Old 08-09-2012, 02:01 PM   #226
_Ogre
_Ogre's Avatar
Re: 1959 Fleetside REBORN
so as not to hyjack shadow's build, read post 26 in my build
shop air compressor timer
Old 08-09-2012, 05:49 PM   #227
Kim57
Kim57's Avatar
You can also check my build page #11 post 265.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 08-09-2012, 08:25 PM   #228
OrrieG
OrrieG's Avatar
Originally Posted by Green 1959 View Post
How does a person do this?
If you look in that area, there is a sheet metal flap just screwed on. when I found it on mine I assumed a poor patch, but it comes that way from the factory. Intent was to have a place to drain and rod the crud out, but most people did not know about it, or like mine it got covered with undercoating.
OrrieG is offline   Reply With Quote
Old 08-09-2012, 09:40 PM   #229
shadow1967
shadow1967's Avatar
Out in the garage for a while and this happens. Its a rust spot in a re-accruing place. Well, went to finish the boxing plates and forgot to mockup the brakes so I'm not done with that but here is what I came up with for the brakes. need to have it done by tomorrow. We're suppose to place the fuel tank and run lines, Place to air ride stuff and run lines, and plumb the brakes. So we can have the engine, trans and rearend back in end of sunday, so we could recab the frame monday.
Build for my 1959 Fleetside...
http://67-72chevytrucks.com/vboard/s...d.php?t=518308
shadow1967 is offline   Reply With Quote
Old 08-09-2012, 11:56 PM   #230
Kim57
Kim57's Avatar
How come you're mounting your master on the outside of your frame?
Kim
My build thread
Old 08-10-2012, 12:18 AM   #231
OrrieG
OrrieG's Avatar
And backwards, but it looks like that bar with the bearing is going to be a pivot from the original via the long rod??? tube x brace takes up the space where the mc and booster would be on an undercab conversion.
Old 08-10-2012, 01:20 AM   #232
shadow1967
shadow1967's Avatar
Well first, the 6 speed automatic is MASSIVE, compared to turbo350. Plus the hydro-boost is longer then vacuum booster, and it would have put the master cylinder tank under the seat. One of the reasons why I wanted to use all late model stock parts, I want to be able to go to any GM dealer and say fix it, when on a road trip. And not worry about custom parts. The only custom part is the drivers side axle and I'm having that made to stand a 1000hp. so my 400+hp motor should not break that. Plus automatics are a soft start compared to a stick instant impact.
Old 08-10-2012, 01:23 AM   #233
shadow1967
shadow1967's Avatar
Plus , if I use the AD battery lid I can have one on eash side to match.
Old 08-10-2012, 11:41 AM   #234
Kim57
Kim57's Avatar
That makes sense. I figured the flat stock was the pivot.
Kim
My build thread
Old 08-10-2012, 06:13 PM   #235
shadow1967
shadow1967's Avatar
Kim,
You put the thought in my head, that I could put it anywhere. With your long rod MC.
Old 08-10-2012, 08:30 PM   #236
Kim57
Kim57's Avatar
Originally Posted by shadow1967 View Post
Kim,
It's not my fault you have the same sickness as me.
Kim
My build thread
Old 08-11-2012, 04:54 PM   #237
shadow1967
shadow1967's Avatar
Well I needed to clean up my desk, so I sat in the ac cleaning my desk. I have this stack of receipt in the corner. I totaled them up to $16165, This is the total for all the parts bought since 2008 when I bought the truck. It all adds up in the end. I only had 4 big paydays, 1. the truck it self, 2. the engine and trans. 3. the denali bucket seats with heat and message. 4. rims and tires. IT ALL ADDS UP!
Old 08-11-2012, 05:29 PM   #238
Chevette
Chevette's Avatar
While you're doing the accounting, remember that you'll be able to sell a whole lot of original parts. It may not add up to much, but it will take some of the sting out of your accounts payable (paid).
Chevette is offline   Reply With Quote
Old 08-11-2012, 05:56 PM   #239
hotrod1
56 - autocross
hotrod1's Avatar
Advice. Stop that right now. Dont add up anything. It will mess u up. You will end up saying "Should have bought a few year old mustang and been done with it."
hotrod1 is offline   Reply With Quote
Old 08-11-2012, 05:57 PM   #240
_Ogre
_Ogre's Avatar
brave man
i purposely lost most of my receipts
plausible deniability by lack of knowledge
Old 08-11-2012, 06:00 PM   #241
hotrod1
56 - autocross
hotrod1's Avatar
If u know and the wife asks you, you will be in a world of hurt. The good answer is "i dont know how much I have spent."
Old 08-11-2012, 06:02 PM   #242
shadow1967
shadow1967's Avatar
Originally Posted by _Ogre View Post
brave man
Your starting to talk like the government!
Old 08-11-2012, 06:12 PM   #243
hotrod1
56 - autocross
hotrod1's Avatar
A wife can be like the KGB.
Old 08-11-2012, 09:26 PM   #244
shadow1967
shadow1967's Avatar
Semi-finished for now need heims.
Old 08-12-2012, 01:07 AM   #245
Kim57
Kim57's Avatar
That's looking good.
Kim
My build thread
Old 08-12-2012, 11:40 AM   #246
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
I stopped adding mine up years ago! Keep up the good work!
ChuckDriver is offline   Reply With Quote
Old 08-12-2012, 12:35 PM   #247
Larry Lindley
good work keep at it.if i dont spend my money i will waste it.
Larry Lindley is offline   Reply With Quote
Old 08-12-2012, 07:50 PM   #248
shadow1967
shadow1967's Avatar
Well a little done today. Fabbing sure takes time. Nowhere near where I wanted to be.
Old 08-13-2012, 04:14 PM   #249
_Ogre
_Ogre's Avatar
ingenious how you used the original mc
one of those ''DOH!" why didn't i do that moments
Old 08-15-2012, 10:25 PM   #250
shadow1967
shadow1967's Avatar
Well the rear suspension is mounted up. I'm missing 2 front bolts so we welded it to the frame, till they come. It's time to get this thing running. Hope to have it plumbed(brakes, fuel and air) by sunday. With the drive shaft loops as well.
