Old 10-04-2024, 09:33 PM   #1
saddletramp
72 Steel bed to Wood ?
Evening Guys can someone help me with swaping from steel bed floor to wood I've got the cross sills from MarK and I spoke to a sales person at Bed Wood he told me to find out and let him no where they can drill the holes in the Wood for my 72 GMC Fleetside long bed to bolt down would it be the same pattern from 71or 70 Wood beds Thanks Saddletramp
saddletramp is offline   Reply With Quote
Old 10-04-2024, 09:41 PM   #2
Getter-Done
Getter-Done's Avatar
Re: 72 Steel bed to Wood ?
There is a member doing this.
Let me see if I can find the thread.
Are you going to C10 Nationals tomorrow?
84 Chevy K-20
Old 10-04-2024, 09:49 PM   #3
Getter-Done
Here's the first thread that came up.
Link: https://67-72chevytrucks.com/vboard/...d+to+steel+bed
84 Chevy K-20
Old 10-05-2024, 12:35 AM   #4
mr48chev
mr48chev's Avatar
I've got a too banged around to use 68 long bed fleetside box on a trailer that has a wood bed that has/had a wood bed that is probably only good for parts for a conversion that I would let a member haul off if they needed it. It's sitting on a 70 frame made into a trailer that is the worse towing trailer I ever built.
My ongoing truck projects:
Old 10-05-2024, 08:25 AM   #5
Jason Banks
Jason Banks's Avatar
If you have the Mar-K cross sills, you can install the bed with the bolt heads concealed. You have to rout a recess in the bottom of the boards for the bolt heads, though.
On the Mar-K cross sills there are square holes where the bed bolts go, to capture the square on the carriage bolt. So, you put the bolts in the cross sill and the wood on top. It's a very clean look.
Jason Banks is online now   Reply With Quote
Old 10-05-2024, 09:10 AM   #6
saddletramp
Thanks Guys for the response I like that Wood over steel bed but I can't afford that just retired and yes I'm going to the C-10 National,s Sunday I'll be taking alot of Pictures Saddletramp
Old 10-05-2024, 04:42 PM   #7
LS short box
Per the pic above I routed some recesses in the bottom of the bed wood.
My 68 project.
Old 10-07-2024, 01:40 PM   #8
crazyjeenyus
crazyjeenyus's Avatar
You'll need to replace or modify the front bed panel. The ones that were used with the wood floor beds are slightly taller than the ones that were used with steel beds due to the extra thickness of the wood compared to steel.
'67 c10 cst farm truck
crazyjeenyus is offline   Reply With Quote
Old 10-07-2024, 10:26 PM   #9
Getter-Done
Great info you just pointed out.
The Header panels are different.
P. S. Not to derail the thread.
I met a Guy from Alberta at C10 Nationals.
He had a Show Winning 67.
He gave me and my nephew and his friend this sticker.
84 Chevy K-20
Old 10-08-2024, 12:35 AM   #10
crazyjeenyus
Haha, that’s awesome. Reminds me of the license plate I saw on an old shoebox Ford lowrider: “Praise the Low’rd”
