Old 08-25-2024, 01:01 PM   #1
Orange Crate
Orange Crate's Avatar
Cast Exhaust Manifolds (Approximately)
After 57 years my 2.5" stock exhaust manifold cracked. Wow what a shame, these things really woke up my 406 but looked stock. Oh well on to the fix. I ordered a set of 2.5" cast units from Summit. So here are the pics comparing them to what is left of the stock pieces. I have a saying that things made in the Pacific Rim are "approximations" of the real thing. Close but.....these new ones are not going on my truck. First pic is...well yea that happened. Second pic is the "new" high performance? Third pic is the old single exhaust port. One of these things is not like the other.....On this engine I need every square millimeter of flow (No I am not going with headers). Now I am looking at the TruRam set. Anybody have a set of those? I have AC so I think these will interfere with the new Alan Grove brackets I just put on.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...
Orange Crate is offline   Reply With Quote
Old 08-25-2024, 10:40 PM   #2
Ziegelsteinfaust
Re: Cast Exhaust Manifolds (Approximately)
I got 2 sets of the Dorman ram horns from Summit, and they looked good. With just being rougher then factory versions, but no misaligned ports like yours.
If by true ram horns you mean the polished ones you can get from speedway that look rounded, and swoopy.
I gave my dad a set of those, and they looked very nice to me
Ziegelsteinfaust is offline   Reply With Quote
Old 08-26-2024, 12:56 PM   #3
Orange Crate
Thanks for the input I'll have to call them about the port size/design. I was looking at these as a substitute for the original Corvette manifolds. The obstruction that can be seen in the port isn't misalignment it is how they are cast. The port on the other end is cast the same way and also the other manifold in the set is cast exactly the same. It seems odd that the manifold is a 2.5" high performance unit but with a complete face plant in the port design, again it is an approximation of the real functional high performance piece. The original Corvette manifolds can flow pretty well up to about 4000 rpm which is fine for the way I build my engine to tow. I have an RV cam that is "all in" at 5000 rpm, so there is no need to have big flow numbers above that as you get with headers.
Old 08-26-2024, 07:28 PM   #4
AcampoDave
AcampoDave's Avatar
Wow, those are even worse than the ones I had. Mine had smaller ports than the o.e.m two inchers and they cracked pretty quickly anyhow. I only have a 283 now so I just want back to oem 2". But wow those....what a shame.
AcampoDave is offline   Reply With Quote
Old 08-28-2024, 12:12 PM   #5
Orange Crate
Does your Dads truck have AC? Any pictures of the install on that truck?
Old 08-28-2024, 08:03 PM   #6
Ziegelsteinfaust
They were used on hot rods, amd a 50's truck. None of them had fitment issues or had AC.
Old 09-15-2024, 10:55 PM   #7
Orange Crate
A slight update on this issue. I have searched and called just about every vendor of these "reproduction" manifolds and they all seem to have the very restrictive bolt support cast inside the ports EXCEPT one....I called Corvette Central and they have their own molds for the manifolds. But just like everyone else they have casting supply issues which basically means they don't have stock. I did talk to a guy there that actually had a set on his desk for his own car and he confirmed that the ports are correct and open. I'll have to wait until the end of the month for their restock to come in. I'll believe it when I see it.... I decided not to go with the manifolds in the picture above after finding out this info from CC.
Old 09-16-2024, 01:41 PM   #8
MySons68C20
MySons68C20's Avatar
If it were me I would braze them up and continue....I have had great success with brazing and feel it would work well for you.
MySons68C20 is offline   Reply With Quote
Old 09-16-2024, 03:23 PM   #9
Orange Crate
Thanks but, the strength limits of brazing (especially at higher temps) is why I will stay away from that option.
