Old 09-18-2024, 08:19 PM   #276
mobileortho
mobileortho's Avatar
Re: '50 3600 re-do. Shortening things up!
Back at it again. Not optimistic about the condition of the 6.0 with the piston grenading so as a back up I bought a complete running 5.3 for $400 bones. I can sell the accessories and make that back. Not planning anything crazy, maybe. mild cam. Also thinking about sealing the Fitech and either using the stock intake or switching to a Holley Sniper carb for the old school look.
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 10-06-2024, 02:25 PM   #277
mobileortho
Started tearing it down & it looks pretty decent, cleaned up the carbon build up from the pistons but the cylinders look good. I’ll scavenge the cam from the 6.0.
Robert C.
1950 3600
Old 10-06-2024, 05:07 PM   #278
8man
Good buy on the 5.3.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is online now   Reply With Quote
Old 10-07-2024, 09:42 AM   #279
dsraven
interested to see how the parts look when the bottom end is apart, see how bad the piston skirts look etc.
Old 10-13-2024, 08:11 AM   #280
mobileortho
Started tearing into the 6.0. The plot thickens! Don’t know what this cylinder is going to look like but sure it won’t be good.🥺
Robert C.
1950 3600
Old 10-13-2024, 09:27 AM   #281
dsraven
I guess they saved a few bucks on new valve springs, huh?
Old 10-13-2024, 04:54 PM   #282
mobileortho
It gets worse the further I tear into it. The head is destroyed, deep gouges I the cylinder wall. $$$ down the drain.😡😡🤬
Robert C.
1950 3600
Old 10-13-2024, 04:59 PM   #283
8man
Wow! Not good.
8man-aka Robert
Old 10-13-2024, 05:04 PM   #284
dsraven
and, no warranty.
got pics of the block?
Old 10-14-2024, 07:47 AM   #285
mobileortho
Originally Posted by dsraven View Post
and, no warranty.
No. It is/was a new build still wrapped on the pallet, but since I wasn’t the original buyer, the warranty was non transferable. I’ll try to get a better pic of the cylinder. In the meantime, here’s the rest os the mess left in the tray.
Robert C.
1950 3600
Old 10-14-2024, 07:51 AM   #286
mobileortho
At least, t was able to salvage th cam, lifters & pushrods. I was hesitant about the oil pump but the screen on the pickup tube kept fragments from getting into it so I reused that as well.
Robert C.
1950 3600
Old 10-14-2024, 10:15 AM   #287
dsraven
if it were me I would disassemble the oil pump and check for small metallic debris, clean it all up, imcluding the bypass, lube and assemble. cheap insurance.
Old 10-14-2024, 10:23 PM   #288
mobileortho
Best I could do.
Robert C.
1950 3600
Old 10-14-2024, 10:25 PM   #289
mobileortho
Before and after. Hope to fire it this weekend!
Robert C.
1950 3600
Old 10-18-2024, 08:39 AM   #290
6DoF
6DoF's Avatar
the orange just looks proper, good luck!
6DoF is offline   Reply With Quote
Old 10-18-2024, 08:37 PM   #291
vintovka
vintovka's Avatar
Do you know the cause of the destruction? Is wasn't just a broken spring was it???
vintovka is offline   Reply With Quote
Old 10-18-2024, 09:39 PM   #292
dsraven
looks like a valve spring broke, then the valve dropped out, then the piston hit the valve, then the pocket book was hit hard.
Old 10-18-2024, 10:26 PM   #293
vintovka
vintovka's Avatar
Wow. Thats something tp think about!
Old 10-19-2024, 08:06 AM   #294
mobileortho
That’s what I suspect, especially that last part!
Robert C.
1950 3600
Old 10-19-2024, 10:20 AM   #295
vintovka
vintovka's Avatar
More shoddy products???
