Old 11-05-2024, 12:55 PM   #1
asesapie
1970 GMC Longbed driveshaft
I can’t sort out how to take the front half of my driveshaft out. The front half of the drive shaft with the carrier bearing has no room to move essentially trapping the driveshaft in place. Anyone have any insight on how this thing can be removed? Carrier bearing is too larger to fit through the cross member. I didn’t build this part of my truck it came to me this way from PO.
asesapie is offline   Reply With Quote
Old 11-05-2024, 01:01 PM   #2
HO455
HO455's Avatar
Re: 1970 GMC Longbed driveshaft
Someone correct me if I'm wrong but I don't believe that is a factory carrier bearing. All the ones I've seen are mounted on the other side of the crossmember. You may have to unbolt the crossmember and push it back enough to get the driveshaft out.
RIP Bob Parks.
Old 11-05-2024, 01:02 PM   #3
asesapie
Yeah sorry the photos had a glitch when uploading and making the thread. Uploaded photos now.
Old 11-05-2024, 01:51 PM   #4
bnorth
with the carrier bearing unbolted you should be able to force the driveshaft back far enough to get the U-joint to clear the yoke on the transmission. You need to remove the U-joint caps for extra clearance.
1970 C10 l/b 292/4spd
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=811062
bnorth is offline   Reply With Quote
Old 11-05-2024, 03:24 PM   #5
Cali72K20
Cali72K20's Avatar
This is from a 1971 service manual Chevrolet Service News Vol. 43, Number 2, Feb 1971.
Cali72K20 is offline   Reply With Quote
Old 11-05-2024, 03:31 PM   #6
Cali72K20
Cali72K20's Avatar
Is your truck a C20/30?
Old Yesterday, 06:57 PM   #7
Sicklajoie
The Niner
Sicklajoie's Avatar
Carrier bearings differ depending on if you're running leafs vs coil springs/truck arms.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old Yesterday, 08:22 PM   #8
Richard
Pop the metal U clamp off of the rubber isolator and it should go through the hole in crossmember.
Richard
Old Yesterday, 10:46 PM   #9
asesapie
Well got it sorted out. First time messing with one and thanks to Bnorth and Richard I got it sorted. Appreciate the help. Didn’t know the metal cage around the rubber isolator would pop off. Thanks!!
