Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 09-22-2024, 07:14 AM   #3726
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Tiger hair should fill
image by [url=https://www.flickr.com/photos/97391199@N06
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-22-2024, 08:25 AM   #3727
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Just like my trunk of my ‘62 impala , no turquoise though
Have to wait 2days for it to dry
SAFETY FIRST
AS usual, off topic
Jim
Old 09-25-2024, 11:00 AM   #3728
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Next step 3 M 08115 body panel adhesive
Must have used a can opener to cut
SAFETY FIRST
AS usual, off topic
Jim
Old 09-25-2024, 11:28 AM   #3729
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Coating not as durable as expected failed wire brush test
SAFETY FIRST
AS usual, off topic
Jim
Old 09-26-2024, 10:46 AM   #3730
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Before degreasing, deburring can wait as ppp smells volatile and sparks from dremel could have bad results
SAFETY FIRST
AS usual, off topic
Jim
Old 09-27-2024, 10:32 AM   #3731
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
image by image by [url=https://www.flickr.com/photos/97391199@N06
Don’t know how CC snuck in
SAFETY FIRST
AS usual, off topic
Jim
Old 09-27-2024, 04:41 PM   #3732
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Failed the scratch test, tried putting paint on top, didn’t work
SAFETY FIRST
AS usual, off topic
Jim
Old 09-29-2024, 09:45 AM   #3733
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
SAFETY FIRST
AS usual, off topic
Jim
Old 09-29-2024, 10:17 AM   #3734
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
PPE required dust may be caustic or down right deadly
SAFETY FIRST
AS usual, off topic
Jim
Old 09-30-2024, 10:40 AM   #3735
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
After reading precautions I decided to try a file and keep the dust as minimal
Using a rat tail lends itself to follow the contour of the sheet metal sort of gauging out an area to be filled later with?
SAFETY FIRST
AS usual, off topic
Jim
Old 10-01-2024, 11:59 AM   #3736
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Second application
Trying plug weld lower left
SAFETY FIRST
AS usual, off topic
Jim
Old 10-01-2024, 12:54 PM   #3737
litebulblsc
litebulblsc's Avatar
Re: PO has me PO'd
I would stick to the panel bond for gluing 2 pieces together.
Then switch to the tiger hair for filling in the low spots.
I am going to guess less then favorable results filling in the bolt holes. Probably best to glue small patches underneath and tiger hair over top.
litebulblsc is offline   Reply With Quote
Old 10-02-2024, 12:21 AM   #3738
Grounded63
Re: PO has me PO'd
You can tool the panel bond out with a body filler squeegee. Just like you would with glazing putty. That should reduce the amount of sanding and reapplying you need to do. Depending on ambient temps it can definitely feel thicker/stickier than glazing putty. But, it still spreads out fairly well.
If you want to fill those screw holes with it. Chamfer both sides of the holes you want to fill. And clean the the surrounding area to bare metal with a 36 grit disk. Just like when you're bonding two body panels together. Then fill the holes and spread a thin skim coat of the panel bond over the top. If you do any finish sanding afterwards. There should still be a skim coat of panel bond surrounding the holes. I would not do this for any exterior body panels.
Grounded63 is offline   Reply With Quote
Old 10-02-2024, 08:31 AM   #3739
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks. First time I have used this, thanks for the tips
SAFETY FIRST
AS usual, off topic
Jim
Old 10-02-2024, 08:36 AM   #3740
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I should have thought of the squeegee but I wasn’t thinking and in a hurry. So, today we’ll see what happens
Are you saying not to use this product to hang body panels, because that was my main purpose to try it out
SAFETY FIRST
AS usual, off topic
Jim
Old 10-02-2024, 10:18 AM   #3741
Grounded63
Re: PO has me PO'd
No, it's made for hanging ( mostly non structural ) body panels. Gluing some pinch seams together in place of spot welding.
But, it shouldn't be used like a filler or have an exposed Seam in the middle of a exterior painted panel. Like if it was used to fill the roof to B pillar lead seam on a car. Or like a partial lower quarter panel replacement that was flanged. If the panels were panel bonded at the flange and the seam was filled in with panel bond. Then just sanded flat, epoxied, 2k surfacer, blocked, sealed, top coated, cleared. That " exposed " panel bond Seam has a tendency to " shadow " through the primer/top coats.
Old 10-03-2024, 06:52 AM   #3742
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks for the explanation
SAFETY FIRST
AS usual, off topic
Jim
Old 10-04-2024, 06:13 AM   #3743
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Well,it does seem to work for a plug weld
SAFETY FIRST
AS usual, off topic
Jim
Old 10-04-2024, 07:55 PM   #3744
litebulblsc
Re: PO has me PO'd
I see you are selling some of your stuff from this like the half top, hopefully everything is alright?
Old 10-06-2024, 02:39 PM   #3745
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks for checking on me
I just ran out of money to finish the truck
I may even sell my speed minder, tach, 60pound oil gauge cluster, tilt column to finance the project, but I hope it doesn’t come to that……
Tags inspection, insurance
SAFETY FIRST
AS usual, off topic
Jim
Old 10-07-2024, 11:24 AM   #3746
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Using texture and color to hide my lack of body work skills
1st coat
SAFETY FIRST
AS usual, off topic
Jim
Old 10-07-2024, 08:53 PM   #3747
zicc1835
zicc1835's Avatar
Re: PO has me PO'd
[quote=jaros44sr;9345730]Using texture and color to hide my lack of body work skills
1st coat
image by [url=https://www.flickr.com/photos/97391199@N06[/quote]
looking better
zicc1835 is offline   Reply With Quote
Old 10-08-2024, 09:32 AM   #3748
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Originally Posted by zicc1835 View Post
looking better
is that motor running yet?
Lends itself to matching with deburring tool
SAFETY FIRST
AS usual, off topic
Jim
Old 10-09-2024, 10:48 AM   #3749
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Leave well enuff alone
K2
SAFETY FIRST
AS usual, off topic
Jim
Old 10-11-2024, 08:55 AM   #3750
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Sometimes you just can’t drill a hole and a punch is a better method
Closing in on 800,000, thank you for all the support
SAFETY FIRST
AS usual, off topic
Jim
