10-07-2024, 09:44 PM | #1 |
Fan Shroud, Normal Operating Temps, Issues?
How hot should a 1972 SBC 350 run and get to after it’s shut off?
Have a fan shroud but think the gap between the radiator and the shroud is too large not sure how I will rectify it but looking for opinions and advice. Last edited by kna4977; 10-07-2024 at 09:50 PM. |
10-07-2024, 10:14 PM | #2 |
Who Changed This?
Re: Fan Shroud, Normal Operating Temps, Issues?
First, get rid of that fan clutch eliminator and put on a clutch that will place the center of the fan blade edges at the edge of the shroud. That MAY take a couple of trial fits. I wouldn't worry about how hot the coolant gets after the engine is shut off. It's guaranteed to go up because of residual heat in the engine that is now not being carried away. 230° isn't an unusual temperature after shutdown. I've seen elsewhere here that a 195° thermostat was installed at the factory.
10-07-2024, 10:33 PM | #3 | |
20' Daredevil (Ret)
There's a chance you might have a shroud for a 4WD truck. It's deeper than one for 2WD, because a 4WD engine sits farther back in the engine bay.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
10-07-2024, 10:52 PM | #4 |
Looks to be a 4WD shroud. Also I do believe you need a clutch fan when you have AC
10-07-2024, 11:31 PM | #5 |
20' Daredevil (Ret)
Yep, factory A/C in my K20 came with a clutch fan.
10-08-2024, 08:07 AM | #6 |
Don't know the level of correctness you are going for, but 4WD Blazers/trucks used a steel connecting pipe for the upper radiator hoses with 4 tower clamps.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
10-08-2024, 09:33 AM | #7 |
10-08-2024, 09:36 AM | #8 | |
10-08-2024, 10:03 AM | #9 | |
Hoses are available on the parts board Just sold one last week
10-08-2024, 12:02 PM | #10 | ||
20' Daredevil (Ret)
10-08-2024, 01:05 PM | #11 |
there are 3 levels of fan clutch made by Hayden. Standard, HD and Severe Duty. AC equipped want a HD
Hayden 2747 https://www.amazon.com/dp/B000C3F370...fed_asin_title 7 blade fan wants to be half in/out of shroud |
10-08-2024, 01:07 PM | #12 | |
10-08-2024, 01:09 PM | #13 |
[quote=jaros44sr;9345920]image by [url=https://www.flickr.com/photos/97391199@N06
Hoses are available on the parts board Just sold one last week[/quote] Got any more? Did they have some kind of rubber hose on each end as well with the 4 tower clamps? Anyone know the reasoning behind using a metal hose? |
10-08-2024, 01:19 PM | #14 |
I have this one but other brands are available
https://www.npdlink.com/product/fan-...%3D7%26year%3D get a coolant recovery tank for a 75 Nova and mount it inside the PS fender next to battery. (pic of my 67 Camaro with the Nova tank) Or buy the generic Dorman and mount it on core support https://www.amazon.com/dp/B000E35UV2...fed_asin_title |
10-08-2024, 01:50 PM | #15 | ||
20' Daredevil (Ret)
The repro fan linked above by 72SB looks identical to my OEM fan.
10-08-2024, 03:08 PM | #16 |
Here's a thread on repop metal tubes. It gives you an idea what the originals looked like.
https://67-72chevytrucks.com/vboard/...d.php?t=624805
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
10-08-2024, 03:09 PM | #17 |
10-08-2024, 06:24 PM | #18 | |
10-08-2024, 06:53 PM | #19 |
20' Daredevil (Ret)
The fan clutch bolts directly to the water pump flange (sandwiching the pulley, of course) with no spacers. The fan bolts to the rear of the clutch.
10-08-2024, 07:37 PM | #20 |
Who Changed This?
Fan clutch eliminators were a cheapo replacement for a not-really-that-expensive clutch. When I worked in a parts store, we sold those like hotcakes. Southern California does get hot.
10-08-2024, 07:39 PM | #21 |
Would that put the fan far enough into the shroud as it’s currently got quite a long spacer on it? Currently has a 4 blade fan with no clutch.
10-08-2024, 07:50 PM | #22 | |
20' Daredevil (Ret)
Distance from the fan mounting surface to the water pump pulley is roughly 1 1/2". Also, in your pic it looks like the fan is sitting too far into the shroud -- meaning the spacer is likely too long.
10-08-2024, 10:51 PM | #23 | |
Anyone able to share a pic of a factory setup? |
10-08-2024, 10:57 PM | #24 |
20' Daredevil (Ret)
Yep. Also want to add, that fixed 4-blade fan will likely never pull as much air as a proper 7-blade. Its blades are possibly narrower and have less pitch than a fan that's designed for a clutch unit.
10-09-2024, 10:16 AM | #25 |
I know I’ll need a clutch either Hayden 2747 or AC-Delco 15-80245 and a 7 blade fan like a Dynacorn M1017.
I doubt any of the bolts that are on it now will work so anyone know what else I would need for hardware? |
