Old 10-01-2015, 01:53 PM   #1
64_4X4_CustomCab
350 or 400 Pontiac engine in '64 4X4?
I'm a newbie to the forum and I need some help with my 1964 Chevy C10 step side big back glass truck that is sitting on a 70's - 80's 4X4 frame. It doesn't have an engine nor a transmission. I have the opportunity to purchase a complete (carb to oil pan) Pontiac 350 out of a '68 Firebird, a Pontiac 400 short block and 2 Turbo 400 tranny's for a good price. I plan on using the truck just for fun and not planning on restoring it to original condition (more like a rat rod without the extreme modifications).
What's everyone's thoughts and things I need to think about in deciding if either of these engines are good solutions for the truck? How different are Pontiac and Chevy engines of the same cubic inch?
Thanks in advance for your input. I look forward to hearing everyone's thoughts.
64_4X4_CustomCab is offline   Reply With Quote
Old 10-02-2015, 03:28 AM   #2
scuderia
scuderia's Avatar
Re: 350 or 400 Pontiac engine in '64 4X4?
Pontiac parts are more $$ than chevy and fewer choices..
'66 C10 SWB
'64 C2 roadster
'38 Indian Scout Flattracker
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline   Reply With Quote
Old 10-03-2015, 09:02 AM   #3
63 & 64 Bowties
and a few others
Welcome to the forum.
I moved this for ya. You had posted in the Projects & Builds section which is for ongoing projects. I moved it into the general question area.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 10-03-2015, 06:44 PM   #4
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Welcome to the board!
If you can take on a Pontiac 400 build, you can create a
monster of a motor but, yup, it can get quite pricey.
Good luck whatever you decide!
ET
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 10-03-2015, 07:37 PM   #5
aotte1
Chevy 350 has several pros:
o as stated above, it will cost you the least for the same parts/build,
o you can get latest technology,
o their are more high performance/efficient parts and easy to find,
o and lots of knowledge out their.
aotte1 is offline   Reply With Quote
Old 10-03-2015, 09:20 PM   #6
jdl71
jdl71's Avatar
The TH400's (or whatever trans you decide to use) will have to be BOP (Buick Olds Pointac) specific as the poncho bellhousing pattern is different from SBC. Do you have or are going to use a transfer case? If so, you will need a 4wd trans also. Might be simpler to find another squarebody (73-87 chevy/gmc) 4x4 drivetrain.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 10-03-2015, 09:53 PM   #7
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
speedway motors does sell an adapter plate to use the BOP trans, or motor w/ a chevy, or vise versa.
I put a 455 pontiac in my 63, however mine is 2wd, so I was able to use the 2wd BOP trans with the motor.
your 73-87 4x4 chassis will have side mounts, and the Pontiac should just slip in without too much hassle, Pontiacs have the starter and fuel pump on the drivers side, so you will have to re-route the fuel lines and battery/ ignition cables
here is a link to the adapter plate:
http://www.speedwaymotors.com/Chevy-...late,3281.html
Old 10-03-2015, 10:01 PM   #8
jdl71
jdl71's Avatar
I guess there probably is no such thing as a BOP trans that would bolt to a t-case adapter is there?
Psalm 23
64 C10
66 K20
Old 10-04-2015, 11:17 AM   #9
'63GENIII
'63GENIII's Avatar
I think that GMC ran Pontiac V8 engines in their trucks as early as '58? It would definitely be different. Im sure that you could take a BOP pattern auto trans and mate it to just about any transferase you used. Id be curious to know if you could do the same with a manual trans if you had the BOP bell housing. My kid brother has a lot of Pontiac stuff at his shop. Not as cheap as a Chevy to build but if you're getting a great deal on the Poncho, then why not rock it?
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 10-04-2015, 02:34 PM   #10
Gargoyle
Gargoyle's Avatar
GMC used the Pontiac V8 in some trucks from 1955-59. The Pontiac is a great engine, lots of low-end torque and likely will get better gas mileage than a comparable small block chevy. That being said, the Chevy engine can be bought off the shelf with good power and should to be easier to install.
If I ever find a project 60-66 suburban it will definitely be getting a Pontiac mill.
Gargoyle is offline   Reply With Quote
Old 10-04-2015, 02:37 PM   #11
jdl71
jdl71's Avatar
A manual I would think would be easy, if you had a divorced t-case. I suppose you could do the same with an auto? What I was unsure of is if the BOP auto's had a removable tail shaft so you could use the t-case adapter for non divorced applications.
Psalm 23
64 C10
66 K20
Old 10-05-2015, 05:19 PM   #12
GRX
GRX's Avatar
I have been building Pontiac engines for over 30 years. Their design makes torque down low so they can be great truck engines. Of those two I would choose the 400. Better power potential. Pontiac are more expensive to build than small block Chevy. Not as much as it used to be though. They have had a big resurgence in popularity the last 10 years or so with a much more vibrant aftermarket than previously.
GRX is offline   Reply With Quote
Old 10-07-2015, 12:03 AM   #13
64_4X4_CustomCab
I greatly appreciate all the input guys. I'm a little leary of the Pontiac engines just because I don't know what I'm getting myself into. My goal is to get the truck driveable as easily and as inexpensively as possible.
I have an opportunity to get a 454 for $500 but I think it's more engine than I want and will wind up costing me more than I want to pay.
I'm seeing quite a few 350's pop up on Craigslist this week so I think I'm going to try to go with a Chevy 350 with either a Turbo 350 or 400 tranny.
Thoughts?
Old 10-12-2015, 01:59 PM   #14
GRX
GRX's Avatar
Just now saw your last post. Given your experience & budget restrictions, sticking with a chevy is definitely your best bet. Easiest would be stay with what it is set up for already. Small block. Big block. Straight 6. What ever.
While pontiac only had one engine family from 287 to 455 cubes - no big or small block, building one is not a one size fits all deal like chevys. Differences in timing cover/water pump designs, intake exhaust cross-overs, and motor mount location from year to year can make things difficult.
Old 10-12-2015, 09:00 PM   #15
64_4X4_CustomCab
Thanks folks! A friend donated a 1986 Chevy C20 to the project. It's been sitting for 10 years but has a fully intact 350 engine and an automatic transmission.
Got to get the engine and transmission out of the truck and determine the condition. Definitely planning on rebuilding it.
Want to build it to pull a trailer hauling project cars / trucks. Any suggestions?
Old 09-24-2024, 09:53 AM   #16
D'Monsta
D'Monsta's Avatar
I know this is an old thread and I hope you are doing well. I wonder if you ever found your project and puta Pontiac engine in it? I'm trying to find out if the motor mounts/perches are in the right place for a 389 Pontiac to sit right under the hood and be able to use the same driveshaft? My truck is a 66 GMC with straight 6.. Any idea?
D'Monsta is offline   Reply With Quote
