Old 11-10-2024, 10:41 AM   #351
raggedjim
raggedjim's Avatar
Re: Previous owner '68
Parts, pieces, pieces, parts.
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 11-10-2024, 10:43 AM   #352
raggedjim
raggedjim's Avatar
And it just keeps on leaking!
Roger
'70 GMC Jimmy 2wd
Old 11-10-2024, 10:46 AM   #353
raggedjim
raggedjim's Avatar
Hi-tech organization system.
Roger
'70 GMC Jimmy 2wd
Old 11-10-2024, 10:51 AM   #354
raggedjim
raggedjim's Avatar
Case is close to being empty.
Roger
'70 GMC Jimmy 2wd
Old 11-10-2024, 03:53 PM   #355
zicc1835
zicc1835's Avatar
I thought I read that you needed this experience the way your going at this looks like you are getting what you asked for ...I wouldn't think of rebuilding a auto trans but now you got me starting to turn your way I have a motor and trans in waiting ...for rebuilding but need to finish my current build ...great progress on your project
zicc1835 is offline   Reply With Quote
Old 11-10-2024, 05:02 PM   #356
raggedjim
raggedjim's Avatar
Trust me, I'm tearing it down and replacing whatever is in the kit but I have a very rudimentary understanding of what the hades is going on in this thing! And I am getting experience! If all goes well I have another one to do for my Pontiac.
I do have a book! But I'm also taking lots of notes which means I'm going slower than a real mechanic would.
I like trying to rebuild things. I was going to rebuild the waterpump but the kit cost more than a new one.
Roger
'70 GMC Jimmy 2wd
Old 11-10-2024, 06:50 PM   #357
raggedjim
raggedjim's Avatar
Took the case to the carwash and sprayed the crap out of it. Looks pretty clean and feels good to the touch.
Roger
'70 GMC Jimmy 2wd
Old 11-10-2024, 06:53 PM   #358
raggedjim
raggedjim's Avatar
Found a worn bearing surface on the output shaft ring gear. Not sure if a tranny guy would go ahead and use it, but I have another one coming in. Every thing else is looking good so far.
Roger
'70 GMC Jimmy 2wd
Old 11-11-2024, 10:07 AM   #359
loudchevy
loudchevy's Avatar
Awesome posts! Never opened one up before and like yourself have a very basic understanding of how it all works. One of these days I'll tear open a TH350 and do this same thing.
I would've replaced that part as well. Might as well while you have it blown apart. Looking forward to seeing it go back together.
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is online now   Reply With Quote
Old 11-12-2024, 10:59 AM   #360
raggedjim
raggedjim's Avatar
If you find one cheap enuff, or even free is better, then I would go for it. There are a couple of tools that help, I'll try to take a picture of them.
The book I have has a few weak areas, but I am also checking the web as I go. Here's a pretty good thread I found. https://nastyz28.com/threads/first-t...-wrong.325954/
Roger
'70 GMC Jimmy 2wd
Old 11-13-2024, 03:40 PM   #361
raggedjim
raggedjim's Avatar
Tools I have been using.
The one to the right is to help guide in seals.
The one in the middle is a slide hammer I modified to help pull the pump. Just welded a bolt that fit the tapped holes in the pump to a nut that fit the slide hammer.
Last one is a clutch spring compresser. It looks odd but works well.
Roger
'70 GMC Jimmy 2wd
Old 11-15-2024, 12:02 AM   #362
dmack91
dmack91's Avatar
On your engine mounts, I would be concerned with the small surface area of the spacer transferring the weight of the engine to the frame. Not sure if it would be a problem or not. I just cut some flat bar stock the length of the mount, 1/2" thick, and drilled the corresponding holes.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 11-15-2024, 10:26 AM   #363
raggedjim
raggedjim's Avatar
You have a point there, I like the idea of a block better! More surface area to spread the load.
Thanks, Rg
Roger
'70 GMC Jimmy 2wd
Old 11-15-2024, 10:39 AM   #364
1970cstblazer
1970cstblazer's Avatar
I've always admired and respected good transmission techs. There is a lot going on inside of an auto, no matter the vintage. It doesn't take much to mess them up!
Great work thus far.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 11-15-2024, 11:34 AM   #365
raggedjim
raggedjim's Avatar
Oh great!!! Just kidding! I'm doing my best, waiting on parts to replace worn parts is slowing me down.
I actually realized that the pump unit on these is also acting as a rotary coupling. I used to mess around with Fibro table rotary couplings when I was still going to work everyday. So I do know a little bit about how they work!
Roger
'70 GMC Jimmy 2wd
Old 11-16-2024, 11:01 AM   #366
raggedjim
raggedjim's Avatar
Got the replacement ring gear, it looks more better good.
Roger
'70 GMC Jimmy 2wd
Old 11-16-2024, 11:04 AM   #367
raggedjim
raggedjim's Avatar
Installed it on the output shaft and put the shaft in the housing. Then I loaded in the low/reverse clutch pack. Pretty easy, start with a steel and alternate with friction. Soak frictions in ATF for 5 minutes before install.
Roger
'70 GMC Jimmy 2wd
Old 11-16-2024, 11:08 AM   #368
raggedjim
raggedjim's Avatar
Then I grabbed the anti-clunk spring to put it in and I dropped it and this happened. What tha??? Don't really understand it, it's very hard and must have had a defect, so at least it broke now and not while in service.
Once again waiting on parts...
Roger
'70 GMC Jimmy 2wd
Old 11-16-2024, 11:10 AM   #369
raggedjim
raggedjim's Avatar
So I painted my intake.
Roger
'70 GMC Jimmy 2wd
Old 11-16-2024, 11:18 AM   #370
raggedjim
raggedjim's Avatar
Now, I hate to even bring this up but I found this thing in the area I'm working on the transmission and I THINK it might go in the tail housing at the end of the driven speedo gear??? It fit there well but is this right??? Do I even need it???
Without it there is quite a bit of side to side play on the driven gear but with in it tightens it up nicely. Is it typical for the driven gears to have side to side play?
Working on transmissions is fun!
Roger
'70 GMC Jimmy 2wd
Old Today, 04:55 PM   #371
raggedjim
raggedjim's Avatar
While waiting on parts I dug through my scrap bin and found some suitable spacer plate for the motor mounts. Thanks to dmack91 for pointing me in the right direction.
Looks okay, not SEMA ready, but that's for people who love $ not trucks.
JMHO, Rg
Roger
'70 GMC Jimmy 2wd
Old Today, 07:01 PM   #372
raggedjim
raggedjim's Avatar
Got the anti-clunk spring in today so I started assembling some of the transmission. This shows the anti -clunk with the snap ring installed.
Roger
'70 GMC Jimmy 2wd
Old Today, 07:06 PM   #373
raggedjim
raggedjim's Avatar
Then I installed the inner race for the low/reverse roller clutch.
Roger
'70 GMC Jimmy 2wd
Old Today, 07:08 PM   #374
raggedjim
raggedjim's Avatar
Next was the sun shell.
Roger
'70 GMC Jimmy 2wd
Old Today, 07:10 PM   #375
raggedjim
raggedjim's Avatar
Then the front planetary assembly. This gets snap ringed in place.
Roger
'70 GMC Jimmy 2wd
