Old 08-09-2024, 07:48 PM   #401
clay68c10
clay68c10's Avatar
Re: ClusterTruck; because that’s what it is
First I needed to strip the front edge and see what I'm dealing with. None of it looked bad from the outside.
Luckily, the back side if the hood makes it clear where the holes go. It's a double wall so the inner holes were still there.
I used my square and a "precise" eyeball and marked the locations.
Then I grabbed one of my smallest drill bits and made a starter hole. I figured (correctly) that the little guy wouldn't grab and tear. I could feel it want to get off center sometimes, but it didn't have enough flute to grab sideways.
Now I could look from the back side and verify that I had the hole centered, and if not, which direction I needed to go. All the holes were very close.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 08-09-2024, 07:53 PM   #402
clay68c10
clay68c10's Avatar
At this point I was ready to enlarge the hole.
First I carefully used a thin stepped drill. It worked ok initially, but when it caught on the uneven back side the tip broke off. No bueno. At least it didn't harm anything.
Next up was a thin tapered die grinder bit. I used it in my drill vs a die grinder. That gave me better control and it didn't want to bounce around like they sometimes do in thin material at high speed.
It ended up being the best tool for the job, hands down. It didn't cut too quickly, it cut evenly, and it didn't catch. The only thing it did on the thicker weld globs was cut slower because the material was thicker.
Success!
13 Tahoe LTZ
Old 08-09-2024, 11:22 PM   #403
ryans69chevy
That color looks so good. Pickup is coming together nicely. Where did you get that sound deadening/heat shield material? I found someone local I can get dynamat. Im looking for a product to put between my roof panels since I have the roof skin off. Was hoping to find a product for both sound and heat.
ryans69chevy is offline   Reply With Quote
Old 08-10-2024, 12:59 AM   #404
clay68c10
clay68c10's Avatar
Thanks!
I bought my sound deadening directly from siless. They had and may still have free shipping. I’ve heard good things about their products.
13 Tahoe LTZ
Old 08-12-2024, 09:12 AM   #405
loudchevy
loudchevy's Avatar
Good progress. The die grinder bit in the drill was a great solution for those holes.
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is online now   Reply With Quote
Old 09-01-2024, 09:52 AM   #406
clay68c10
clay68c10's Avatar
It sure worked better than just drilling. Especially if you were redoing closed up side trim. That could go south pretty quickly.
If I can save someone else that hassle then I’m happy.
13 Tahoe LTZ
Old 09-01-2024, 10:15 AM   #407
clay68c10
clay68c10's Avatar
Now that the trim holes were located again, the hood went to the blaster. I had some $ scraped up and frankly was sick of the work it took to strip these panels. I had just finished stripping the fenders and really thought about the flat surface of the hood and how I could possibly mess it up, even with the fairly low heat generated by the stripping tool. Also the edges and braces would be a ton of work. So it went to the media blaster. I’m going to do the same with the bed sides and floor.
There was some ancient hail damage uncovered. Must have been from the white paint days since I couldn’t see it in the red version. Dave got the hood in skim and got after it. I’ll have to get a shot of it sanded out and flat.
That’s his laser straight Chevelle in the background. I’ll be helping him out with that. It’s getting a built 6.0/T56. Should be a fun one.
13 Tahoe LTZ
Old 09-01-2024, 10:29 AM   #408
clay68c10
clay68c10's Avatar
I’ve been wanting to learn more techniques for block sanding the skim coat so I started working on the front fenders. It is definitely a good bit of work and does require some technique. The long semi rigid blocks really do work. The use of powder guide coat really takes relying on the “calibrated hand” to determine how flat the panel is out of the equation. If there is a low spot, you will absolutely see it. The only places you really need to feel are the curved body lines. Those are more tricky and I got them close, but let the pro get them that last bit.
It took several hours for each fender, but they’re straight and flat now. Next step is high build and more blocking with guide coat.
These pics are from about the 80% done point.
13 Tahoe LTZ
Old 09-30-2024, 10:21 PM   #409
clay68c10
clay68c10's Avatar
I’ve been busy, but not with posting updates…..
The Tahoe seats I’m using came with the seatbelts and retractors. I had set them in place previously, but hadn’t come up with any mounting solutions.
I knew I would need a bracket for the retractor, but I hadn’t figured out the pillar mount.
This was one place where I got lucky. The thread pitch was the same across the years, or a convenient overlap of SAE and metric threads. I had to search thru my washer pile to space the pivot out so it wouldn’t rub. Also, the Tahoe pillar mount was chrome underneath the plastic cladding and actually looks pretty nice as is.
13 Tahoe LTZ
Old 09-30-2024, 10:29 PM   #410
clay68c10
clay68c10's Avatar
The bottom mount wasn’t too difficult, I used some 1/4” plate and adapted from the factory mount.
I did have a “cheat code” tool for bending the plate the first 90deg. I used the regular press to get the additional 10deg.
Without the Scotchman, I would have used a regular press and made due.
13 Tahoe LTZ
Old 09-30-2024, 10:47 PM   #411
clay68c10
clay68c10's Avatar
One more random little time eater was the r/f fender brace. I had to notch it out because I was mounting the LS air filter housing on that side.
Cut and weld and grind and etc…. It came out pretty nice.
13 Tahoe LTZ
Old 10-02-2024, 10:24 PM   #412
clay68c10
clay68c10's Avatar
On to the HVAC boxes.
The parts I got were not in great shape, they had been sitting outside and were solid but sun bleached. That was a fun purchase. Some very sketchy dude had these parts for cheap but I had to go into his backyard to get them. He was nice but really weird, as was his buddy living in the immobile clapped out motorhome in the yard.
At least the pieces were cheap and usable. And I didn’t end up a picture on a milk carton.
I would have liked them to be that cool original grey/brown color but that ship had sailed.
Semigloss black it is. I actually painted these parts 3-4 years ago and they’ve been in my attic.
I installed a square body evaporator and repurposed the POA bracket to hold the accumulator with the old cut/splice/weld method. I figured using a big hose clamp was factory-esque and functional.
I tested the recirc door actuator and it held vacuum for 24hrs. Not bad for a 50 year old part. The inside one passed the test also!
13 Tahoe LTZ
Old 10-02-2024, 10:37 PM   #413
clay68c10
clay68c10's Avatar
It all looked good until I put the inner fender on for a reality check.
That bottom exit accumulator was not going to clear. At least they’re cheap and GM had a few different styles.
With a different part on there my low side hose would clear. I did dimple the inner at the bottom of the accumulator since I’m not sure where it will end up with the fenders attached.
13 Tahoe LTZ
Old 10-03-2024, 09:40 AM   #414
SCOTI
SCOTI's Avatar
Nice progress.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-05-2024, 10:27 AM   #415
clay68c10
clay68c10's Avatar
Originally Posted by SCOTI View Post
Nice progress.
Thanks SCOTI, just trying to do a little something at least a few times a week. It feels like I haven’t done much of anything until I look back thru my photos. It seems the small things eat up a ton of time too.
Saying that, my hydroboost hose situation is one of those time consumers.
I had saved the original hoses from the 79 P30 motorhome, knowing they probably wouldn’t work but could be an idea generator. They were definitely too short and had most of the bends in the wrong places.
So I figured a set from a square body might be close. Yeah maybe not. I fitted the pressure out side from the pump and it was the wrong angle at the pump. I bent that end to get it to work, but the whole line and routing were so-so. Then the booster to box line. Way too long.
But, if anyone out there has a square body LS swap with hydroboost, I have a ready to go hose set for you. Seriously, just pay for shipping and it’s yours.
13 Tahoe LTZ
Old 10-05-2024, 11:10 AM   #416
clay68c10
clay68c10's Avatar
So, options for the hoses;
Keep trying factory hoses and bend them to sorta fit
Use AN adapters and hoses like a lot of folks do
Something else…???
The off the shelf hose option is fairly cheap, but how many of these sets will I have to buy to get one that works?? I don’t have an assortment at my disposal to try so it could be many.
AN stuff? I’m not a huge fan because of the price and the adapters needed. That sounds like more potential for leaks and complications.
Time to go into the rabbit hole of hydraulic hoses and fittings. That took some research but was very informative.
There’s a variety of hoses and ends, and they have to be the same mfg/style. The most common for 3/8” (-6) is Parker 43 style.
Parker 43 style fittings have a flare to -6 connector series. There’s also o-ring style fittings available if you’re running that type.
There are a few hose types, but what we need is fairly low pressure (<2000psi) and not super expensive.
The shop next to my work has a 43 style crimper and I have a buddy there, so a little science experiment was in order.
13 Tahoe LTZ
Old 10-06-2024, 08:05 AM   #417
72 tigger
72 tigger's Avatar
I really appreciate your attention to detail- nice work!
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 10-06-2024, 12:15 PM   #418
CG
BlahBlahBlah
I think you should make the Tahoe seat belt idea its own thread. I think that's a really interesting solution for installing new belts with the shoulder harness feature. Or maybe its already been done by someone and Ive missed it.
Old 10-11-2024, 10:21 AM   #419
raggedjim
raggedjim's Avatar
Nice work! Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 10-15-2024, 08:00 AM   #420
clay68c10
clay68c10's Avatar
Originally Posted by raggedjim View Post
Nice work! Rg
Thanks all, I appreciate it. Hopefully I don't have to go back and re-do any of this stuff later.
The Tahoe belts are handy if you're running the matching seats. The buckle is built into the seat frame.
13 Tahoe LTZ
