Old 09-20-2024, 04:12 PM   #26
leegreen
Re: No spark
does it run if you take a jumper wire from battery to distributor as was suggested ?
You have a stomp starter so the starter solenoid wires in harness are probably unused
I think I'd take the switch out and test it's function with a MM or test light. If it only has off and on, how many terminals does it have? 55-59 have more than 2. Where does your ACC connect?
leegreen is offline   Reply With Quote
Old 09-20-2024, 06:29 PM   #27
popeyestruck
Re: No spark
there are 5 terminals bat ,sol,acc,ign and ground and its a 2 position switch. The acc goes to a 6 position plug for fuel pump ,power seats,power locks,cruise,power windows and CB . They are just a source for 12 volt power. ive tested the ignition switch and only the Batt and AC get power. I tested the old switch that worked when removed and its the same way. I guess I'm missing something. I've rebuilt old harley switches that are 3 position where the 3rd run position is just an internal jumper bar but this is a 2position. I havent jumped the distributor direct from the battery yet. Not really ready to check that if I dont at least have power to the distributor
popeyestruck is offline   Reply With Quote
Old 09-20-2024, 07:34 PM   #28
leegreen
Re: No spark
do the colors you mention correspond to 1950s wiring ?
https://chevy.oldcarmanualproject.co...ring/index.htm
this is '55 truck from link above
Name:  Screenshot 2024-09-20 161836.jpg
pink here appears to be for accessories and dk green from ign1 to coil, violet from ign 2 to starter (does that energize the foot starter or something?)
this section is interesting,
Name:  Screenshot 2024-09-20 162651.jpg
this resistor, if you trace it back appears to take power from ACC through the resistor and to the coil and back to IGN. Maybe ign1, 2 is not switched inside the switch it is just a pair of connectors??
Post # 10 here by mr48chev hints at some knowledge here? and he posted the same diagram.
Old 09-21-2024, 09:01 AM   #29
popeyestruck
Re: No spark
OK . I put everything back together and I now have an energized pink wire. I dont know what I did. Might have been grounded or pinched wire or maybe it is a bad switch. I'm going to put the battery on the charger and try it in the morning. Dont want to rwsh low voltage going to the HEI
Old 09-22-2024, 08:02 AM   #30
popeyestruck
Re: No spark
IT RUNS!!!! Started right up . 235 is so quiet you can hardly hear it run. Got a little leak on the power steering line should just need tightening. I'll post a video if I can. Thanks to everyone
Old 09-22-2024, 10:28 AM   #31
dsraven
Re: No spark
Perfect. Good to hear. A video would be great.
Old 09-22-2024, 06:48 PM   #32
mr48chev
mr48chev's Avatar
Re: No spark
Cool Beans. Now we can look forward to that first drive video.
My ongoing truck projects:
