![]() Join Date: Jan 2025
Location: Clarkdale, Arizona in a van down by the river
Detailing forum here - I cannot do windows
I am just curious there enough interest in a detailing forum here or if the idea has been suggested.
I suck at cleaning windows no matter how hard I try or what products. The best I can do is to use a waffle weave cloth and lots of cleaner. Using a glass stripper has helped me some too. The wand type things with the cloth on the end do not seem to work for me. On another related note, the magic eraser pads work great on trim and dirty vinyl pieces and even leather seats. My wife used them to clean her 300M seatbelts, dash and door panels and they worked amazing.
'72 C10 / 402 ___________________________________________ Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility. |
#2 | |
![]() Join Date: Dec 1999
Re: Detailing forum here - I cannot do windows
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
The Older Generation
![]() Join Date: Dec 2009
As Richard mentioned there is a Detailing section.
As far as widows go. To deep clean them start with Vinegar and water. Then use Windex or Sprayway foaming glass cleaner. This is what works for me. A Bit of Info Below: Vinegar is one of the most effective cleaning solutions for a car window. It works better than soap and will leave your car windows streak free. Just ensure you have the right vinegar to water ratio and use Black and white print newspaper while cleaning to achieve the best results. Vinegar isnt necessarily a better cleaner than soap, as it differs from soap. While vinegar breaks through dirt and kills bacteria, it wont help on filthy surfaces. And you could use a generic glass cleaner like Windex, but you treat the windows of your car different than you treat other windows in your life for a reason. What is the Correct Vinegar to Water Ratio? Obviously, you cant just pour vinegar on your car and call it a day; instead, you need to take the time to make a vinegar solution for proper application. The proper ratio of vinegar to water when making a cleaning solution is one to one. Therefore, for every one cup of vinegar, you will add one cup of water. Mix both in a spray bottle and apply to your car windows as needed. Do note that you should never mix anything else into this solution, and vinegar is highly reactive and could react negatively to other cleaning products or soaps.
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Like
I have found Sprayaway at Costco for much cheaper. All of the spray bottle type cleaners are crap these days. I found the detailing forum finally - thanks
#6 | |
![]() Join Date: Nov 2018
Just another option |
The Niner
![]() Join Date: Nov 2010
I always use Invisible Glass and a terry towel.
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
Best thing to was use newspaper to do the wiping. No steaks or cloudy smearing crap
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting |
![]() Join Date: Apr 2016
There were members here suggesting LA's Totally Awesome for cleaning. It cleans everything. I have been impressed. I went to Dollar Tree and got 4 spray bottles of it, and poured the spray bottle contents into a gallon distilled water jug to store the undiluted cleaner. You are supposed to dilute it and there is a mixing chart on the bottle. I made 3 bottles worth of cleaners, 5 parts water to 1 part LA for heavy cleaning, 10 to 1 for regular everyday cleaning, and 120 to 1 for glass. For the 5 to 1 and 10 to 1 I used tap water, and for the 120 to 1 I used distilled water. I use it with a paper towel, works great.
#11 | |
Who Changed This?
![]() Join Date: Jan 2013
I've had pretty good luck with a wet microfiber towel, followed by paper towels.
#13 | |
![]() Join Date: Dec 2014
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
#14 | ||
Haven't tried it on windows. I will have to start using it on windows now.
#15 |
I use Awesome at 100% to degrease and clean my engine compartment, spray it on heavy let it sit for a few minutes then rinse it off. Even makes the firewall shine.
#16 |
I saw the Awesome cleaner at a flea market type place and thought it was probably some discount snake oil that they were mixing in their garage or a pyramid scheme product. They had it in cases and it was pretty cheap. I will need to pick some up when I am back there again.
#17 |
![]() ![]() Join Date: May 2015
Lady down the road from me gets her house windows pro cleaned every year... all they use is vinegar and newspapers.
https://67-72chevytrucks.com/vboard/...ighlight=Glass John (theastronaut) uses Dow GC-800
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 02-22-2025 at 11:18 AM. |
#18 |
BlahBlahBlah
I got a few gallons of the Totally Awesome stuff when I was working at Lowes. I think its great and use it on all kinds of surfaces.
Ive used Windex for glass many years with no issues. Used it all the time when I was working on copiers and printers to clean all the glass, mirrors and lenses. Course if you've got water spots on office equipments optics you have bigger problems =0 I have some Griots glass cleaner that does a good job on water spots on car and truck windows.
#19 |
After a good cleaning, regardless of exactly how you do it, try one of the ceramic coatings for glass available on the market. The last car show my truck attended (September 2024) presented all participants with a goody bag. Among a bunch of other things in the bag was a small bottle of a ceramic glass coating product. Don't know the brand but think palm sized plastic spray bottle about the size of two or three bic lighters strapped together. Just spray it on and wipe it off. Anyways, after a good cleaning, the product was applied and to my surprise, subsequent window cleaning since then have been an absolute breeze. Stuff works! Hth, -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#20 |
![]() Join Date: Jul 2007
I learned the news print thing from my dad 70 years ago and have done it since I started driving my own car.
I knew old timers who used a sack of Bull Durham to clean the bugs off with back when every place that sold tobacco products had it on the shelf for pocket change. You have to have something in your other hand to wipe it off our you have a mess though. I've also heard of guys using Coke to scrub bugs off. I bought some fancy glass cleaner that is supposed to clean better at O'Reillys the other day for the OT ride but it is been too freeking cold to try it out.
#21 |
You give lots of good input on here and I appreciate your comments. I'm going to have to question this one though. I guess without a husband to interfere this might be possible. Still, I'm not sure it's advisable... although it sounds like it's working for you...
#22 |
Typically, before and after photos would tell the story but in this case it would probably be quite instructive to have some in-process photos...
