooz
gottattooz's Avatar
I welded the passenger wheel well tub back in place and am using this 1.25 inch bed frame rail section to repair the lower window channel
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-15-2024, 10:54 PM   #196
gottattooz
gottattooz's Avatar
I finally finished the passenger rear wheel tub. I still have to finish the seam sealer and the sound deadener on the top side, but I'm glad the hardest part is done.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-21-2024, 06:23 PM   #197
gottattooz
gottattooz's Avatar
I replaced the dying starter. Then I found a guy across town parting out a 1967 gs 400. I bought the hood and front bumper. He also had a 67 chevelle front bumper that I plan to cut up and use to dress up the front air dam
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-24-2024, 06:06 PM   #198
gottattooz
gottattooz's Avatar
I've been messing with the 67 chevelle bumper. I cut out the bottom section and flipped it over to see what it would look like on the car. Then I clamped the ends together on the spare bumper. It's definitely not as pointed as the first version, but I'm also not hating it. I'm going to try to build some kind of jig to mount the spare bumper to so I can build it on the stand and then transfer it to the car.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-24-2024, 09:02 PM   #199
gottattooz
gottattooz's Avatar
I cut the bottom of the chevelle bumper to contour the buick bumper. Then I pie cut the center so I could bend it until the ends touched. There's still some tweaking to do before I weld it to the air dam, but your can see what its going to look like. I'm beyond ecstatic on how it's turning out!
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-26-2024, 09:01 PM   #200
gottattooz
gottattooz's Avatar
I cleaned up and dialed in the fitment of the bumper to the air dam. I ground the air dam to bare metal where I tack welded it in place. Now that it's attached, I'll remove the air dam and I'll fill in the gaps on the work bench.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
