Old 10-05-2024, 12:28 AM   #1
bennylava
bennylava's Avatar
Which paint schemes/colors make the 80's trucks look older?
I have an 87 model that I will have repainted next year. It's in bad need of a new paint job. But I have never liked the original colors.
I was hoping for a paint scheme that makes it look even older. I'm thinking having a white roof is a step in the right direction. Anyway, I was hoping that some of you might have some pictures for a recommendation.
Thank you
bennylava is offline   Reply With Quote
Old 10-05-2024, 12:44 AM   #2
Wikid61
Wikid61's Avatar
Re: Which paint schemes/colors make the 80's trucks look older?
Soft metallic & earth tones of the early '70's.
"Envy is a declaration of inferiority". Napoleon Bonaparte.
Wikid61 is offline   Reply With Quote
Old 10-05-2024, 08:46 AM   #3
kipps
Anything two-tone will be an improvement. Particularly look at ZY5 two-tone configurations.
Do a google search for "chevy squarebody stripe". Most of the image results will be of the 1970's trucks, but there are a few 1980's trucks included in the mix as well. Any of those gaudy stripe packages will instantly date the truck to where you want it.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 10-05-2024, 10:33 AM   #4
Dead Parrot
Probably not what you have in mind but a "Flower Power" scheme would definitely scream 60's. The 67? Chevy PU my dad bought new was single color white and I think it was more flat then the modern super gloss.
Dead Parrot is offline   Reply With Quote
Old 10-07-2024, 04:35 PM   #5
bennylava
bennylava's Avatar
Great ideas!
Anyone have a pic of an 80's truck where the roof is white, or a different color than the top half of the truck?
Old 10-07-2024, 05:39 PM   #6
cadillac_al
Med Olive is definitely an early 70's color. That's the color I am painting my truck; two tone with white.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 10-19-2024, 10:08 AM   #7
bennylava
bennylava's Avatar
Do you happen to have a pic of the color scheme you're referring to?
Maybe 70's colors would do the trick, when it comes to making the truck look a bit older than the 80's.
Old 10-26-2024, 08:34 PM   #8
Sovereign
Here's mine. The roof is the same tan as the lower portion. While it may not scream 70's or older, it's definitely a classic color scheme which is why I bought the truck.
As suggested, earth tones are great 70's color. There are some beautiful browns out there. Don't limit yourself to GM colors. Porsche and Lexus have some great browns. They won't look good with a while roof, but you could pair it with a lighter brown or tan.
Mint greens and pea greens are also 60s/70s colors. Light blues and even mustard/darker yellows also harken back to the same period. These would lend themselves to a white roof or middle section.
Good luck. Personally, I love seeing different colors. It's not that the regular blacks, blues, reds, and white look bad, but why limit yourself?
1986 C10. Stock aside from being dropped on 20's.
Sovereign is offline   Reply With Quote
Old 10-29-2024, 03:50 PM   #9
bennylava
bennylava's Avatar
I'm looking for a classy paint job that looks great. I don't really want to be the tester for something that turns out not so great.
Old 10-29-2024, 10:31 PM   #10
cadillac_al
https://www.alamy.com/1974-70s-green...b&searchtype=0
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
