Old 09-18-2024, 09:35 AM   #26
MikeB
MikeB's Avatar
Re: Rear gear Ratio Opinions/Suggestions
350 yes, Tach yes, 3 speed manual, so at highway it would be same as T350. Rpms are about 2300 at 70MPH, 60 is a hair over 2K. 265/70x16 tires or about 30.5 in high
A TH350 would have a little slip at highway speeds, depending on load. My old tach wouldn't fit after I shortened my column, but I remember there was a 200-300 PRM difference between a slight downslope (light throttle) and an upslope. So with 29" tires, let's say if you see 2100 on level ground to downslope, that would be 2300-2400 so on an upslope. Of course the amount of "slip" depends on the converter.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 09-18-2024, 11:41 AM   #27
BRL
BRL's Avatar
Originally Posted by pjmoreland View Post
I had a '67 C10 that was ordered originally with 4:10 gears. I put a 350/350 combo in it, and it was miserable on the highway. I swapped in 3.08 gears, which made it great for highway cruising. I drove that truck between California, Colorado and Oregon many times over the years I owned it. A set of 3.08 gears would drop you from 3300 down to 2700. The down side, of course, is that you will end up with a very sluggish first gear.
That's exactly what I had and exactly what I did and I couldn't be happier!
As far as a sluggish 1st gear goes I have what I consider to be a rather healthy low end torque engine and I don't drag race the truck.
This pickup has plenty of pick-up!
God I'm witty.
BRL is offline   Reply With Quote
Old 09-18-2024, 05:25 PM   #28
MikeB
MikeB's Avatar
My truck has a 3.08 posi behind a mild 350, and will spin the tires for 50 ft if I stomp on it in first gear. PJ, you must be one of them there hotrodders with a big cam and 850 double pumper.
Mike
Old 09-18-2024, 06:43 PM   #29
slikside
slikside's Avatar
350 yes, Tach yes, 3 speed manual, so at highway it would be sam as T350. Rpms are about 2300 at 70MPH, 60 is a hair over 2K. 265/70x16 tires or about 30.5 in high
Yeah, mine came out similar on Geezer’s calculator. I have 30” tires.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 09-18-2024, 06:54 PM   #30
pjmoreland
pjmoreland's Avatar
I did that swap 27 years ago, and I'll admit the gas pedal spent a decent amount of time mashed to the floor back then. I had a 70s smogger 350 with a stock cam, so it was nothing too crazy. With the 4:10 gears it would squeal the rear tires effortlessly. Not so much with the 3.08 gears.
A few years later I swapped in a 300HP crate 350 to liven things up. The younger brother of an ex-girlfriend asked to borrow my truck for a high school day at the local drag strip. My truck did quite poorly that day, getting 17 second quarter mile. I ended up installing 3.73 gears after that, but once again it was miserable on the highway.
pjmoreland is offline   Reply With Quote
Old 09-18-2024, 06:56 PM   #31
jocko
jocko's Avatar
custom10nut, if you share your tire diameter we can tell you exactly what your current rpm is at various speeds and what it would be with different trans and/or rear gearing at various speeds. Engine size and observed tach/mph readings aren't relevant.
Old 09-18-2024, 09:56 PM   #32
custom10nut
custom10nut's Avatar
You haven't mentioned what size rear tires your running. For my GTO with a T400 3.55's with a 26" tall tire was perfect for me. But I wouldn't have been happy with 28" tires.
In my Burban I run 3.73's with a Gearvendor (Which I got off Craigslist for $600. It was the 3rd one I've bought used.) on 28" tall tires.
275/60/15 BF Goodrich T/A Radials.
I think they’re 29 or 30 inches tall
Is realist here.
I never going to chase the dream of 18-20mpg (right now I get about 15 Hwy)
My concern is the constant running at 32-3300 rpm at 70-75.
Oh the truck will easily do it, but I don’t want to abuse the engine.
custom10nut is offline   Reply With Quote
Old 09-18-2024, 10:36 PM   #33
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Is realist here.
Your 275/60 15's are 28 inches tall.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 09-19-2024, 09:21 AM   #34
jocko
jocko's Avatar
the actual RPM your truck is experiencing in the upper left red box - along with various trans and gearing combos that have been mentioned in the thread. Obviously you won't want to do BOTH an O/D and 3.08 gearing - they're just listed for reference only. It shows why 3.73/700R4 is such a popular option (and why GM built zillions of modern 1/2 ton trucks this way) - it improves 1st gear acceleration and also reduces your cruising rpm more than a 3.08 does. But, several options can get you closer to what you're trying to achieve. Hope this helps!
Old 09-19-2024, 02:48 PM   #35
MikeB
MikeB's Avatar
Nice charts! Interesting to see the RPM increases from 55 to 65 and 65 to 75. More than I would have guessed off the top of my head.
Looks like the TH350 numbers assume no converter slip at all, which rarely happens even on a level highway.
Mike
