09-08-2024, 08:05 PM | #101 |
I'm trying....
Re: 1970 K20 Z62 Full Restoration
Eric came over today to lend a hand in setting the transmission and engine. I used the threaded holes that I think they used from the factory to set the transmission and the lift brackets on the engine to set that.
All things considered I would say that it was relatively drama free. I am trying so hard to seal this thing up. I have never had one that didn't leak somewhere. I would have liked to have gotten more stuff on...but I'm waiting for some parts...like exhaust bolts. I did mock the right side exhaust manifold up there just for fun...but it's got to come off. It is nice to have the drive line complete. A lot of work to get some rough pieces to this stage. I like this part the best.
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
09-08-2024, 08:07 PM | #102 |
I'm trying....
One final pic tonight. This is not an NOS or rebuilt fuel pump, but a new reproduction. I do like seeing that AC on there. But also the original refinished hardware. The "f" bolts and "L" bolts. Love it.
09-09-2024, 08:36 AM | #103 |
Carpe manana
Nice progress sir. The bolt affixing the fuel pump looks to have a real nice finish. Those bolts are neat.
09-09-2024, 04:00 PM | #104 |
Proprietor of Dale's Corner
Looking great
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
09-15-2024, 06:08 PM | #105 | |
I'm trying....
09-15-2024, 06:21 PM | #106 |
I'm trying....
I was lucky enough to put together two NOS exhaust manifolds. I had them ceramic coated as we have done in the past. I had a nice heat stove that I had ceramic coated as well...but it honestly didn't turn out too great. The black was too flat and the silver on the inner panel just made it look painted. In the meantime NOS bird dog Pete, alerted me to an NOS outer panel that I jumped on. We elected to strip the enamel and paint it with high temp. I had another nice inner that looked great in its original finish out of the electrolysis tank. The original finish kind of looks galvanized.
As an aside, few things are more mechanically satisfying than a nice fold over lock.
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 09-15-2024 at 11:11 PM. |
09-15-2024, 06:37 PM | #107 |
I'm trying....
Dave (DaHos) came through on the elusive 1970 K truck (with J70) oil fill tube. It was a nice example that cleaned up well. The rubber gasket came off a regular valve cover oil cap.
The style of oil cap that goes on this tube is kind of ubiquitous. I had a lot of NOS options available to me at reasonable cost (how often have you heard that in the last couple of years). But I don't know what the finish should be. This example has a phosphate finish. They put chrome ones on Corvettes (at least the higher HP versions). Dave did not have the OE cap. The pics of the original tube/cap earlier in this thread could be phosphate...could be raw. I don't think it was painted black. We'll leave it as is for now, until hopefully more info emerges.
09-15-2024, 07:01 PM | #108 |
I'm trying....
I started putting on some of the accessories and you know how I love to get in the weeds (as much as I can) on the plant processes.
So the engine shows up from Flint at the Fremont plant assembled and painted. The A/C is obviously installed at the truck assembly plant. The (honestly insane) bracketry that holds the compressor has mounting points on the intake manifold and water pump. The bolts that hold the intake and WP on are too short to hold the brackets too. So instead of chucking bolts in the trash, it appears that they repurposed the three intake bolts to the back of the compressor and the long water pump bolt got moved up to the top water pump bolt hole. Then new longer bolts are added where necessary. So you end up with a mix of painted (but scratched up) and unpainted bolts from the process. I also finally got to break out my date coded Frigidaire decal that I've been sitting on since we did that run back in 2019 (I think).
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 09-15-2024 at 08:49 PM. |
09-15-2024, 07:20 PM | #109 |
I'm trying....
I also got the alternator and power steering pump installed.
I found a date code correct alternator that Jason at Advanced Electrical Rebuilders rebuilt for me. I've used Jason before and he does a great job. I was on the hunt for a long time for a date code correct starter core to rebuild as well...but it still hasn't materialized. I don't know if the PS pump that was on this motor was original. Honestly...if the brackets hadn't been on it I might question them as well. Sometimes there can be a stamped date on the reservoir but there wasn't in my case. I will say..of all the trucks we've done, the pulleys line up on this one best.
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; Yesterday at 10:00 AM. |
09-15-2024, 08:12 PM | #110 |
I'm trying....
Eric sprayed the firewall on Saturday. Which meant it was time to write in the wet paint. The Fremont paint shop put what looks like an "A" on my truck, which I tried to copy as best as I could. It is a one shot deal...so I was happy to have that instead of the "N" or other tougher looking marks. Several practice runs on a spare panel before letting it rip.
I am so excited about the color. It looks fantastic in person. Eric even caved and gave me a few "factory style" runs.
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 09-15-2024 at 08:52 PM. |
09-15-2024, 10:57 PM | #111 |
Wow just beautiful.
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
Yesterday, 07:29 AM | #112 | |
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
Yesterday, 07:40 AM | #113 |
I'm trying....
Thanks!
Well info emerged quickly! Phosphate it stays. Thanks!
Yesterday, 12:58 PM | #114 |
Absolutely beautiful! Every detail looks so crisp. That heat shield and pipe really turned out nice. Did all of the 1970 trucks have the fold over lock on the exhaust manifold bolts?
1972 Blazer Highlander 1971 GMC K1500 SWB (sold) 2004 Corvette Z06 CE |
Yesterday, 02:06 PM | #115 | |
My 1970 TBC engine had the French locks on the manifolds, and the tabs were never bent over.
Yesterday, 02:25 PM | #116 |
Very nice, I love the runs..
Yesterday, 02:34 PM | #117 |
I asked my painter about recreating the runs my cab had before taking it down to the metal and he said he wasn't interested in doing it. Nice detail on the engine! Just curious why the ceramic didn't turn out on the heat stove? That was my plan but now mabey I won't do that on mine.
Yesterday, 10:18 PM | #118 | |||
I'm trying....
Me too...except after Mexican. Quote:
I can absolutely recommend ceramic coating for the heat stove. We've done it before to good effect. I just wasn't happy with the colors in this case and didn't push the powder coater to re-do it. I've attached a pic of the ceramic coated ones below. The black was too flat and the silver just looked like paint. I think you can get a better result than I got.
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; Today at 07:46 AM. |
Yesterday, 10:22 PM | #119 |
Did you paint your frame or powder coat? If paint do you mind sharing what kind?
Yesterday, 10:34 PM | #120 | |
I'm trying....
I'll check with Eric tomorrow on the paint...I don't think it's anything special on this one. We've used different semi gloss blacks. It usually is whatever is in the shop or the paint du jour. The paint store we use honestly has gone through a handful of paint lines in the last couple of years. Don't forget the General used the cheapest black he could get for those chassis and driveline pieces.
