Old Today, 02:36 PM   #1
jabborabbo
jabborabbo's Avatar
Gonna rebuild the rear drum brakes on my ‘67
Does anyone have a link to a DIY regarding rear drum brake rebuilding for my ‘67 GMC or other compatible year (and/or particular things to watch for?). I rebuilt the front brakes a while back with no problems, but I feel better if I have a reliable go-by handy….
Also, should I rebuild the master brake cylinder while I’m at it or wait until it starts misbehaving?
Thanks in advance for any and all info! I love this board!!!
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense
jabborabbo is online now   Reply With Quote
Old Today, 03:11 PM   #2
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Gonna rebuild the rear drum brakes on my ‘67
Make sure you do only one side at a time. That way you can get an idea of how to reassemble if you are uncertain, or take a pic of it prior to disassembly. Make sure the shoe with the shorter lining material goes towards the front. Always preferably replace or rebuild the wheel cylinders, since they fail if they set just a few months, and ensure the bleeder screw can loosen. Make sure the self adjuster is free and apply some high temp anti-seize to the threads. Use high temp anti-seize on the drum to hub mating surfaces to ensure the drum comes off the next time you need to service the brakes. When you have the shoes adjusted properly on both LH and RH, adjust the parking brake.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
1970cstblazer is online now   Reply With Quote
