11-09-2024, 10:18 AM | #1 |
Clutch Fan Install getting mucho frustrated
Could someone break it down the assembly order for this? I'm thinking I need studs because I cannot get the bolts in from the fan side o from the water pump.
Hey man 67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603 |
11-09-2024, 10:27 AM | #2 |
Who Changed This?
Re: Clutch Fan Install getting mucho frustrated
Save yourself mucho frustration and get the studs. It's 10 times easier.
11-09-2024, 01:23 PM | #3 |
20' Daredevil (Ret)
This. The last time I changed my fan clutch, I didn't know about the studs. Fiddly but I eventually got it. Told myself if I ever do it again, I'll get the studs.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
11-09-2024, 01:49 PM | #4 |
Moderator
I use studs on every vehicle I own, makes life way easier.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
11-09-2024, 02:37 PM | #5 |
Copy that. Thank you I'm getting studs.
11-09-2024, 03:01 PM | #6 |
I used studs on my 67 327 as well. Much easier to line up the clutch under the shroud
11-09-2024, 03:17 PM | #7 |
Napa has a kit with everything you need.
71 C-20 07 Magnum RT AWD |
11-09-2024, 07:01 PM | #8 |
Active Member
You're not putting that spacer back, right? I believe those are only for flex fans replacing thermo clutch fans.
11-09-2024, 08:44 PM | #9 |
20' Daredevil (Ret)
Good point, that spacer should not be needed. The real test is whether the fan blades are roughly half-in, half-out of the shroud opening.
11-10-2024, 03:12 AM | #10 |
I do need that spacer to reach half in half out position in shroud. Hope i can find studs that long. I'll look at NAPa because O O'Reilly only had two inches
11-10-2024, 08:51 AM | #11 |
I ordered this from Summit. Hope it works
Yesterday, 12:20 PM | #12 |
It didn't work. Going to augment shroud
Yesterday, 01:35 PM | #13 |
20' Daredevil (Ret)
I couldn't tell by the pic, and don't have the particulars off the top of my head.... But is there a chance you have a short water pump, and a long water pump might put everything right?
EDIT: This might help:
Yesterday, 02:45 PM | #14 |
Who Changed This?
^ Interesting pic. My '70 BBC has a short water pump.
Yesterday, 04:14 PM | #15 |
20' Daredevil (Ret)
Well, the OP's '67 should have a short original WP -- but over the years, things can change.
Yesterday, 04:59 PM | #16 |
Who Changed This?
What's worse is that my fan clutch is about 1/2" from the radiator. That's the severe duty clutch, though, which has fins that stick out pretty far past the fan mounting flange. I ended up just making a shroud from a piece of aluminum strap.
We haven't seen the OP's shroud. Maybe the deeper 4WD shroud would work?
Yesterday, 08:24 PM | #17 |
I agree. I've tried both ways and studs are definitely the way to go.
Today, 01:59 AM | #18 |
If you do a search for 5/16 studs 1.25 inches long you will find several with the fine thread end longer than the course thread end. This is not ideal for a fan clutch instillation.
AMK has the correct hard to find studs available but has a minimum order of $30. Along with the studs I also bought some correct water pump, alternator, and power steering pump bolts to replace some ugly hardware store bolts. https://www.amkproducts.com/bulk-fas...oduct_ID=11003 |
Today, 07:57 AM | #19 |
I have a long water pump.
Today, 10:35 AM | #20 | |
Something is strange then . The long water pump would push the fan further into the shroud . I have this problem on my 72 it had a later model engine with a long water pump with the associated accessories brackets. The fan is not half in and out it’s completely inside the shroud . I’ll post a pick later have to go out to the truck Edit for pictures: It’s not optimal but the truck has never overheated even pulling the trailer .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; Today at 12:03 PM. |
Today, 11:06 AM | #21 |
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
