Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 10-15-2024, 11:04 AM   #76
NDM
Re: Bucketlist Blazer -Restomod build 6.6liter L8T
Originally Posted by NDM View Post
Since People may be getting sick of my posts here I will just post these random thoughts that keep entering my mind about this build.
I realized today that I may be underestimating the amount of power that my motor is going to be putting out. Brian Tooley Racing for me has been known to be pretty stand up folks amongst the other manufacturers inflate their numbers. Well I was on their site today and found the results from their testing of the motor that I am running on E85. I realize that I was estimating based off a factory intake and E85. That is clearly not what I am running. I have a Holley Hi ram intake and will be running E85. Well it just so happens that my high ram is comparable to the trinity intake that they tested it with and low and behold................I may just be underestimating a bit.
This is the one with the factory intake.
Following up on my own post, I found a test between the trinity intake and the hi-ram but it is on a 6.0 stroker build. This is why I am kind of excited. The BTR testing was done with a stock intake and a trinity. The new video shows that the Hi-ram beats the trinity everywhere. If this is the same kind of results that I will get then I will be very happy! The second screenshot shows that the BTR testing numbers are somewhat consistent (lower though)with the tested numbers. BTR got less power though.
NDM is offline   Reply With Quote
Old 10-19-2024, 08:36 PM   #77
NDM
Tired of waiting for the dual allternator pulleys to be in stock so I bought the single alternator belt to run the motor. It was only like $26 so no big deal.
Got the 3 inch exhaust tubing kit. Just need mufflers now.
Figured out how to run the factory oil dipstick with the lower profile oil pan. I just have to weld on a tab since the bolt hole is too low. It will be tight on the firewall but should make it.
Worked on my Halloween decorations. Halloween is my favorite holiday.
This year added a simple old run down cooler with fake blood, food coloring and random fake body parts wrapped in bags or saran wrap with fake blood inside. Added some napkins with blood to make it look real deal. Even labeled some parts for effect.
Old 10-26-2024, 07:39 PM   #78
NDM
Nothing spectacular to announce but I spent the day learning how to operate the Holley software. I uploaded a couple global files to the ECU and finally got it pretty much how I want. I can now definitely confirm that the Holley software is much easier to use than HPTuners. After just a few hours I feel comfy that I will be able to tune the motor about as well as I have my other LS swap with a factory ECM. So far I am pleased with Holley terminator X max. I should be able to start the motor on the stand soon. Just waiting on a couple parts for the fueling system to arrive.
Old 10-27-2024, 08:59 PM   #79
NDM
This one is very exciting for me! While I just almost blew a gasket at the results of the Bears vs Commanders game, I did finish the design of my fuel system. The holley filter regulator will be near the tank as they suggest. My flex fuel sensor do-dad just so happens to mount perfectly to the Holley fuel rails. The line from the rear will come to the flex fuel thingy and run between the 4 and 6 intake runner and go beneath the intake to a Y adapter. From the Y the equal lengths go to the rails on the back. The front of the rails just tie together.
All lines and fittings are Evil Energy AN-8 lines bought entirely off of Amazon.
Basically I am 95% ready to test fire on the stand.
Old 10-31-2024, 12:07 AM   #80
NDM
Brushless Spal fan from a camaro is on the way. Only 1 more thing on my white board list. Mufflers. I am deciding whether I want to go up to 18 inch case (vs 14 inch) this time. I love that V8 muscle sound but I am getting older and tire from the noise. I want aggressive sound but still want to be able to make a phone call.
Day after halloween and I am going to begin the swap.
Old Yesterday, 11:18 PM   #81
NDM
Fan is here. Only mufflers remain. I will begin tomorrown too tired today from halloween festivities.
