Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 10-11-2024, 11:05 AM   #3751
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Air gap gone, twin stick done
image by [url=https://www.flickr.com/photos/97391199@N06
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-11-2024, 08:14 PM   #3752
zicc1835
zicc1835's Avatar
Re: PO has me PO'd
[quote=jaros44sr;9346445]Air gap gone, twin stick done
image by [url=https://www.flickr.com/photos/97391199@N06[/quote]
LOOKS great
zicc1835 is offline   Reply With Quote
Old 10-12-2024, 09:04 AM   #3753
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks Jesse, onto the next hole to be filled
SAFETY FIRST
AS usual, off topic
Jim
Old 10-14-2024, 07:48 AM   #3754
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Missed it by this much……
SAFETY FIRST
AS usual, off topic
Jim
Old 10-16-2024, 08:27 AM   #3755
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I found it mo better to support both sides when drilling
Make sure your chuck clears clamps when you get that Bamm and you’re through the sheet metal
SAFETY FIRST
AS usual, off topic
Jim
Old 10-16-2024, 09:31 AM   #3756
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
SAFETY FIRST
AS usual, off topic
Jim
Old 10-18-2024, 06:33 AM   #3757
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I want to try and seal up my high mount, anyone know how the factory did it, maybe dum dum
I found some 1/2” rope, 5/8” was to big, I’ll use some black weather strip cement to see if it bonds to the nylon
SAFETY FIRST
AS usual, off topic
Jim
Old 10-18-2024, 07:25 AM   #3758
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Which surface will fail first, old rusty metal, or shiny plastic
Found an old wire wheel, variable speed helps
SAFETY FIRST
AS usual, off topic
Jim
Old 10-18-2024, 08:51 AM   #3759
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Finally got to a point where I can install other housing
SAFETY FIRST
AS usual, off topic
Jim
Old 10-19-2024, 10:58 AM   #3760
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Seems easier to paint on a product then to wire brush, with all those wires flying out
Glue worked with an overnight soak
SAFETY FIRST
AS usual, off topic
Jim
Old 10-22-2024, 08:33 AM   #3761
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I like to use a primer coat of the 3M adhesive, let it sit overnight, and reapply in morning, let it flash and apply
SAFETY FIRST
AS usual, off topic
Jim
Old 10-23-2024, 10:48 AM   #3762
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Out of the clear blue adhesive stops sticking to the trans hump
SAFETY FIRST
AS usual, off topic
Jim
Old 10-23-2024, 12:13 PM   #3763
litebulblsc
litebulblsc's Avatar
Re: PO has me PO'd
Doesn't like the bare metal?
litebulblsc is offline   Reply With Quote
Old 10-24-2024, 04:51 AM   #3764
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Good guess, I have no idea. But, later in the day, I wire brushed the area and added another coat of rust mort, let it dry and it stuck
Maybe a bubble of bad product in the tube, but that doesn’t make sense b/c I continued to use the same product later in the day
SAFETY FIRST
AS usual, off topic
Jim
Old 10-24-2024, 06:39 AM   #3765
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
2nd most feared tool, I envision bad things happening when I pick up this tool, right in front of the death wheel
Pressure not sawing action
SAFETY FIRST
AS usual, off topic
Jim
Old 10-24-2024, 07:14 PM   #3766
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
So, today I slowed my driver down to 10rpm, so the wire bristles don’t fly out at me, gave it a coat of rust mort and coated it with my spatter paint
SAFETY FIRST
AS usual, off topic
Jim
Old 10-25-2024, 09:12 AM   #3767
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Apparently some sort of chemical reaction, spatter paint turned chalky, 2 steps back
It looked good last night
Guess I better do a better job at prepaint
SAFETY FIRST
AS usual, off topic
Jim
Old 10-26-2024, 09:11 AM   #3768
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Prepanel bonding assembly
SAFETY FIRST
AS usual, off topic
Jim
Old 10-26-2024, 10:10 AM   #3769
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Cut the shank off at surface of sheet metal
SAFETY FIRST
AS usual, off topic
Jim
Old 10-26-2024, 06:52 PM   #3770
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Well I guess this stuff works like a plug weld
SAFETY FIRST
AS usual, off topic
Jim
Old 10-28-2024, 11:04 AM   #3771
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Had to stop, blood sugar dropped to 53 borderline passing out, yet to experience that, rather not
SAFETY FIRST
AS usual, off topic
Jim
Old 10-28-2024, 12:35 PM   #3772
zicc1835
zicc1835's Avatar
Re: PO has me PO'd
Yikes don’t let that happen
Old 10-28-2024, 05:27 PM   #3773
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks Jesse, seems like the older I get, the more things are failing on my body, thank goodness we have doctors and technology I have several devices in there. My favorite is the main artery from my heart to my groin, made of goretex and some synthetic stuff
SAFETY FIRST
AS usual, off topic
Jim
Old 10-28-2024, 08:13 PM   #3774
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Tried the old molten hoola hoop trick wasn’t satisfied with results, so I filled up the hollow rope with 3M adhesive, let it cure for 4hours, then I could shape into desired shape
SAFETY FIRST
AS usual, off topic
Jim
Old 10-30-2024, 02:30 PM   #3775
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
https://flic.kr/p/2qr8dL4
SAFETY FIRST
AS usual, off topic
Jim
