Old 10-02-2024, 05:43 AM   #1
Dude68
Active Member
68 wiper motor gasket/seal
Had some rust damage on wiper motor hole in cowl. Ordered a replacement gasket from GMC Paul's. The hole on this gasket it quite a bit smaller than the original one. Are these made to cut? Am I missing something?
Joey
Dude68 is offline   Reply With Quote
Old 10-02-2024, 11:50 AM   #2
pjmoreland
pjmoreland's Avatar
Re: 68 wiper motor gasket/seal
I got one of those from GMCPauls and it fit just fine without any cutting.
pjmoreland is offline   Reply With Quote
Old 10-02-2024, 02:26 PM   #3
Dude68
Active Member
Does the lip that is on the hole in cowl press into the gasket?
Joey
Old 10-02-2024, 02:29 PM   #4
pjmoreland
pjmoreland's Avatar
I don't know. I just bolted it up. It hasn't leaked.
Old 10-02-2024, 04:08 PM   #5
Dude68
Active Member
I will post a pic when I get home
Joey
Old 10-02-2024, 06:44 PM   #6
Dude68
Active Member
Here is a pic of a piece of the old gasket lying on top of the new one. And another pic of the piece of old gasket in its original position on the wiper motor.
Joey
Old 10-02-2024, 06:52 PM   #7
Dude68
Active Member
Here is a shot up under the dash, the non rusted part has a flange. All of the gasket was rotted out when we pulled the wiper motor. Ordered the gasket and built a piece to epoxy based on the pattern of the old gasket. This new one does not match the outline on the wiper motor from the old gasket in the previous pic. The gasket will fit the wiper motor, but not around this hole in the wiper motor mount.
Joey
Old 10-02-2024, 07:03 PM   #8
pjmoreland
pjmoreland's Avatar
Will the new gasket fit around the rubber seal on your motor?
Old 10-02-2024, 07:21 PM   #9
Dude68
Active Member
yes
Joey
Old 10-02-2024, 07:41 PM   #10
pjmoreland
pjmoreland's Avatar
The little lip on the cab mounting surface will likely just pierce into the seal, which may actually enhance the tightness of the sealing.
Old 10-02-2024, 07:50 PM   #11
Dude68
Active Member
That's what I was wondering. Used a compass and built a piece based off of the old gasket. Made it out of epoxy with the lip. It is strong but not sharp enough to pierce the gasket. Might just grind it flat and work from there.
Joey
