Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 10-05-2024, 11:48 AM   #1
weq92f
weq92f's Avatar
nylock vs. lock washer...which is best?
Kinda surprising results...
https://www.youtube.com/watch?v=pDZ8PezMzzY
What if you use both at the same time...
https://www.youtube.com/watch?v=Iao2HT71kB8
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 10-05-2024, 12:18 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: nylock vs. lock washer...which is best?
Not surprising that the lock washer case came loose. The washer wasn't completely compressed. He should have done this test with the recommended torque of 31 Ft-Lbs for this type fastener.
~Steven
Simi Valley, CA
Old 10-05-2024, 12:48 PM   #3
weq92f
weq92f's Avatar
Agreed...more torque would have definitely made a difference. The video is far more interesting at 6lbs though!
Another issue that stands out is...those nylock nuts I've dealt with required more than 6lbs just to turn so trying to torque them down at such a low value seems inaccurate at best.
-Kevin
Old 10-05-2024, 12:56 PM   #4
truckster
truckster's Avatar
I actually posted that as a comment in the video when I first saw it. It's impossible to test a fastener's holding power unless it's properly torqued.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 10-05-2024, 01:57 PM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
-Kevin
Right, he completely ignored the running torque of the nylock nut.
~Steven
Simi Valley, CA
Old 10-05-2024, 04:32 PM   #6
LS short box
On my hot rod projects I use grade 8 bolts and grade 8 nylocks. One of the reasons I use nylocks is that when you use a washer it doesn't crack the paint or powder coat. Never had one come loose.
Old 10-06-2024, 07:28 AM   #7
jjzepplin
jjzepplin's Avatar
I am sort of a redneck and grew up on a farm. Each type of bolt has it's rightful place to be used. If a nylock gets hot it's not going to hold the same. I like lock bolts but they bugger the threads after the first use. I use lock washers if I run out of nylock bolts and can't get to the store. I used to take a standard bolt and put it on a vise and bang it with a hammer to make it slightly out of round and boom-lock bolt. I have always wondered how a lock washer on top of a standard washer holds with a standard bolt.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 10-06-2024, 03:47 PM   #8
HO455
HO455's Avatar
Caterpillar machinery quit using lock washers many decades ago. They use grade 8 fasteners and under every nut or bolt head, there is a hardened flat washer. Some fasteners are required to have Loctite.
If you ever have an opportunity to buy a junk Cat engine for cheap, do it the as fasteners are some of the best around.
RIP Bob Parks.
Old 10-06-2024, 06:54 PM   #9
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
agree.
I wonder if he's tested torque nuts? Bet they beat nylon/split washer to )_&_&+, though been wrong before.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 10-06-2024, 08:46 PM   #10
Steeveedee
Who Changed This?
Steeveedee's Avatar
OK, I had to go look that up. I've seen those used on truly ancient MOPAR products, like my dad's '51 Dodge truck- "ancient" meaning that that truck was one year older than I. Dodge Bros did things a bit differently, like left hand threads on the left side of the vehicle. They may have worked better, I have no idea. I note that cotter pins are far more common now, and MOPAR has gone to all right hand threads(?).
~Steven
Simi Valley, CA
Old 10-07-2024, 11:44 AM   #11
kwmech
Moot point and a waste of a video and everybodys time if the fastener was not torqued to specs
Old 10-07-2024, 05:51 PM   #12
72c20customcamper
72c20customcamper's Avatar
Red loctite .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 10-08-2024, 07:47 AM   #13
biketopia
Wedge Lock washers have been our go to around the shop in recent months.
https://www.nord-lock.com/nord-lock/products/washers/
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 10-09-2024, 09:13 PM   #14
Willie Makeit
Willie Makeit's Avatar
Split washers, also known as lock washers, are useless as a locking feature. Don't believe me? Ask NASA: they do NOT allow split washers on anything. Period.
ALL fasteners are torqued to a given spec and then it's either a mechanical locking features such as a poly-loc nut, safety wire, or distorted nuts OR chemical thread locking compounds such as Loc-Tite. Oftentimes it's multiple features.
This applies to ALL fasteners.
NASA publication RP-1228, pp. 9-10
Willie Makeit is offline   Reply With Quote
Old 10-09-2024, 09:43 PM   #15
mongocanfly
mongocanfly's Avatar
Hard to beat a good crossthread....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 10-10-2024, 06:24 AM   #16
Keith Seymore
Keith Seymore's Avatar
Thank you -
Those were my thoughts as well.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-10-2024, 06:53 AM   #17
biketopia
Old guy at the gas station I started at "cross thread is better than lock-tite"
Old 10-10-2024, 07:23 AM   #18
Boog
laying low
Boog's Avatar
^^^ Hands down!
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 10-10-2024, 10:33 AM   #19
Steeveedee
Who Changed This?
Steeveedee's Avatar
DoD, same way. I've worked on several spacecraft programs (MILSATCOM, Missile Defense, various civilian) and there are no lock washers to be found. If it didn't have a thread-locking compound, it was lock wired.
~Steven
Simi Valley, CA
Old 10-15-2024, 10:59 AM   #20
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Except for the Ground (Auto) Side.....Had Bins full of lock washers. Even had National Stock Numbers (NSNs) for a washer kit.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
