Old 10-06-2024, 09:32 AM   #1
NorthernMatthew
NorthernMatthew's Avatar
Need Part# for Delco Remy High Note Horn
Good day folks! I’m going go try track one of these down to install in the 72 K5, would one of you know the GM part number for it?
NorthernMatthew is offline   Reply With Quote
Old 10-06-2024, 10:00 AM   #2
chewychevy67
Re: Need Part# for Delco Remy High Note Horn
9000011 I believe is the high note horn
chewychevy67 is offline   Reply With Quote
Old 10-10-2024, 01:06 AM   #3
NorthernMatthew
Thank you very much! Wish me luck!
Old 10-10-2024, 08:42 AM   #4
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Need Part# for Delco Remy High Note Horn
https://www.ebay.com/itm/296522113951
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 10-10-2024, 10:13 AM   #5
1970cstblazer
All of the GM replacement "NOS" service horns came with universal bracketry. I have drilled the spotwelds out of an original horn to remove the factory bracket, and very carefully plug welded the bracket to the new replacement horn.
Old 10-16-2024, 12:40 AM   #6
NorthernMatthew
Thank you for the tip and I went right to it but the ad was expired. New is great but pricey for sure. Seems that the high note OEM horns aren't in great abundance out there but I'll keep my eyes open. Would rather have OEM over a modern version for sure.
