Old 09-12-2024, 11:46 PM   #1
TonyM
TonyM's Avatar
E Brake cable HELP PLEASE
Hi there! I need some help sourcing this brake cable so I'm consulting the experts! I have a 68 GMC 920 with a 4spd. I don't believe that this is a stock brake setup because it connects to the transmission and brakes the driveshaft, I believe. If any of you recognize the cable in the photo or could help me source one, I'd really appreciate it!!!
68GMC in family since new
Victoria, B.C.
Canada
TonyM is offline   Reply With Quote
Old 09-13-2024, 07:08 AM   #2
RustyPile
RustyPile's Avatar
Re: E Brake cable HELP PLEASE
TonyM, Many GMCs had a brake drum apparatus attached to the drive shaft for the parking brake.
RustyPile is offline   Reply With Quote
Old 09-13-2024, 08:18 AM   #3
Jason Banks
Jason Banks's Avatar
If Inline Tube doesn't have it, I would call them, I think they will custom make/duplicate.
Jason Banks is offline   Reply With Quote
Old 09-13-2024, 09:46 AM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
That's option J76- Prop Shaft Parking Brake.
SPID codes are here-
https://outintheshop.com/options.html
~Steven
Simi Valley, CA
Old 09-13-2024, 03:44 PM   #5
67km1590
Junior Member
Call Control Cables Inc 562-949-0455, Ed has made several for me and did a great job. Also his turnaround is quick.
67km1590 is offline   Reply With Quote
Old 09-14-2024, 09:50 AM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Here are some threads on the driveshaft brake. This search will include all years so keep that in mind.
https://www.google.com/search?domain...D%3A1%3B&hl=en
Leon
Old 09-15-2024, 12:03 PM   #7
TonyM
TonyM's Avatar
Thanks everyone! I guess it is stock after all. It's on the SPID sheet. You guys are awesome!
Victoria, B.C.
Canada
Old 10-09-2024, 01:33 AM   #8
TonyM
TonyM's Avatar
Control cables hooked me up too. Thanks so much for the tip! Cheers
Victoria, B.C.
Canada
Old 10-09-2024, 03:45 AM   #9
'68OrangeSunshine
'68OrangeSunshine's Avatar
Hi. My Canadian Language proficiency is a bit rusty, but does ''920'' mean 3/4 Ton? And do you have an SM 420 in a Model Year 1968?
I have a '68 Chevy C/10 Stepside from Fremont, CA, w/L6 292 and an SM 465.
I do think the Prop Shaft Hand Brake is cool.
I had to R&R the E-Brake cable my '71 GMC Jimmy [350/SM465/NP205/12-Bolt 3.73] earlier this year.
You have my sincerest commiserations...
Old 10-09-2024, 10:13 AM   #10
dagnabbitt
dagnabbitt's Avatar
I had no cable at all, so added a '66 handbrake to mine, we will see how it works.
I ran the casting numbers on my 292 and SM420 and discovered they are both dated from 1964. I don't think they have ever been out of the truck.
I realize this sounds crazy, but I have this theory that Oshawa trucks were built with some NOS equipment from the previous generation. There are lots of 1968s here with SM420s in them, and I have yet to see a J76 option on a C10 or C20 that was not built in Canada.
Would you post some pics for us, and maybe take a look at your casting numbers as well?
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 10-09-2024, 06:13 PM   #11
'68OrangeSunshine
I have also heard the rumor that unused SM420s went to Canadian plants after the 1967 Model Year production ended, and were installed until they ran out in MY '69. Also that it was mainly in GMCs.
I have a junkyard score of an SM465/T221 Rockwell transfer case. Possible core for a future 292 powered '72 K/5 project. Fabricating shift linkage for the T221 is gonna be the most fun, ever. One year-only, 1968. They went to the quieter NP205 in '69.
RPO code for SM465 was '' 1M20AJ 4-SPEED TRASNSMISSIO '' where you can delete the 1 and AJ as code fillers and add the N. [That's from my '71 GMC]. The RPO code in my '68 C/10 SPID is: ''04M20AL 4 SP TRANSMIS ION '' (Eroded letters) So M20 for the SM465.
But then, the SPID entry on the glovebox door of my '67 K/10 Suburban is ''04M20GQ 4 SPD TRANSMISSION''
A Model Year 1967 truck would have had an SM420. No engine is called out, but an E[eight] in the VIN would've been the Base V8, The 283. Probably the T221, too.
When I bought that truck it had been modified by the PO to a BBC 454 V8/TH350/NP205/12-Bolt 3.73.
So M20 is also the RPO code for the SM420. Go figure.
SPID-speak is weird. An early Robotic dialect.
Old 10-12-2024, 05:58 PM   #12
Accelo
Accelo's Avatar
Maybe?https://www.amazon.com/MYFANDOOR-UnI...=AHX24KHDK1XA5
Accelo is offline   Reply With Quote
