10-11-2024, 11:05 AM | #3751 |
Re: PO has me PO'd
10-11-2024, 08:14 PM | #3752 |
Re: PO has me PO'd
[quote=jaros44sr;9346445]Air gap gone, twin stick done
image by [url=https://www.flickr.com/photos/97391199@N06[/quote] LOOKS great
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
10-12-2024, 09:04 AM | #3753 |
Re: PO has me PO'd
Thanks Jesse, onto the next hole to be filled
10-14-2024, 07:48 AM | #3754 |
Re: PO has me PO'd
10-16-2024, 08:27 AM | #3755 |
Re: PO has me PO'd
I found it mo better to support both sides when drilling
Make sure your chuck clears clamps when you get that Bamm and you’re through the sheet metal image by [url=https://www.flickr.com/photos/97391199@N06
10-16-2024, 09:31 AM | #3756 |
Re: PO has me PO'd
10-18-2024, 06:33 AM | #3757 |
Re: PO has me PO'd
I want to try and seal up my high mount, anyone know how the factory did it, maybe dum dum
I found some 1/2” rope, 5/8” was to big, I’ll use some black weather strip cement to see if it bonds to the nylon image by [url=https://www.flickr.com/photos/97391199@N06
10-18-2024, 07:25 AM | #3758 |
Re: PO has me PO'd
Which surface will fail first, old rusty metal, or shiny plastic
image by [url=https://www.flickr.com/photos/97391199@N06 Found an old wire wheel, variable speed helps
10-18-2024, 08:51 AM | #3759 |
Re: PO has me PO'd
Finally got to a point where I can install other housing
10-19-2024, 10:58 AM | #3760 |
Re: PO has me PO'd
Seems easier to paint on a product then to wire brush, with all those wires flying out
image by [url=https://www.flickr.com/photos/97391199@N06 Glue worked with an overnight soak
10-22-2024, 08:33 AM | #3761 |
Re: PO has me PO'd
I like to use a primer coat of the 3M adhesive, let it sit overnight, and reapply in morning, let it flash and apply
10-23-2024, 10:48 AM | #3762 |
Re: PO has me PO'd
Out of the clear blue adhesive stops sticking to the trans hump
10-23-2024, 12:13 PM | #3763 |
Re: PO has me PO'd
Doesn't like the bare metal?
10-24-2024, 04:51 AM | #3764 |
Re: PO has me PO'd
Good guess, I have no idea. But, later in the day, I wire brushed the area and added another coat of rust mort, let it dry and it stuck
Maybe a bubble of bad product in the tube, but that doesn’t make sense b/c I continued to use the same product later in the day image by [url=https://www.flickr.com/photos/97391199@N06
10-24-2024, 06:39 AM | #3765 |
Re: PO has me PO'd
2nd most feared tool, I envision bad things happening when I pick up this tool, right in front of the death wheel
Pressure not sawing action image by [url=https://www.flickr.com/photos/97391199@N06
10-24-2024, 07:14 PM | #3766 |
Re: PO has me PO'd
So, today I slowed my driver down to 10rpm, so the wire bristles don’t fly out at me, gave it a coat of rust mort and coated it with my spatter paint
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-24-2024 at 07:23 PM. |
10-25-2024, 09:12 AM | #3767 |
Re: PO has me PO'd
Apparently some sort of chemical reaction, spatter paint turned chalky, 2 steps back
It looked good last night Guess I better do a better job at prepaint image by [url=https://www.flickr.com/photos/97391199@N06
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-25-2024 at 09:17 AM. |
10-26-2024, 09:11 AM | #3768 |
Re: PO has me PO'd
10-26-2024, 10:10 AM | #3769 |
Re: PO has me PO'd
Cut the shank off at surface of sheet metal
10-26-2024, 06:52 PM | #3770 |
Re: PO has me PO'd
Well I guess this stuff works like a plug weld
Today, 11:04 AM | #3771 |
Re: PO has me PO'd
Had to stop, blood sugar dropped to 53 borderline passing out, yet to experience that, rather not
Today, 12:35 PM | #3772 |
Re: PO has me PO'd
Yikes don’t let that happen
