![]() Join Date: Dec 2009
Help Decoding Exhaust Manifolds.
If I remember correctly,
Someone on the forum has a Book that covers the Castings numbers on Intake and Exhaust manifolds. I used my Normal searches and some of Same Cast # manifolds that I found on E bay ![]() I think it has something to do with the LH 24 & RH 6 under the casting #. So Here is my Question. Does anyone know what this Pair of Exhaust Manifolds came off of? Left manifold has a casting # of 3832473 with LH 24 under it. Right Manifold has a casting # of 3838956 with a RH 6 under it. Thanks in advance for the help. ![]() ![]() ![]() My guess is a 69/70 307cid.?
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
![]() ![]() Join Date: Jul 2003
Top one is 3932473 which is a LH 1969-70 2WD. The LH 24 refers to the side and which mold it was cast in. K series 4WD trucks use a RH straight dump manifold 3932465 on both sides.
3838956 does not exist. However, 3896956 is a '67-'70 RH manifold for 2WD 307, 327, 350 W/O A.I.R.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. ![]() 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels Last edited by 1970cstblazer; Today at 02:12 PM. |
Re: Help Decoding Exhaust Manifolds.
So the second number is a 9.
That makes sense. Thank You so much. ![]()
![]() Join Date: Feb 2000
Just adding what my book says:
3932473: Left hand, 307/350, 69-70 Passenger car, W/O A.I.R., angled dump, no bracket 3896956: Right hand, 283/307/327, 67-68 Truck, W/O A.I.R., angled dump, no bracket
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
